Thread started 22 Jun 2012 (Friday) 09:03
Ready to hit the buy button!
DanFrank
Jun 22, 2012 09:03 |  #1
Everyones been great here. Was set on a 7D but a few members opened me up to the 60D. I'm torn between two setups.
1) 60D & 15-85 f/3.5-5.6 IS USM ($1430)
2) 7D & 17-85 f/4-5.6 IS USM ($1459)
All equipment is used. This setup will be a walk around setup, if that makes sense. And is my first DSLR setup. Something I can use for learning and still taking great shots. Don't wanna upgrade in a few months because I didnt put $$ in the first time
Gear "A creative man is motivated by the desire to achieve, not by the desire to beat others"
Martzart
Joined May 2012
Jun 22, 2012 09:19 |  #2
I would go with 7d over the 60, have you considered this lens for a walk-around over those XX-85's, It will give you f2.8 throughout the entire focal range.
Tamron SP AF 17-50mm f/2.8 XR Di II LD IF (external link)
The name is a link to a review for it with sample pics.
Very good lens for a very good price.
Deviant Art ~ (external link) T4i/ T2i /Rip300d ~ 50mm f1.2L/135mm f2L/ 70-200mm f4L/ 100mm 2.8 macro/ Sigma 70-200 2.8/ Tamron 17-50 2.8/ 50 1.8 ~ 430 exII/ Vivitar 285hv/ Metz 60 ct-4
mcoomer
Joined Jun 2012
Jun 22, 2012 09:30 |  #3
With a difference of only $29 I'd go with the 7D. Weather resistant, more fps, better autofocus. That would be my choice.
Mike
Gripped 5D2, 24-70 f/2.8L, 70-200 f/2.8L II, 580EXII
DanFrank
Jun 22, 2012 09:30 |  #4
I'm sorry, I don't know what f2.8 for entire focal range means. New to all this. But I'll take a look!
XxDJCyberLoverxX
Gallery: 30 photos
Jun 22, 2012 09:34 |  #5
Then I'd kindly suggest for you to hold out on hitting the buy button to look more into the kind of lenses you're planning to get. You're choosing between two fantastic cameras (I'd go for the 7D myself), so don't let the lenses be the bottleneck on the images you want to capture.
I've never used the Canon 15-85mm, but many people vouch for that lens. I've used the lens Martzart recommended (Tamron 17-50mm). I loved that lens (until it died).
Daniel
Sony a7 / Sony a7s / FE 24-70mm / FE 28mm F/2 / Samyang 135mm
Nebula 4000 Lite / Manfrotto 190cx
POTN Feedback / My Work! (external link)
rrblint
Gallery: 84 photos
Joined May 2012
Jun 22, 2012 09:35 |  #6
DanFrank wrote in post #14615794 (external link)
If those are the only two rigs that you are considering then I'd take the one with the 15mm lens at the wide end...Those extra 2mm are huge!
Mark
n1klass
Jun 22, 2012 09:35 |  #7
F2.8 over the whole focal lenght means the the aparture doesn't change when you zoom in or out. On, lets say, the 15-85 the lowest aparture you can use at 15mm is f4 but at 85mm the lowest is f5.6.
MadlyAlive
Jun 22, 2012 09:36 |  #8
DanFrank wrote in post #14615906 (external link)
With a variable aperture on the 2 lenses you listed (the 17-85 f/4-5.6 IS USM for example), your minimum available aperture will be between 4 and 5.6 (4 @ 17mm and 5.6 @ 85mm) so your shutter speed with be different throughout the zoom range.
With a constant 2.8 you will be able to use that aperture throughout the zoom range allowing you to keep your shutter speed at the same setting throughout your zooming.
2.8 gives you a few stops over a 4-5.6 and allows you to get faster shutter speeds in low lighting situations.
5D Mark III Gripped ~ 7D Gripped ~ EF 70-200mm f/2.8L IS II USM ~ EF 24-70 f/2.8L USM ~ EF-S 10-22mm f/3.5-4.5 USM ~ EF 50mm f/1.8 II ~ 550EX ~ 600EX-RT
Martzart
Joined May 2012
Jun 22, 2012 09:40 |  #9
Every f stop doubles the amount of light that enters the lens.
The smaller the fstop number, the wider the lens opens up to allow more light in.
Also when shooting with a wider aperture of f2.8 gives you a narrower depth of field, blurring out background detail.
Allowing you to choose to isolate your focus more and blur out background details a bit when you open it up all the way.
Lower f stop lenses are considered faster glass because you can shoot with higher shutter speeds in lower light.
DanFrank
Jun 22, 2012 09:48 |  #10
Ok so the 7D and Tamron 17-50 f/2.8 $1600 used. Should get me started and not wanting to upgrade in 6 months? Except for adding more glass!
Martzart
Joined May 2012
Jun 22, 2012 09:59 |  #11
Should get you started,
another nice decently priced lens to look at later on is the ef 100mm 2.8 macro usm. (external link)
It is really sharp and will give some more reach, plus can be used as macro or a normal 100mm lens.
Great 2nd lens choice imo, because of its versatility, useful length and price.
mtimber
Jun 22, 2012 10:02 |  #12
Personally for your first setup, I would go 7d with a Canon 18-200mm.
I have a 5d3 and a 5d2, but still grab the above setup when I need versatility...
Add a nifty fifty to that, with a yongnuo 565ex flash and you are good to go...
"Lovely photo, you must have a really good camera"
artyman
Sleepless in Hampshire
Gallery: 17 photos
Jun 22, 2012 10:31 |  #13
I'd go withthe 7D and the 15-85 lens, which is a much better lens than the 17-85
Ken
1,987 views & 0 likes for this thread, 9 members have posted to it.
2935 guests, 139 members online
