Thread started 24 Jun 2012 (Sunday) 11:06
17-40mm, uneven ghosting problem
Closed ­ 123
Jun 24, 2012 11:06 |  #1
bannedPermanently
Hey all,
I've been using my 17-40mm for some time now and I have noticed that the lens has a disfunction. The left side of whatever image I take has a lot of ghosting whereas the right image seems fine.
Examples @ f/4, 1/2000, 17mm, ISO100:
Left side: http://i45.tinypic.com​/2lkd7pu.jpg (external link)
Right side: http://i45.tinypic.com​/r1daah.jpg (external link)
Bumping the aperture to f/5.6 makes the problem less apparent.
Is this a normal problem, because it makes the lens quite unusable. It's annoying to say the least.
Canon EOS 80D
Canon 10-18mm STM | Canon 24-70mm f/4 | Canon 50mm STM
Canon Speedlite 430EX II
Phototeacher
Jun 24, 2012 11:12 |  #2
The lens appears to be mis-aligned. Have you had the lens for a while, or is it new to you? Have you recently noticed this problem, or has the lens always had it? Has the lens been struck, dropped, hit, etc?
Does the problem occur with other lenses? If not, then it looks like a trip to Canon is in order. If it shows up with other lenses, then the camera sensor may be suspect.
(Really simple / obvious question: are the front and rear lens elements clean?)
Closed ­ 123
Jun 24, 2012 11:18 |  #3
bannedPermanently
I carefully handle all my lenses, the lens is clean and has never fell or hit anything. Other lenses perform fine, I've only seen it happen with my 17-40mm! :(
I don't think it qualifies for a trip to Canon, since I bought it second-handed.
Canon EOS 80D
Phototeacher
Jun 24, 2012 12:11 |  #4
I meant for a repair, not necessarily warranty work. From the sample you posted, and your original comments, you are (understandably!) not happy with these results.
RobinSchouten wrote in post #14624734 (external link)
casaaviocar
Jun 24, 2012 12:12 |  #5
I think it still qualifies for a trip to Canon. Unless you just want to chalk it up as a loss. Canon should be able to fix that, they might even do it under warranty, I'd have them at least send an estimate of cost. My 17-40 is sharp across the frame.
Rule books are paper they will not cushion a sudden meeting of stone and metal -ekg-
Closed ­ 123
Jun 24, 2012 12:44 as a reply to  @ casaaviocar's post |  #6
bannedPermanently
My 17-40 has the UW serial code. That means it's made in 2008... Would warranty still apply for this lens?
What would be an estimate cost for lens calibration?
Canon EOS 80D
Closed ­ 123
Jun 25, 2012 06:35 |  #7
bannedPermanently
Could anyone fill me in on the estimate price (from personal experience)?
Would I be able to get it aligned in the Netherlands?
Canon EOS 80D
Virto
Joined Nov 2010
Jun 25, 2012 11:16 |  #8
RobinSchouten wrote in post #14628079 (external link)
Canon's US warranty is 1 year, so assuming the EU warranty isn't dramatically different, it will no longer apply.
Prices are hard to quote, since Canon wants to see the item in question before issuing a estimate. In the US, barring a major part replacement, I'd expect the issue to cost something in the area of 150-250 USD.
Visit Canon.nl or call 088 -7322666
Kelly - EOS 5D - EOS 40D - Rebel XS - EOS 10D - EOS 1D - SX230 - AE-1 - OM-1n - Minolta Himatic7 - EOS-1N
ABR800 - Several flashes, remote triggers, stands, too many and yet not enough lenses
Ramon-uk
Gallery: 61 photos
Jun 25, 2012 14:46 |  #9
It looks as though it may be de-centred but it's difficult to tell with these pictures.
Try taking a picture of a flat brick wall, making sure that the camera is parallel to the wall both horizontally and vertically.
lannes
Jun 25, 2012 17:16 |  #10
Does this lens have a filter on it, the issue could be the result of a poor quality filter ?
Closed ­ 123
Jun 29, 2012 17:21 |  #11
bannedPermanently
lannes wrote in post #14630633 (external link)
There is not filter on the lens, thanks. ;)
I have contacted Canon. They told me that they will not fix it, because it does not have warranty anymore. There was no optional paid repair available, because first they'd want to see the lens for themselves. I was warned for high costs and they couldn't assure me that they'll try to fix the problem.
This does not help me at all. As far as I know, my question was a simple one: asking for an estimate cost concerning realignment of the 17-40.
Are there any trusted retailers that could help me out here?
Canon EOS 80D
mrkgoo
Jun 29, 2012 19:06 |  #12
I had a similar issue with my 17-40 brand new:
https://photography-on-the.net/forum/showthre​ad.php?t=792320
In the end, I sent it to canon, they took a while, sent it back and it was still the same. I ended up living with it.
Closed ­ 123
Jun 30, 2012 12:51 |  #13
bannedPermanently
mrkgoo wrote in post #14650715 (external link)
Thank you for sharing, I'm glad to hear I'm not the only one. Mine performs better @ f/5.6, have you tested it with higher apertures? I mean it's still a great lens if you're only going to use it at 5.6 or higher.
Canon EOS 80D
BirdsofBC
" eye candy, pure and simple"
Jun 30, 2012 13:04 as a reply to  @ Closed 123's post |  #14
i've owned 2 17-40's, both soft near the outer edges, but not quite that bad.
https://birdsofbc.com/ (external link)
mrkgoo
Jul 01, 2012 06:54 |  #15
RobinSchouten wrote in post #14653104 (external link)
My issue was mostly the way bokeh looked over at the left. It was kind of unnoticeable most of the time. It only really was apparent if I used it wide open and there were trees or something else with high detail, and slightly out of focus.
I learnt an important lesson with my 17-40 - that IQ isn't everything, particularly pixel-peeping. I frequently use it at F/4.0 these days. So long as the images look fine, I'm not too bothered.
5,538 views & 0 likes for this thread, 11 members have posted to it.
1387 guests, 121 members online
