Ltdave wrote in post #14628962
When I was being raised with film, shooting in manual USUALLY meant selecting a ****ter speed and then adjusting the aperture ring (on the lens) with my support hand...
With my T2i I had to hold a button while spinning the index finger wheel...
My new 7d defaults to the rear thumb wheel for manual aperture settings but I just switched it to the index finger wheel and the shutter speed to the read thumb wheel...
Im just curious if anyone ELSE has their camera set up like this?
Set it up however it feels most comfortable for you. I think you also can reverse the direction of the dials, if you wish. With some practice whatever you choose will become second nature. Right now it just feels a bit odd because you were accustomed to doing something else.
I've not yet used the rear button for focusing with regularity because my thumbs I bit too short to reach comfortably...
Again, it takes some practice to get accustomed to Back Button Focusing, but soon becomes second nature.
But, if you wish, you also can reassign AF to the * button (and AE Lock to the AF On button). That moves it closer so might not be as much of a reach for you. Also, the * button is larger and more prominent.
I do this swap for several reasons. AF is a lot more important to me, is used on every shot... Rather than AE Lock, which is only occasionally used. So I want the closer and more prominent button to activate AF. Also, older cameras (and/or their vertical grips) didn't have the AF On button. With them the only way to do BBF was to use the * button... so I got in the habit of using. Plus I still use some of those cameras so it's helpful to have all my cameras working the same way.
