I want to photograph a painting and achieve accurate colour. How do I do that using a grey card and processing in PS?
markimage Member 225 posts Joined Jul 2007 Location: Hitchin, Herts. UK More info | Jun 27, 2012 01:27 | #1 I want to photograph a painting and achieve accurate colour. How do I do that using a grey card and processing in PS? http://www.markwebb.smugmug.com/
tonylong ...winded More info | Jun 27, 2012 01:41 | #2 If you are shooting jpeg, you need to use a Custom White Balance. Look it up in the index of your camera manual (either "Custom White Balance" or "Custom WB") for specifics on how to set this up. Tony
Jun 27, 2012 01:46 | #3 Thanks Tony. So can I use the painting for the sample in Custom White Balance or should it be a white card? http://www.markwebb.smugmug.com/
tonylong ...winded More info | Jun 27, 2012 02:02 | #4 For a Custom White Balance or using the eydropper with a Raw file, you need a "neutral target", so use the grey card or a good neutral white paper will do as long as you use it with a "Standard" exposure so it comes out "grey", not a blown out white. Part of a painting will likely not be good! Not neutral! Tony
Jun 27, 2012 02:06 | #5 What do you mean by Standard Exposure? http://www.markwebb.smugmug.com/
tonylong ...winded More info | Jun 27, 2012 02:17 | #6 markimage wrote in post #14638065 What do you mean by Standard Exposure? A "standard" exposure means to meter the "target" so that it is exposed to "medium", with the meter needle centered and using no Exposure Compensation. This will expose a White target to be gray. Tony
Jun 27, 2012 02:23 | #7 Fantastic. Thank you very much Tony. http://www.markwebb.smugmug.com/
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Jun 27, 2012 04:04 | #8 Just a brief note to point out that the procedure outlined by Tony is the best you can do if you have only a grey/white card. This will account for any overall color cast caused by the lighting and will nail one color (grey) among the possible millions in an image. A photographer who frequently needs greater color accuracy will carry the process further by photographing a card containing number of color patches whose exact chromacities are known and constructing a profile that describes the difference (delta) in the way the camera renders those colors. As I said, as a rule only someone who needs a high degree of color fidelity in their work will invest the time and expense involved. For the rest of us Canon made generic profiles that are incorporated in their jpeg Picture Styles and in DPP and so did Adobe for their software; profiles that produce acceptably close to reality colors. Elie / אלי
Jun 27, 2012 05:26 | #9 tzalman wrote in post #14638247 A photographer who frequently needs greater color accuracy will carry the process further by photographing a card containing number of color patches whose exact chromacities are known and constructing a profile that describes the difference (delta) in the way the camera renders those colors. X-rite do a selection of products that make this process fairly easy. Their Colochecker Passport Frank Hollis - Retired mass spectroscopist
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Jun 27, 2012 11:38 | #10 tzalman wrote in post #14638247 Just a brief note to point out that the procedure outlined by Tony is the best you can do if you have only a grey/white card. This will account for any overall color cast caused by the lighting and will nail one color (grey) among the possible millions in an image. A photographer who frequently needs greater color accuracy will carry the process further by photographing a card containing number of color patches whose exact chromacities are known and constructing a profile that describes the difference (delta) in the way the camera renders those colors. As I said, as a rule only someone who needs a high degree of color fidelity in their work will invest the time and expense involved. For the rest of us Canon made generic profiles that are incorporated in their jpeg Picture Styles and in DPP and so did Adobe for their software; profiles that produce acceptably close to reality colors. ^^^
--ALL of them have same WB value! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Jun 27, 2012 13:39 | #11 Thanks all. I usually use Picture Style - Faithful, would this be the best choice for this subject? http://www.markwebb.smugmug.com/
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Jun 27, 2012 16:03 | #12 Either faithful or neutral I'd say. "I think the idea of art kills creativity" - Douglas Adams
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jun 27, 2012 18:00 | #13 This book will help you out a lot - Light, Science and Magic Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
| Latest registered member is MWCarlsson 938 guests, 183 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
