Thread started 28 Jun 2012 (Thursday) 12:16
Turn on high speed sync?
uneek78
Joined Nov 2011
Jun 28, 2012 12:16 |  #1
Anyone know how to turn on high speed sync on a canon 580 speedlite? I noticed that as an off-camera flash the output of the flash is much lower than when on the camera. I was advised to turn on high speed sync. Please advise if you think I should be trying something else.
Gerard Payne | www.gerardpayne.com (external link)
Canon Rebel T1i | Canon 50mm f/1.4 | Canon 24-105L |Canon 55-250mm f/4-5.6
bobbyz
Jun 28, 2012 12:23 |  #2
How are you using your 580 of camera, it manual mode or eTTL? HSS mode irrespective of on camera or off camera will lower output power.
5dmk3, 35L, 85L II, 300mm f2.8 IS I, 400mm f5.6
Fuji XT-1, 14mm f2.8, 23mm f1.4, 35mm f1.4, 56mm f1.2, 90mm f2, 50-140mm f2.8
uneek78
Joined Nov 2011
Jun 28, 2012 12:26 |  #3
bobbyz wrote in post #14644469 (external link)
ETTL.
uneek78
Joined Nov 2011
Jun 28, 2012 12:27 |  #4
What can I do to remedy this issue?
gonzogolf
dumb remark memorialized
Gallery: 40 photos
Jun 28, 2012 12:28 |  #5
What triggering method are you using? What gear?
uneek78
Joined Nov 2011
Jun 28, 2012 12:30 |  #6
gonzogolf wrote in post #14644491 (external link)
Canon Speedlite Transmitter ST-E2
bobbyz
Jun 28, 2012 12:31 |  #7
Use FEC (on camera or on the flash) to change power.
uneek78
Joined Nov 2011
Jun 28, 2012 12:33 |  #8
bobbyz wrote in post #14644501 (external link)
This is an option in the menus on the camera and is also on the flash trigger? Is it more of a benefit to turn it on one than the other?
gonzogolf
Gallery: 40 photos
Jun 28, 2012 12:33 |  #9
This. In ETTL mode the output is automatic. HSS would only kick in when you set your shutter speed above max, below it doesnt matter if its turned on or not so thats not your problem. Dial in the amount of compensation you need.
uneek78
Joined Nov 2011
Jun 28, 2012 12:47 |  #10
gonzogolf wrote in post #14644514 (external link)
Okay, so they're currently in slave mode to be controlled by the canon wireless transmitter. Are you saying I can manipulate the output in slave mode? Or do I need to change to something totally different? The manuals don't do a great job of explaining this stuff. UGH!!!!!
uneek78
Joined Nov 2011
Jun 28, 2012 12:48 |  #11
I am use to manipulating the output when it's on the camera.
gonzogolf
Gallery: 40 photos
Jun 28, 2012 13:48 |  #12
uneek78 wrote in post #14644569 (external link)
In ettl mode its pretty much as if they were on camera, assuming you dont have anything set to manual or are using the st-e2 groups function improperly.
gonzogolf
Gallery: 40 photos
Jun 28, 2012 13:49 |  #13
If you set FEC on the flash it will override the camera setting in camera.
drvnbysound
Jun 28, 2012 15:01 |  #14
Just trying to clarify... I believe that if the flash is not already set in HSS mode, the camera will automatically default to your sync speed if you were to try and choose a faster shutter. That said, you can leave your flash in HSS mode at all times, and it will automatically utilize HSS if you set your shutter speed faster than the sync speed.
I use manual exposure settings on the copy machine
..::Gear Listing::.. --==Feedback==--
...A few umbrella brackets I own...
JohnThomas
Joined May 2012
Jun 28, 2012 15:42 |  #15
Let me try and help explain with simple english..
What everyone is trying to tell you is that even though you are physically using your flash(es) off-camera, using the ST-E2 to trigger them in ETTL mode makes them operate exactly the same way as if they WERE physically mounted to your camera. In other words, however you're used to adjusting flash exposure, do the same thing. With ETTL, you would use FEC, or flash exposure compensation (on camera).
I have a feeling you think flash exposure decreased because you have the flash(es) setup to your side, and you're used to lighting subjects head-on. That's just my guess.. I apologize if I'm wrong.
You can call me JT
jsantiniphotography.co​m
3,112 views & 0 likes for this thread
Latest registered member is mrbarnard
1033 guests, 403 members online
