I have heard the rebel has a option to turn on a red filter. Use is for single well lit subject. Filter gives shadow look of subject in sunset. Does anyone know how to find it in the menus?
tennman28147 Hatchling 3 posts Joined Jun 2012 More info | Jun 28, 2012 19:14 | #1 I have heard the rebel has a option to turn on a red filter. Use is for single well lit subject. Filter gives shadow look of subject in sunset. Does anyone know how to find it in the menus?
Sirrith Cream of the Crop More info | Jun 28, 2012 20:42 | #2 I've never heard of this. Perhaps you mean one of the picture styles? -Tom
Jim_T Goldmember 3,312 posts Likes: 115 Joined Nov 2003 Location: Woodlands, MB, Canada More info | Jun 28, 2012 21:33 | #3 Without knowing which Rebel you're asking about it's hard to say..
JohnfromPA Cream of the Crop 11,262 posts Likes: 1530 Joined May 2003 Location: Southeast Pennsylvania More info | Jun 28, 2012 22:27 | #4 Much like Jim_T said. Attached is the section on how to do it on a 60D. Probably very similar on a Rebel, likely even titled the same in your manual.
melanopsin Senior Member 278 posts Joined Aug 2010 More info | For Rebel XT (350D) instructions for red filter use in B&W mode are on pp. 64-66.
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Jun 29, 2012 00:41 | #6 I'm not sure that's what the OP is looking for... Alan Myers
sandpiper Cream of the Crop More info | Personally, I wouldn't want to use an effect or colour filter in camera, or shoot in mono. The results can easily be duplicated during post processing, but with far greater control. If you whack in a red filter when you take the shot, then you are stuck with it. If it is too strong, and you have committed it to jpeg, it's too late. If you decide you want to try a different effect later, it's too late.
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Jun 29, 2012 04:26 | #8 tennman28147 wrote in post #14646117 I have heard the rebel has a option to turn on a red filter. Use is for single well lit subject. Filter gives shadow look of subject in sunset. Does anyone know how to find it in the menus? Set WB to 7500 - 8000K by going to the menu section for White Balance / Temperature. Elie / אלי
JohnfromPA Cream of the Crop 11,262 posts Likes: 1530 Joined May 2003 Location: Southeast Pennsylvania More info | Jun 29, 2012 06:52 | #9 If what you want is an enhancement to a sunset, as amfoto1 points out, then I don't think the Rebel has anything "internal" that will yield what you want. It is generally not recommended to use color correction or enhancing filters on digital cameras. The White Balance - set either in-camera or in post-processing - is far more effective and does not degrade the image with distortions or flare/glare/reflections from additional glass surfaces. "Physical" filters also cause a lot of light loss (as much as two stops) as well.
TeamSpeed 01010100 01010011 More info | Jun 29, 2012 07:23 | #10 Depending on your model, you may have the ability to white balance bracket. Nobody ever really talks about it, but you can go into a grid view under the options and set up a bracket of 3 different points that will create 3 different white balanced images. When you shoot an scene, you will end up with 3 images, one for each point in your white balance bracket. This is hardly ever used from what I can tell, most either shoot a custom white balance beforehand, or set it in raw later. Past Equipment | My Personal Gallery
melanopsin Senior Member 278 posts Joined Aug 2010 More info | Colored filters have use on digital cameras.
JohnfromPA Cream of the Crop 11,262 posts Likes: 1530 Joined May 2003 Location: Southeast Pennsylvania More info | Jun 29, 2012 12:52 | #12 melanopsin wrote in post #14649198 Colored filters have use on digital cameras. The problem is if "auto" white balance is on, the effect of a colored filter is pretty much reversed anyway. A surprisingly large number of people use AWB, inlarge parts because it works well in the Canon line.
melanopsin Senior Member 278 posts Joined Aug 2010 More info | Jun 29, 2012 13:06 | #13 John from PA wrote in post #14649236 The problem is if "auto" white balance is on, the effect of a colored filter is pretty much reversed anyway. A surprisingly large number of people use AWB, inlarge parts because it works well in the Canon line. I use Auto WB too, however, in-camera, the WB gets applied to the raw data, which includes the effects of the filter. A proper white balance gets applied in PP, retaining the filter effects as captured in the raw exposure through the lens with the filter.
| Latest registered member was a spammer, and banned as such! 2767 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
