It seems I get white spots quite frequently with my omnibounce, is this common?
Dec 13, 2005 13:32 | #1 It seems I get white spots quite frequently with my omnibounce, is this common? Joe
Homer Member 93 posts Joined Mar 2005 Location: Mississauga, Ontario More info | Dec 13, 2005 21:15 | #2 I had the same thing happen to me on occasion with my G3, 420EX and omni-bounce. I was never able to figure out a pattern to when or why it happened...
BottomBracket Cream of the Crop 6,398 posts Likes: 1 Joined Dec 2004 Location: NYC More info | Dec 13, 2005 21:18 | #3 Perhaps it would be better if you could post a pic so we can see how we can help. Pio
jeffreyr Junior Member 24 posts Joined Aug 2005 More info | Dec 14, 2005 10:22 | #4 I've had the same thing happen to me with the G6, 420EX and omnibounce. Little hexagonal (or something like that) spots in my pictures. I don't know the cause and I haven't figured out a pattern.
rpolitsr Cream of the Crop More info | Dec 14, 2005 13:43 | #5 Dust floating in the air near the lens and lighted by the flash can produce out of focus white spots, perhaps dust in the lens surface may also produce spots, but I think that some dust in the omnibounce surface will not affect your picture. rafael
rpolitsr Cream of the Crop More info | Dec 14, 2005 20:43 | #7 Not the kind of white spots I was thinking of. rafael
BottomBracket Cream of the Crop 6,398 posts Likes: 1 Joined Dec 2004 Location: NYC More info | Dec 14, 2005 20:46 | #8 I really can't see it. Can you enlarge the pic? Pio
BottomBracket wrote: I really can't see it. Can you enlarge the pic? you can see one spot in the upper right hand corner, just left of the chair Joe
I just did a test, it seems if I shoot straight on with the Omnibounce on and an overhead light I get the spots for sure. Joe
lostdoggy King Duffus 4,787 posts Joined Aug 2004 Location: Queens, NY More info | Dec 14, 2005 21:50 | #12 Hexagonal shape is form from the aperature. If you look in front of your lens there might be an small oil or water spot. Something translucent. Very small.
sharksbite Member 137 posts Joined Dec 2005 Location: surprise! arizona More info | Dec 14, 2005 22:16 | #13 maybe its just some dirt on the lens?? that'd be the first thing i'd check. pro1 has an L lens :: photoblog : http://sharks.devgirl.ca/
BottomBracket Cream of the Crop 6,398 posts Likes: 1 Joined Dec 2004 Location: NYC More info | Dec 14, 2005 23:08 | #14 Hmmm. It does seem to move. I'm puzzled to what it could be. It is more prominent in the second pic, where you can see one near the picture frame and another on the blue shirt. Are you using the lens adapter, and if so, do you have a filter on it? Be sure it is clean on the inside and outside. Pio
BottomBracket wrote: Hmmm. It does seem to move. I'm puzzled to what it could be. It is more prominent in the second pic, where you can see one near the picture frame and another on the blue shirt. Are you using the lens adapter, and if so, do you have a filter on it? Be sure it is clean on the inside and outside. Lens adapter is on. I will check the lens for dust. The problem seems to be lens flare from the hexagon shape of the spot. It only seems to happen when the omnibounce is on and pointed straight on instead of "bounced" at 45 degree angle and there is another light source in the room, usually overhead. Joe
| Latest registered member was a spammer, and banned as such! 2177 guests, 129 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
