Thread started 01 Jul 2012 (Sunday) 16:01
Which lenses?
chloeP
Joined Jun 2012
Jul 01, 2012 16:01 |  #1
I have the 500D which came with 2 lenses, the Canon EF-S 18-55mm f/3.5-5.6
and the 75-300mm - F/4.0-5.6.
I want to do on-location type photography with children. I have found that the 75-300mm lens is quite good for dof but I have to stand too far back for some of the shots i'd like to do.
The 18-55mm isn't very good for dof unless they are stood a long way away from their background.
I need a lens which is really good for dof but one where I don't have to stand miles away!
An in between lens I guess.
Examples of shots I have taken with the 75-300mm lens, i'd like to still be able to achieve the same sort of shots:
IMAGE: http://farm8.staticflickr.com/7077/7297950924_4157e84494.jpg
IMAGE: http://farm9.staticflickr.com/8162/7462765602_eeda840f96.jpg
My Flickr (external link)
Facebook (external link)
kin2son
Joined May 2011
Jul 01, 2012 16:14 |  #2
At what focal length were those taken?
Basically you want a lens with faster aperture to compensate the shorter shooting distance yet retaining the creamy oof area (that's what I think you meant).
Some suggestion - 50 1.4, 85 1.8, 100 2, 70-200f2.8.
5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
EOS M / EF-M 18-55 / EF-M 22f2 / Ricoh GR aka Ultimate street camera :p
Flickr (external link) | My Images on Getty®‎ (external link)
paddler4
Jul 01, 2012 16:33 |  #3
Both are very nice shots.
Perhaps a Tamron 17-50 f/2.8 non-VC. Relatively inexpensive, optically excellent, and much faster than the kit lens. I use its longer cousin (28-75) for that purpose, but the 17-50 would give you a full replacement of our kit lens.
Check out my photos at http://dkoretz.smugmug​.com (external link)
casaaviocar
Jul 01, 2012 16:36 |  #4
Yes larger aperture = better bokeh. The suggestions above are good ones.
Rule books are paper they will not cushion a sudden meeting of stone and metal -ekg-
jimewall
Jul 01, 2012 17:29 as a reply to  @ casaaviocar's post |  #5
What Kin2son suggested.
Thanks for Reading & Good Luck - Jim
GEAR
sol95
Jul 01, 2012 18:07 |  #6
casaaviocar wrote in post #14657369 (external link)
Incorrect
faster aperture = smaller depth of field = more out of focus
bokeh is the QUALITY of the out of focus area, not the amount
TO THE OP
any of the 17-5x/2.8 lenses will be better for subject separation than the 18-55 kit lens
and while we don't know what price range is ok for you, any of these will be great: 50/1.8; 50/1.4; 85/1.8
Bodies: 5D mk III
Lenses: 50 f/1.2L | 85 f/1.2L II | 100 f/2.8L IS Macro | 17-40 f/4.0L | 24-70 f/2.8L II | 70-200 f/2.8L IS II
Accessories: 430EX II | TC-80N3 M43: Olympus E-PM1 | Olympus m.Zuiko 14-42 II R | Panasonic 14 f/2.5 | Panasonic 20 f/1.8 | Olympus m.Zuiko 45 f/1.8
casaaviocar
Jul 01, 2012 21:09 |  #7
sol95 wrote in post #14657679 (external link)
Incorrect
Web definitions:
In photography, bokeh is the blur, or the aesthetic quality of the blur, in out-of-focus areas of an image, or "the way the lens...
en.wikipedia.org/wiki/​Bokeh
More info*»Source - Wikipedia - Dictionary.com
The word Bokeh comes from the Japanese word Boke (pronounced bo-keh) which literally means fuzziness, blur, or haze. This word can also be applied to a mental haze or senility.
Boke-aji is closer, meaning blur quality.
So wider aperture = more fuzziness or blur (there is no such thing as faster aperture if you're gonna get technical, faster is a function of SS)
tempest68
Jul 01, 2012 21:23 |  #8
Sigma 50-150mm f2.8 or Tokina 50-135mm f2.8 if you want a zoom that's wider than your 75-300 but still has some decent telephoto length.
Jim
Canon: EOS 3, 40mm f2.8 STM, 85mm f1.8 USM. Voigtlander: R3A, 28mm F2.8 SL II, Nokton 40mm f1.4, 50mm f2 Heliar.
Nikon: SB-25. Yongnuo: YN565EX, YN-622C transceiver (x2)
Sony: A7S, a6000, 24-240mm f3.5-6.3 G, Nissin i40.
sol95
Jul 01, 2012 21:53 |  #9
casaaviocar wrote in post #14658326 (external link)
Web definitions:
you're proving my point and disproving yours. the bokeh is, from your quoted definition, the aesthetic quality of the blur, or the blur in out-of-focus areas. since the fact that something is out-of-focus is already accepted, the term "blur" is referring to the qualitative measure, not the quantitative measure
if you want to see what it looks like, check out comparisons between 50/1.8 - 50/1.4 - 50/1.2 all at f1.8. The quality of the blur (which is the bokeh) differs significantly between the three lenses. the 50/1.8 is harsher than the 50/1.4. But best of all is the 50/1.2 which renders a smooth and creamy BOKEH in the out of focus areas.
wider aperture creates more blur, but doesn't necessarily mean you get good bokeh, which was your initial incorrect statement
Bodies: 5D mk III
casaaviocar
Jul 01, 2012 23:12 |  #10
Selective reading or failure to understand English? You're skipping the most important word in that definition...OR. Bokeh is the blur....OR....the aesthetic quality of the blur.
Or. conjunction Used to indicate an alternative. This or that, blur or asthetic quality of blur.
Japanese again: fuzziness, blur, or haze.
FEChariot
Gallery: 13 photos
Joined Sep 2011
Jul 01, 2012 23:28 |  #11
Those are nice shots. I have a lot of simular stuff with my 85/1.8. That can really blur the background without it having to be in the next yard over. Also the 30/1.4 can do a good job if you need something in the 18-55 range but obviously not as good as longer focal length lenses. A 50/1.4 would be good too in between those.
Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Jul 01, 2012 23:32 |  #12
Can we not descend into squabbling semantics every time the word Bokeh is used? The OP wants a fast lens to retain shallow depth of field while allowing for a shorter working distance. Essentially, she wants a lens that is shorter, but faster. Simple. No need to argue and get off topic.
Cloe, I would personally recommend an 85mm lens. The Canon 1.8 is an excellent lens for the money, the Samyang/Rokinon is highly respected but is fully manual, and the Sigma isn't too shabby either. ;)
500px (external link)
1x (external link)
instagram (external link)
sol95
Jul 01, 2012 23:34 |  #13
Firstly, sorry to the OP for digressing here. But incorrect information should be corrected.
casaaviocar wrote in post #14658761 (external link)
Again, you're proving my point and disproving yours. The structure of that sentence isn't presenting the the concept of "blur" as an option to "aesthetic quality of the blur". The word "or" is functioning as additional information to what is meant by "blur". It seems here that your rudimentary understanding of English is failing to grasp how clauses work in English. The placement of the commas shows that the flow of the sentence is essentially "bokeh is the blur in out-of-focus areas of an image", and the clause "or the aesthetic quality of the blur" is giving additional clarification to that point.
This is borne out by the next sentence in your referenced wiki article. "Bokeh has been defined as 'the way the lens renders out-of-focus points of light'." Read it properly - the WAY the lens renders, not the AMOUNT the lens renders.
At the end of the day cassaaviocar, if you don't know what you're talking about, it's best to stay quiet and learn. It doesn't help the situation either if you accuse others of problems (selective reading, or lack of English) which is clearly the problem that you yourself have.
Anyways, I've said my piece and won't respond any further to misinformed comments. :)
Bodies: 5D mk III
sol95
Jul 01, 2012 23:36 |  #14
Again, my apologies to chloeP for being part of the off-topic rant :o
but as I put in my original post...
Bodies: 5D mk III
xarqi
Jul 02, 2012 06:31 |  #15
Moving right along.
Yup - look hard at the 50/1.8 (or if you like the 50 mm focal length, the 1.4 or the Sigma alternative), or the 85/1.8 or 100/2.
3,325 views & 0 likes for this thread, 11 members have posted to it.
Which lenses?
2636 guests, 155 members online
