Thread started 01 Jul 2012 (Sunday) 20:02
Best on-camera speedlite diffuser?
uneek78
Joined Nov 2011
Jul 01, 2012 20:02 |  #1
I currently use a Gary Fong and it works well most of the time, but I'm curious if there is something better that diffuses the flash on my canon 580 speedlite. Sometimes I noticed that when you have seriously uneven ceilings (fancy ballrooms and such have trey ceilings) I notice that the light that bounces off the ceiling won't reach your subject(s) if they're not under the same level ceiling. Which is something I don't want to be concerned about when I'm taking photos. I've seen a lot of photographers with Soft Box Flash Diffusers (external link). Are these much better? Would you highly recommend these or something else? I found myself in a situation like that several times this weekend and I would have to move the subjects into the same level ceiling I was under, because the Gary Fong relied heavily off the ceiling bounce flash evidently. Normally after I resituated the subjects under the same level ceiling as myself the picture was perfect. Please advise!
Gerard Payne | www.gerardpayne.com (external link)
Canon Rebel T1i | Canon 50mm f/1.4 | Canon 24-105L |Canon 55-250mm f/4-5.6
tim
Light Bringer
Jul 01, 2012 20:23 |  #2
The Fong Dong throws light everywhere, and leave some going direct. It's similar to an Omnibounce, though less efficient. A soft box has most of the light going direct, and they're so small they don't really do that much.
Really what seems to be missing is your understanding of light. You seem to want a one size fits all solution, when really you need to understand light and how to control it better.
I rarely use on camera light as my main light at events, I use off camera lights - tutorial here. I have most of the flash diffusers that were available from when I was new, but now I understand light a lot better I don't use any on camera diffuser.
uneek78
Joined Nov 2011
Jul 02, 2012 07:33 |  #3
tim wrote in post #14658149 (external link)
I actually realize I have read your article before. And it does work great; I know a friend that has done it. I actually mount my speedlites on stands with umbrellas when it is time for posed pictures. Unfortunately, this does not prove itself to be convenient when the venue spreads between several rooms; which was my situation this weekend. It was in skyscraper in which the venue quickly changed rooms throughout one floor. Unfortunately, the luxury of moving stands and such was not afforded for this specific situation. Yet, it is a great idea assuming the whole venue is to be in one centralized area.
My question was geared for something when you have to constantly move from room-to-room. What is something I can put in my speedlite that will not cause the limitations I saw this weekend. The gary fong is great but per articles I read it does also rely on the bounce of the ceiling. I probably can use a little more understanding of the gary fong, but when I bought it at the photography store the clerk only showed me one way to use it. I am now looking online and seeing there are more ways. I will start working on these ways immediately.
dmward
Gallery: 29 photos
Jul 02, 2012 08:36 |  #4
Gerard,
If you are using flash in a room where it has to be the primary light source, then you have to accept that its going to be a flash picture. In that case, get the speedlite above the lens and high enough minimize skin hotspots. In these situations I tend to use a large foamie deflector. Similar to the the one described on http://super.nova.org/​DPR/DIY01/ (external link).
Most of the time I bounce the speedlite using a small foamie to keep the light from going directly toward the subject. Most often I have one or two speedlites on light stands working with the on camera flash.
http://www.dmwfotos.co​m/galleries/weddingpor​tfolio/ (external link) is my wedding gallery. Every image there has a speedlite component. Most are bounced, several have both on camera and off. The outside shots use the speedlite for fill.
As Tim suggests, spend time learning how to "read the light" and augment it with your speedlite.
Looking at your equipment list, it appears that your camera and lens combinations make higher ISO shots with flash augmentation more challenging.
uneek78
Joined Nov 2011
Jul 02, 2012 08:45 |  #5
dmward wrote in post #14659829 (external link)
Gerard,
Good info! I will take all this mind. Thanks for the knowledge. And you're definitely correct about the "more challenging" part. I can't quite afford a Mark 5D II at the moment even though I hear they help really well with higher ISO in low light situations. I was leaning more toward the 60D since it will be more achievable for the near future.
Here are some of the shots I took this weekend:
uneek78
Joined Nov 2011
Jul 02, 2012 10:46 |  #6
Hey Tim, I'm loving your article more and more now. Can you tell me where you place your stands when taking group posed shots at after the ceremony? Distance? Height of stand? I use umbrellas at the moment.
I notice for the reception you leave the speedlite unhindered by any type of diffuser. I guess at the distance they are from the subjects....that is okay, right?
uneek78
Joined Nov 2011
Jul 02, 2012 10:47 |  #7
Also, just curious and not trying to be annoying. Why do you have 3 websites?
uneek78
Joined Nov 2011
Jul 02, 2012 11:00 |  #8
Okay, it's just 2 website I see now. You have 3 links for your signature and I was checking them out. Nice work!
tim
Light Bringer
Jul 02, 2012 16:42 as a reply to  @ uneek78's post |  #9
uneek78 wrote in post #14660367 (external link)
SEO :)
uneek78 wrote in post #14660359 (external link)
I typically don't light posed group shots. Here in NZ they're done outdoors, and I don't use flash as it only lights the front row.
I did do church formals one horribly wet day this summer. I used one AlienBee strobe with a shoot thru umbrella up pretty high, directly above me. I had one 550EX on a small stand at 1/4 power or so lighting the background. No photos online unfortunately.
uneek78 wrote in post #14659672 (external link)
High iso, bare flash pointed at the ceiling, and I use the built in white bounce card.
MDEphoto
Joined Jul 2011
Jul 02, 2012 22:00 |  #10
I've had good luck using the Rogue FlashBender.
http://www.expoimaging​.com …p?cat_id=13&pro​duct_id=21 (external link)
If you go with the FlashBender, don't forget to get a diffusion panel - works really well and softens the light
http://www.expoimaging​.com …ds=Rogue_Diffus​ion_Panels (external link)
Gear List and Feedback
windpig
Chopped liver
Gallery: 6 photos
Jul 02, 2012 22:07 |  #11
Uh oh, here we go again.
Go ahead, spin the wheel.
Green ­ Li
Gallery: 15 photos
Jul 03, 2012 21:45 |  #12
have you tried googling best flash diffuser? :)
PHOTO-TIPS-ONLINE.com – photo tips, photography reviews (external link)
Facebook (external link) | Twitter (external link) | Google (external link)+
tim
Light Bringer
Jul 03, 2012 22:40 |  #13
Green Li wrote in post #14667729 (external link)
Then you'll just find the company with the best SEO.
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Jul 04, 2012 08:53 |  #14
I have a set of better bounce cards and the Lumiquest set. I really like both, but the Better Bounce cards get the most use.
Doc Klepper in the USA
I
airfrogusmc
Gallery: 147 photos
Jul 04, 2012 09:31 as a reply to  @ rklepper's post |  #15
I tried just about everything and was't happy so I made one.
IMAGE: http://i4.photobucket.com/albums/y118/airfrogusmc/Cameras/IMG_9344.jpg
And I use a modified sto-fen. The tape keeps light from coming trough the sto-fen forward thus reduces the hot spots that I was getting before I blocked the light. I usually meter the ambient and set my strobe for one stop lower. I have the same set up for my Metz 58 and my 580. I use a Nikon gel pack for the Metz (fits perfect) so I gel for the ambient and I have a strobist pack for the 580. Note the velcro to hold the pure white art board.
IMAGE: http://i4.photobucket.com/albums/y118/airfrogusmc/Cameras/IMG_4438.jpg
IMAGE: http://i4.photobucket.com/albums/y118/airfrogusmc/Cameras/IMG_4437.jpg
IMAGE: http://i4.photobucket.com/albums/y118/airfrogusmc/Cameras/IMG_4436.jpg
IMAGE: http://i4.photobucket.com/albums/y118/airfrogusmc/Cameras/IMG_4435.jpg
Nikon gel pack
IMAGE: http://i4.photobucket.com/albums/y118/airfrogusmc/Cameras/IMG_4441.jpg
IMAGE: http://i4.photobucket.com/albums/y118/airfrogusmc/Cameras/IMG_4442.jpg
IMAGE: http://i4.photobucket.com/albums/y118/airfrogusmc/Cameras/IMG_4443.jpg
16,812 views & 0 likes for this thread
Latest registered member is EgonSpengler_89
1935 guests, 321 members online
