Thread started 02 Jul 2012 (Monday) 10:07
IS on a tripod if... .
Gaarryy
Jul 02, 2012 10:07 |  #1
I'm going to be shooting fireworks from a boat? pretty calm lake, but still it's a boat. I was going to attempt to use bulb or longer shutter speeds, but I know the boat will be moving some. While I realize that you shouldnt' use IS when on a tripod I was wondering if it being on would help with the movement of the boat some??
thoughts?
---------------Camera, Lens, Flash stuff.. but still wanting more
mwsilver
Gallery: 54 photos
Joined Oct 2011
Jul 02, 2012 10:49 |  #2
Gaarryy wrote in post #14660231 (external link)
thoughts?
That's an interesting thought. If there is movement, I suspect the lens will "think" its being hand held and the IS will help rather than hurt. But if there is any movement I'm guessing the results won't be pin sharp with long shutter speeds even with mirror lockup and and a remote shutter release.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
amfoto1
Jul 02, 2012 10:58 |  #3
I'm assuming you mean using your 70-200, since that's the only lens you list with IS...
Most definitely leave IS on to counteract the movement of the boat, vibration from the motor, any shake caused by other people moving around in the boat, etc.
... I realize that you shouldnt' use IS when on a tripod...
Actually, you are incorrect... if that's the lens you are planning to use. There is no need to ever turn off IS on any Canon 70-200, when the lens is mounted on a tripod. All versions of 70-200 with the feature, it is not one of the lenses where that's necessary. The IS in the 70-200s self-detects if there's no movement and turns off IS itself.
Gaarryy
Jul 02, 2012 11:20 |  #4
amfoto1 wrote in post #14660417 (external link)
I really need to update my lens, I was going to use the my sigma 17-55 or my kit lens 28?-135 ish? can't remember actually.
I might just attempt a few handheld around a 1/20th sec or so also
hollis_f
Jul 03, 2012 05:11 |  #5
IS will help with vibration from the motors, or from people walking about on deck. But it will do nothing to counteract the gentle rocking of the boat.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
magwai
Jul 03, 2012 05:56 |  #6
The problem with using IS on a tripod is that the vibration caused by the IS itself can move the tripod. The IS system is not good at dealing with this self-induced feedback.
I was trying to get a shot on a wooden deck using the 300L f4 IS and a 2x teleconverter and I could not seem to get rid of camera wobble. I was using a remote and had the shutter locked up etc etc. Eventually realised I had left the IS on and bingo - steady exposures.
This was on a deck that would wobble noticeably if you walked on it so not the firmest of platforms for a tripod, but might be similar to a boat deck so I thought it was worth mentioning.
Lowner
"I'm the original idiot"
Jul 03, 2012 07:00 |  #7
hollis_f wrote in post #14664024 (external link)
Agreed. The frequency of the oscillations is too low for IS. Sorry, I come from a career in Electrical Engineering!
Richard
Keyan
Joined Mar 2011
Jul 03, 2012 07:17 |  #8
Yeah, the IS is designed to only counteract very small rapid movements from vibration or just our bodies, the movement of the boat won't be corrected by IS at all, the boat moves inches on the water and there is no way for the optical elements to correct that much. Good luck!
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
Gaarryy
Jul 03, 2012 08:56 |  #9
Thanks for all the great replies !!!
John ­ from ­ PA
Joined May 2003
Jul 03, 2012 09:46 |  #10
A tripod on a boat might be quite a disadvantage. Let's just say (to simplify the math) that the base of the tripod legs forms a 30 inch diameter circle and the lens is 60 inches from the tripod mounting surface. If 1/8 inch motion occurs at the tripod feet, that could translate to 1/4 inch motion at the lens. Again, I've simplified the math but this scenario is entirely possible and even likely.
Handheld, one thing will help especially if the boat is rolling (side to side motion) and that is to position yourself as near the center (side to side) of the boat. If the boat is pitching (a front to bak motion) then you'll have to judge the point from stem to stern (front to back) that has the least motion. It may or may not be near the center of the ship, as measured from front to back.
AJSJones
Gallery: 6 photos
Joined Dec 2001
Jul 03, 2012 10:01 |  #11
Steadycam. :). (Steadyboat, too!).
Early versions of the IS system should be turned off if the lens is stationary (like on a tripod) - all the more recent IS versions detect a stationary condition and deactive it themselves - so for those lenses, you never actually need to turn it off. I can't find the link to list of lenses in the older category, perhaps someone else can.
My picture galleries (external link)
Delija
Jul 03, 2012 10:33 |  #12
Says all that needs to be said.
Enjoy the fireworks - leave the tripod at home and avoid the frustration. You may be able to get some photos of friends on the boat (using flash) and get lucky with the fireworks in the background, but shooting with long exposures would be nothing but an excessive in futility.
BTW, if you are on a "calm lake" chances are that the boat would be on the smaller side - standing to man a camera on a tripod would make you and your camera raise the center of gravity and make any rocking more pronounced. (ever try standing up in a canoe?).
Wow, what a nice picture! You must have a really great camera!
2,214 views & 0 likes for this thread, 10 members have posted to it.
1457 guests, 137 members online
