Thread started 02 Jul 2012 (Monday) 14:29
Difficulty with focus in portrait orientation.
Lonestarlady61
Location: Montana for over 13 years but I'm originally from Houston, Texas.
Jul 02, 2012 14:29 |  #1
I've improved quite a bit with my focus in landscape orientation but I'm still having problems with portrait orientation. Any ideas why?
IMAGE: http://farm8.staticflickr.com/7271/7488936246_a9bf60fa79_b.jpg
Canon 60D since Dec. 2011, Canon 28-135mm lens, Canon 70-300mm USM lens and Nifty Fifty 50mm 1.8 lens. Just got in a new lens: Tamron 18-270mm ; )
martini
Jul 02, 2012 14:30 |  #2
Personally, I don't see anything wrong.
- martini
Ramon-uk
Gallery: 61 photos
Jul 02, 2012 15:09 as a reply to  @ martini's post |  #3
I presume you are talking about the far distance being off focus.
If you let your camera choose the focus point then it will pick the closest thing it finds ( the grass in the front). In this case you should have manually selected a focus point and focussed about a third of the way into the shot, probably about where the rocks are on the right hand side then with a small aperture you will have got it sharp from the foreground to the distance.
This applies to both landscape and portrait orientation so I don't see why you should struggle with either once you have mastered it.
Flo
Gimmie Some Lovin
Jul 02, 2012 15:36 as a reply to  @ Ramon-uk's post |  #4
As to the orientation, I might lean towards the landscape version, only because I like seeing the lines of the mountains in the distant, the rock on the foreground doesn't seem to be a "star" of the photo, but in portrait , it does take center view....do you have the original without crop?
gonzogolf
dumb remark memorialized
Gallery: 512 photos
Jul 02, 2012 15:41 |  #5
Ramon-uk wrote in post #14661499 (external link)
IIf you let your camera choose the focus point then it will pick the closest thing it finds ( the grass in the front). In this case you should have manually selected a focus point and focussed about a third of the way into the shot, probably about where the rocks are on the right hand side then with a small aperture you will have got it sharp from the foreground to the distance.
/\ This. In horizontal orientation you have more of the scene hitting focus points. In portrait (as framed) you have a dominant subject close so the camera will lock on that.
Flo
Gimmie Some Lovin
Jul 02, 2012 15:46 |  #6
gonzogolf wrote in post #14661653 (external link)
^ agreed
Lonestarlady61
Jul 03, 2012 09:08 |  #7
martini wrote in post #14661334 (external link)
Thanks for your feedback Martini.
Thanks so much for your input Ramon. I use manual settings and manual focus in all my landscape photos. I also use the LCD screen, that way I can use the grid to find something 1/3 up from the bottom of the frame. It was very windy when I took this photo and that might have contributed to the out of focus distant landscape.
Flo wrote in post #14661629 (external link)
Hello Flo, this is the original version. No crop was done at all to this particular photo. I did take quite a few landscape orientation shots but decided to experiment with using theses grasses and rocks for foreground interest.
Thanks Gonzogolf. I used manual settings, manual focus and tried to focus 1/3 up from the bottom. I must have missed my focus point by a little bit and I'll keep practicing till I get it right.
gonzogolf
Gallery: 512 photos
Jul 03, 2012 09:47 |  #8
Lonestarlady61 wrote in post #14664694 (external link)
I'm not a big fan of manual focus using the modern DLSR. They really arent built well for the purpose. I started my photo career well before autofocus so its not that I dont love manual focus, but the viewfinders are poorly designed for the purpose.
Titus213
Jul 03, 2012 12:06 |  #9
Landscapes shot in portrait mode give a feeling of confining space. Landscape orientation opens that up and makes for a more pleasing shot IMO.
So the solution for me is don't shoot landscapes in portrait mode unless you have a specific subject you are trying to compose for.
Dave
Perspiring photographer.
Lonestarlady61
Jul 03, 2012 13:10 |  #10
Titus213 wrote in post #14665508 (external link)
I know exactly what you mean Titus and I feel the same way but a few people have encouraged me to try it out so I did. You might prefer an image like this one:
IMAGE: http://farm8.staticflickr.com/7267/7488938462_6249d9eb58_b.jpg
Lonestarlady61
Jul 03, 2012 13:11 |  #11
gonzogolf wrote in post #14664884 (external link)
Thanks so much for your comment Gonzogolf and I do know what you mean but the method I'm using seems to work for me 90% of the time anyway.
AE_Photography
Joined Nov 2011
Jul 04, 2012 00:34 |  #12
You could also try a higher aperture to have more DOF as well. I don't see the camera settings, so I do not know what you shot at, but obviously the higher you go up, the more focused background you will achieve.
Andrew Johnson / Owner
https://www.facebook.c​om …w-Johnson/33615570653492​9 (external link)
Camera Bodies:Canon MKIII 1D / Canon 6D
Lenses: 50mm 1.8 / 24-105mm F4 / 70-200mm 2.8 IS L
Titus213
Jul 04, 2012 09:50 |  #13
Lonestarlady61 wrote in post #14665790 (external link)
Now stitch an image on each side of that and you have a great landscape.:D
Dave
3,087 views & 0 likes for this thread, 7 members have posted to it.
Latest registered member is Bella toye
1222 guests, 176 members online
