Thread started 02 Jul 2012 (Monday) 22:30
IS Problems with Canon 17-55mm f/2.8
dereknitrorc
Joined Jul 2012
Jul 02, 2012 22:30 |  #1
Here is a video of what it is doing...
http://www.youtube.com​/watch?v=XKyYxQnV9eo (external link)
It jumps like that with or without the IS turned on/off. Is the IS messing up, or a sensor? I updated the firmware from 1.2.3 to 1.2.5 (latest) on the 7D body. I also tried the lens on a different 7D body and it still had the same issue. I was taking pictures earlier today at a car show and it worked fine until the last couple pictures I took it started acting up. The pictures came out clear but it would just keep jumping. Now it just jumps like that when I turn the camera on. Is there a fix that I can personally do or a shop I can send it to? I have a open ticket with Canon, but before sending it in I wanted to make sure I had exhausted my options. Thanks for any help!
rixtix
Jul 02, 2012 22:49 |  #2
Interesting. How old is the lens? I would send it back it is a costly piece of equipment. If I buy an lens for more than 300 dollars new I always get buy a warranty that covers everything from routine failure to dropping...just in case. Good luck
Canon EOS T4i. EFS 15-85, Tamron 10-24, EF-S 18-55 STM, EF 100 f/2.8 USM
No Deity Can Save Us, We Can Only Save Ourselves
dereknitrorc
Joined Jul 2012
Jul 02, 2012 23:00 |  #3
I have no idea. I bought it used a little over two years ago and has worked like a charm up until today.
dingie256
Joined Dec 2011
Jul 02, 2012 23:06 |  #4
send it in. looks messed up
450D | Canon 17-55 | 70-400 4L IS | 24L II | Elph 300 HS :D
mrkgoo
Jul 03, 2012 04:31 |  #5
My IS on my 17-55 did that when the AF broke. It broke several times, even after repair by Canon.
When I complain about the 'cheap' build of the lens, it's not about the materials, it's about the prone to failure AF and IS mechanisms.
dereknitrorc
Joined Jul 2012
Jul 03, 2012 08:46 |  #6
Do you remember how much it cost to have repaired? If this is a common issue then I might need to switch to a different lens.
John ­ from ­ PA
Joined May 2003
Jul 03, 2012 09:56 |  #7
How does the camera body behave with a different lens?
dereknitrorc
Joined Jul 2012
Jul 03, 2012 10:04 |  #8
I do not have another lens that has IS, but I did try the body with a 50mm f/1.4 and it didn't have any issues. The lens had the same issue with my 7D body as it did with a friend's 7D body.
Tsmith
Formerly known as Bluedog_XT
Jul 03, 2012 11:55 |  #9
Roger at LensRentals.com (external link) and POTN member also, did a write up on the IS failures with this lens happening a lot with he's rentals. However he later reported that the failure rate had dropped off.
So a Canon design change?
dereknitrorc
Joined Jul 2012
Jul 03, 2012 12:02 |  #10
Could be possible, I hope so. The lens is now on its way to Canon.
Keyan
Joined Mar 2011
Jul 03, 2012 12:09 |  #11
Yeah that's bad. Hopefully Canon fixes it up right. and it doesn't cost a million bux.
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
amfoto1
Jul 03, 2012 22:04 |  #12
Early on there were a lot of complaints about the 17-55 getting dust inside the front element, too... As well as a lot of IS failures. I think they must have done some mid-production-run "silent upgrades" to it, since complaints on both are a whole lot less common now. An older lens still might have issues, tho.
rawshooter
Jul 04, 2012 00:02 |  #13
Had to return my first one for an IS failure out of the box.The new one was was packed differently (better protected in a bigger box) and a later production run, and haven't had an issue since then.
7D
http://www.flickr.com/​photos/lookwhatidid (external link)
http://500px.com/jstcr​oix9 (external link)
dereknitrorc
Joined Jul 2012
Jul 10, 2012 10:17 |  #14
Canon just sent me a pdf this morning with the bill, $171.97 total with taxes/shipping. The labor part is at $149. I called the factory to find out what is wrong with it but they will not give me any updates until they actually start working on it. $172 isn't too bad considering it will be calibrated and tightened up to being like new again. I had been wanting to have that done since I bought it used, so guess with the IS problem I was forced into getting it done now instead of continuing to put it off. Based on how good of a job they do, I might send in my 7D to have them fix the sensor cleaning noise.
dereknitrorc
Joined Jul 2012
Jul 20, 2012 10:16 |  #15
Got the lens back, they replaced the IS unit. It had a white speck on one of the elements though. So it has been shipped back to Canon to have them clean it up, this time it is going to the Virginia repair center. I guess this is a good lesson to make sure you have a back up lens.
3,681 views & 0 likes for this thread, 13 members have posted to it.
2777 guests, 139 members online
