Recently I've moved to a wide gamut monitor and noticed that while viewing photos using Firefox on POTN many of them look very over-saturated and overly contrasty. My monitor is calibrated with Native (full) gamut. Most of the images (but not all) that have this problem seem to be hosted on Photobucket.
If I save the same image onto my computer and view it with Photoshop it looks fine.
It looks like Firefox (I'm using 13.0.1) has a problem handling images that don't have an embedded ICC profile. However, it turns out that this is a known "problem" and someone has made an add-on that fixes the behavior. The add-on is called "Color Management" and lets you enable color management for ALL images instead of the default which is only images with embedded ICC profiles. After installing it I'm now able to view all images on POTN as the poster intended them to be seen
If you keep your calibrated system as wide gamut and you use Firefox I recommend trying this out. Here's a link to the add-on: https://addons.mozilla.org …x/addon/color-management/![]()
Here is a screen capture of the "Options" screen for the Color Management add-on:
