Thread started 13 Dec 2005 (Tuesday) 20:06
Post Processing and then printing
jr#8
Dec 13, 2005 20:06 |  #1
Can any one answer this. When I download images from my camera to my pc the size is 48 X 32 resolution is 72. I'll open the image in PSCS2 I'll change the image size to 6 X 4 res. 600 and then print. Heres is my question, Why when printed to the 6 X 4 I can see the square pixels when printed?
Astrophotography,Fishi​ng
Canon 20D,Canon 100mm-400mm "L" IS USM,50mm 1.4 USM, Tamron AF28-80mm Asph, Canon 50mm FD Backwards Macro
Canon Speedlite 430 EX ,Bogen Monopod
Stroboframe
Dchemist
Joined Sep 2003
Dec 14, 2005 07:57 |  #2
What means are you using to resize the image? I do this using the CS2 crop tool set at 300dpi without issues when I print -- you should not need anything finer than 300 dpi.
What resolution setting did you use when you took the photo on the camera?
You might post an image in the forum if you don't get it resolved.
Dennis
POTN Book Vol4 Astronomy Image Manager and BC Member
20D, 5DMkII, 50F1.4, 100F2.8 macro, 135F2, 17-40F4, 70-200F2.8, 24-105F4, 580EX
Robert_Lay
Dec 14, 2005 09:43 |  #3
Apparently you have checked the box that enables Resampling. You do NOT want to resample. I suspect that you have ended up in throwing away most of your image.
When printing from your PC, you do not need to resize the image. The menu File->Print with Preview takes care of everything for you AND makes sure that you cannot inadvertently downsample.
I use PSCS, but I think that menu item works the same in CS2
If there is any confusion on that point, just make sure that you never re-sample. The only thing that counts in printing is to give it all the pixels that you have in the image. Whenever you give the printer less than are available in the full image, you are throwing away detail.
Bob
Quality of Light (external link), Photo Tool ver 2.0 (external link)
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
jr#8
Dec 15, 2005 07:03 |  #4
I use raw +jpeg.
There are 2 ways I use. Either go to image size or I crop to the size I want. I usually set resolution to 600.
If I post the mage you wont be able to see the pixels. its only when I print.
Stroboframe
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Dec 15, 2005 09:01 |  #5
Quote: What resolution setting did you use when you took the photo on the camera?
I use raw +jpeg.
I'm not understanding the "48 X 32 resolution is 72." size. You should be able to convert the RAW file to a 3000X2000 18MB 300ppi tiff to start out with. Check the settings in your conversion software.
jr#8
Dec 15, 2005 10:46 |  #6
When I download the image to my PC, Open CS2, then open my image, Go to image size and it says in the box's(width is 48 and the height is 32 Inches, Resolution is 72 pixels per inch). Thats how I open the image.
Stroboframe
Longwatcher
obsolete as of this post
Joined Sep 2002
Dec 15, 2005 13:34 as a reply to  @ jr#8's post |  #7
When looking at resizing your image make sure the number of pixels is not dropping.
I have my PS CS2 to display pixels on top, inches in middle and DPI on bottom of factors.
I pay most attention to number of pixels as it is there I will see if I forgot to check or uncheck the correct box at the bottom of the image size pop-up window.
If just changing the inches then if you have the check boxes at the bottom set correctly there should be no change in the number of pixels, but the DPI should change.
if starting with say 72 dpi at 48x32 you should have 3456x2304 pixels (give or take a couple)
So changing your dpi to say 144 should get you 24x16 and still 3456x2304 pixels
or Changing inches to 4x6 should change dpi to 576, but you should still have 3456x2304 pixels. If the pixels are changing you have one of the boxes checked wrong at the bottom. cancel, change the boxes and try again.
If the pixels are not changing and you are still having the problem printing then I would first check to make sure you are not printing in draft or standard modes. Make sure your are printing in high-quality mode.
Hope that helps,
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com (external link)
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher​.com/photoequipment.ht​m (external link)
jr#8
Dec 31, 2005 11:00 |  #8
Thanks that solved the problem. Now I have a new one. I'll start a New thread for this one.
Stroboframe
Robert_Lay
Dec 31, 2005 12:34 as a reply to  @ jr#8's post |  #9
Thank you for the positive feedback, and I'm glad my suggestion worked for you. We don't often get feedback from the original poster as to the final outcome.
Bob
Hellashot
Joined Sep 2004
Dec 31, 2005 15:28 |  #10
You have no need to resize your image at all. When you print, just tell it to print a 4x6 image instead of "actual size" It will do all the work for you.
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
1,162 views & 0 likes for this thread, 6 members have posted to it.
2305 guests, 135 members online
