I just received my new 135 f/2 when I got home from work. I was so happy and try it out immediately. It appears that the AF is a little slow. I originally thought that there might not be enough light, but after a compared it to my 17-40mm, it's even slow than the 17-40mm. Is it possible that the 135 slower than the 17-40mm, or I just got a bad copy???
Also, I suspect that the AF is not as accurate as it should be, what is the best way to test it?
Any suggestions and inputs would be appreciated.
Thanks.
| Canon 5DII
| Fujifilm Finepix F30
