Thread started 04 Jul 2012 (Wednesday) 09:12
Faulty flash
mongoos665
Joined Jul 2012
Jul 04, 2012 09:12 |  #1
I have recently purchased a Canon 60D and all seemed to be working well except for the flash. When the flash comes on to illuminate the subject beforehand to focus, instead of one long prolonged light to illuminate the object, it's a series of very fast flickers of light, with about 20 flashes of light per second as opposed to one prolonged light.
I sent it back to the company and they sent me a completely new one, which also has the same problem. Canon said it was not a setting inside the camera, could anyone help or has anyone had the same problem? :cry:
F-Stran
Jul 04, 2012 09:14 |  #2
What type of flash is it?
5DMK IV | 60D | 40D | Tamron 70-200 G2 | Sigma 35 f/1.4 | Tamron 17-50 | 50 f/1.4 | 85 f/1.8 | 55-250
Website (external link)
oldvultureface
Gallery: 85 photos
Jul 04, 2012 09:14 |  #3
That's not a problem. That's how the focus assist works.
MakisM1
Gallery: 50 photos
Joined Dec 2011
Jul 04, 2012 09:16 |  #4
Are you talking about the pop-up flash?
What mode (P,M, Av, Tv) are you using?
Is the wireless off?
Gerry
rrblint
Gallery: 84 photos
Joined May 2012
Jul 04, 2012 09:25 |  #5
oldvultureface wrote in post #14669239 (external link)
+1..This is normal.
Mark
mongoos665
Joined Jul 2012
Jul 04, 2012 09:25 |  #6
It is the built in flash I got with the camera with all the default settings (have even restored it to factory settings a few times), flash mode- E-TTL II, Shutter sync- 1st Curtain, exp comp at 0, E-TTL II meter- evaluative, Wireless Func- Disable.
I am new to cameras of this sort
mongoos665
Joined Jul 2012
Jul 04, 2012 09:26 |  #7
Also makes a fast clicking sound, a click for all the individual little flashes it does
Ody
Jul 04, 2012 09:29 |  #8
It's fine. Enjoy using.
5D mk III, 1D mk III, 17-40L, 24-70L, 70-200L mk II, 300mm f4L IS, 85 1.8, 100 macro.
mongoos665
Joined Jul 2012
Jul 04, 2012 09:32 |  #9
Every camera I've ever used or seen has had just one long prolonged light to bring the subject into focus, not just a series of flashes with a strange clicking sound...
mongoos665
Joined Jul 2012
Jul 04, 2012 09:33 |  #10
And it does this in every mode
tumblew33d
Jul 04, 2012 09:40 |  #11
As the rest have said, that's how it works.
Have a read of this discussion to help it sink in some more
http://forums.steves-digicams.com …-beam-canon-models.html#b (external link)
In particular, look at post #8
mongoos665
Joined Jul 2012
Jul 04, 2012 09:41 |  #12
So it's meant to fire hundreds of small flashes, as a opposed to one prolonged one?
JDPhotoGuy
Joined Apr 2012
Jul 04, 2012 09:44 |  #13
It's your focus assist. It does this in lighting situations where the autofocus has a hard time detecting anything. The flash will strobe like that, illuminating your intended subject enough for the focus system to lock on. As stated, it's normal. For whatever reason (whether too cheap or out of fear of 10,000 IR beams messing with pros at events) they have decided that this ghetto functionality is sufficient. :)
BTW: It's not taking your picture then, so it's not 1000 flashes. It's essentially using your flash as a flashlight, getting focus, saying "okay, I'm focused now", turning the light back off and waiting for you to take the shot. And "yes" to your last question.
Yes, I have severe Equipment Deficiency. No, the pills don't fix it.
Jim_T
Joined Nov 2003
Jul 04, 2012 09:45 |  #14
It's an EOS thing. Both my 10D and 7D do it..
Rather than installing a stand-alone AF Assist light, they pulse the popop flash to illuminate the subject so that the AF can lock in low light. The flash has to be 'sizzled' because it's a pulse type device and can't be turned on to create a steady beam.
This action is described on page 55 of the EOS 60D owner's manual.
mrbubbles
Jul 04, 2012 09:48 |  #15
mongoose the flash on your new 60d is only meant to be on for short bursts. If it were to 'stay' on it would probably burnout. That is the reason it pulses a lot. There is nothing wrong with it.
Zenfolio (external link)
2,863 views & 0 likes for this thread, 16 members have posted to it.
Faulty flash
2704 guests, 150 members online
