Not sure what I am doing wrong. Once I edit a photo in Elements 10 and send back to file in ZB it take forever to load up. it seem like I am somehoe screwing up the file. Help greatly appreciated.
Jul 04, 2012 16:53 | #1 Not sure what I am doing wrong. Once I edit a photo in Elements 10 and send back to file in ZB it take forever to load up. it seem like I am somehoe screwing up the file. Help greatly appreciated. Canon 5D3, 60D, 70-200 L f4 IS, 17-40L,16-35f4, 24-105L,100 f2.8, 85 f/1.8, 55-250 IS, 400 f/5.6, Ziess 21 2.8, canon 1.4, 430EX www.flickr.com/photos/maggiesguy
tonylong ...winded More info | Jul 04, 2012 21:53 | #2 CHUCK A wrote in post #14670872 Not sure what I am doing wrong. Once I edit a photo in Elements 10 and send back to file in ZB it take forever to load up. it seem like I am somehoe screwing up the file. Help greatly appreciated. What format of original file are you working on? Tony
I am working with raw file and than saving to psd. I tah convert and export in jpeg. Canon 5D3, 60D, 70-200 L f4 IS, 17-40L,16-35f4, 24-105L,100 f2.8, 85 f/1.8, 55-250 IS, 400 f/5.6, Ziess 21 2.8, canon 1.4, 430EX www.flickr.com/photos/maggiesguy
tonylong ...winded More info | Jul 06, 2012 01:08 | #4 OK, I've been busy! Tony
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | Jul 06, 2012 03:29 | #5 Try saving a copy as a TIFF file and compare the loading speed? I'd understood (maybe wrongly) that psd was a photoshop special, while TIFF's are more universal. Richard
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Jul 06, 2012 05:43 | #6 Zoombrowser supports *.psd? Elie / אלי
GilBean Senior Member 515 posts Joined Jan 2009 Location: San Angelo, TX More info | Jul 06, 2012 14:38 | #7 tzalman wrote in post #14677673 Zoombrowser supports *.psd? No. I opened a folder with .PSD files & 1 TIF file in ZB. The only thing ZB showed was the TIF file. I could not access the PSD files at all. G3, G6, G12, T2i + kit lens & accoutrements
tonylong ...winded More info | Jul 06, 2012 16:36 | #8 CHUCK A wrote in post #14672657 I am working with raw file and than saving to psd. I tah convert and export in jpeg. tzalman wrote in post #14677673 Zoombrowser supports *.psd? Gil Bean wrote in post #14679933 No. I opened a folder with .PSD files & 1 TIF file in ZB. The only thing ZB showed was the TIF file. I could not access the PSD files at all. GilBean Good points -- ZoomBrowser can't read the psd files. And, if you open a folder with a mix of psd and jpegs, ZoomBrowser might "choke" a bit with the psds before showing the jpegs. And, the Canon software also seems to have a problem with tiffs that have been saved by PS. I'm not sure of the technical details there, but I've seen bad DPP behavior if trying to show thumbnails of tiffs that were created by PS. Tony
Thank you for all of the responses. That is what is happening. I am saving in psd and ZB is getting choked. Takes forever to load up. I save in jpig and no problems. Canon 5D3, 60D, 70-200 L f4 IS, 17-40L,16-35f4, 24-105L,100 f2.8, 85 f/1.8, 55-250 IS, 400 f/5.6, Ziess 21 2.8, canon 1.4, 430EX www.flickr.com/photos/maggiesguy
GilBean Senior Member 515 posts Joined Jan 2009 Location: San Angelo, TX More info | Jul 07, 2012 13:13 | #10 CHUCK A wrote in post #14680618 Thank you for all of the responses. That is what is happening. I am saving in psd and ZB is getting choked. Takes forever to load up. I save in jpig and no problems. ZB will work with TIF but they must be 8 Bit. If you have 16 bit, I think it will ask if you want to convert to 8 bit when you try to do anything (not sure on this) but am certain it will work with 8 bit TIF. Please do not use JPG. JPG is lossy = you lose pixels everytime you open/close/modify/save. TIF is lossless. G3, G6, G12, T2i + kit lens & accoutrements
| Latest registered member is Niagara Wedding Photographer 1340 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
