Hi,
Considering it myself but would like some honest feedback - especially about IQ and AF.
Even better of course if you made the switch and then I could get a real comparative.
Ta.
theviper Senior Member 615 posts Likes: 1 Joined Oct 2010 More info | Jul 04, 2012 19:30 | #2 John_N wrote in post #14671115 Hi, Considering it myself but would like some honest feedback - especially about IQ and AF. Even better of course if you made the switch and then I could get a real comparative. Ta. I have both. the 1D3 is the backup for my 5D3. The 5D3 is much better in most ways. I find I can push the 1D3 images slightly more in post though plus the 1.3 crop is nice with longer lenses as well as the more rugged build and weatherproofing. http://www.flickr.com/photos/vinnyburns/
jase1125 Goldmember More info | Jul 04, 2012 22:06 | #3 AF significantly better IMO and IQ is outstanding. The crop factor is void since cropping a 5D3 image will yield a 13 megapixel image with the same FOV as a 1D3. Jason
theviper Senior Member 615 posts Likes: 1 Joined Oct 2010 More info | Jul 05, 2012 03:12 | #4 jase1125 wrote in post #14671736 AF significantly better IMO and IQ is outstanding. The crop factor is void since cropping a 5D3 image will yield a 13 megapixel image with the same FOV as a 1D3. Yes true. http://www.flickr.com/photos/vinnyburns/
JohnB57 Goldmember 1,511 posts Likes: 23 Joined Jul 2010 Location: Holmfirth, Yorkshire, England More info | Jul 05, 2012 04:13 | #5 jase1125 wrote in post #14671736 The crop factor is void since cropping a 5D3 image will yield a 13 megapixel image with the same FOV as a 1D3. theviper wrote in post #14672562 Yes true. The crop factor is only void if, as you say, you crop the outer portion of the FF image. If instead you adjust focal length in order to use the whole frame in both cases, the higher pixel count of the 5D3 - and less subsequent enlargement required - are major factors.
JohnB57 Goldmember 1,511 posts Likes: 23 Joined Jul 2010 Location: Holmfirth, Yorkshire, England More info | Jul 05, 2012 14:49 | #7 John_N wrote in post #14674559 Sorry I didn't follow that - I was with the MP countering the crop. My point was that if you fill each frame with the subject by adjusting focal length, resulting in two identical images, the 5D3 one will be 22mp whilst the 1D3 one will be only 10mp.
jlbrach Member 219 posts Joined Jul 2006 More info | Jul 05, 2012 15:18 | #8 I have the 5D3 and used to have the 1D3 and currently have the 1D4.....the 5D3 is a better camera than the 1D3 but the 1D3 is an outstanding camera especially for sports and low light shooting.....for the price of a used camera today the 1D3 is a bargain canon 5d3,,1d4
Jul 06, 2012 05:55 | #9 I agree on the price - got mine for around £1.2K, which I hope to get back when I upgrade to the 5D3 (which knowing me and my obsessions will be soon) - I'll have to shift a few other less used lenses and equipment too sadly but that the price of things I guess.
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | Jul 06, 2012 06:25 | #10 JohnB57 wrote in post #14672643 The crop factor is only void if, as you say, you crop the outer portion of the FF image. If instead you adjust focal length in order to use the whole frame in both cases, the higher pixel count of the 5D3 - and less subsequent enlargement required - are major factors. Or have I missed something? No, you've missed nothing. What you say is the complete truth. Why throw away pixels needlessly when a little thought and a switch of lens will produce higher quality work? Richard
jase1125 Goldmember More info | Jul 06, 2012 09:55 | #11 The point was the reach advantage of the 1d3 isn't an advantage at all when using the same focal length lens. Cropping a 5d3 image to have the same field of view results in an image with 3 more megapixels. It goes without saying if an option exists for a longer lens or to zoom with your feet then one should. More pixels on target is always desired for maximum image quality. Jason
| Latest registered member is semonsters 1460 guests, 129 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
