Can anyone help you brighten up this little koala please.
I have CS6. I do have the RAW file too.
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
koala
jtsmith90 Member 51 posts Likes: 12 Joined Feb 2012 Location: Townsville More info | Jul 07, 2012 05:32 | #1 Can anyone help you brighten up this little koala please.
koala Josh
Jul 07, 2012 05:57 | #2 Hi Josh, I'm sure someone else will jump in & do a better job. Phil Cupra
les_au Senior Member More info | Jul 07, 2012 06:28 | #3 this is another quick edit with a bit of a crop, i am no expert either
JDPhotoGuy Senior Member 294 posts Likes: 1 Joined Apr 2012 More info | There's a lot of detail still there, even more to be had in the RAW! Yes, I have severe Equipment Deficiency. No, the pills don't fix it.
Jul 07, 2012 07:24 | #5 Thanks all. They all look heaps better. Josh
Jul 07, 2012 08:03 | #6 like the 3rd one by les_au best, great composition/detail in it
JDPhotoGuy Senior Member 294 posts Likes: 1 Joined Apr 2012 More info | Jul 07, 2012 08:09 | #7 jtsmith90 wrote in post #14682865 Thanks all. They all look heaps better. JDPhotoGuy Is there any tutorials on how to do that. Josh, I wish I could say there was! In truth though, what I know/do with Photoshop is the culmination of a lot of tutorials. Bits and pieces I've picked up from here and there. Sometimes I don't even know why they work, just that they do. Yes, I have severe Equipment Deficiency. No, the pills don't fix it.
Jul 07, 2012 17:29 | #8 Thanks i will give this a try and see what it comes out like. JDPhotoGuy wrote in post #14682945 Josh, I wish I could say there was! In truth though, what I know/do with Photoshop is the culmination of a lot of tutorials. Bits and pieces I've picked up from here and there. Sometimes I don't even know why they work, just that they do. I will walk you through what I did here though! I copied the background, turned off the original background copy Copied again, desaturated the new layer - I always start with a desaturated layer when I want details to pop. Set the blending mode to screen 100%, added a layer mask (if you don't use layer masks I suggest you start on tutorials there. It should be an essential part of your PP workflow. Without layer masks you will never use 1% of the potential of Photoshop.) On the layer mask, I masked out everything that was background. I figured for this picture the foreground would include the shrubbery and two stumps sticking up. When I got close to the foreground when masking out, I dropped the brush's flow down to 40-60% and feathered the ghosting out. Copied the background again, desaturated again, set blending mode to color dodge 100%. Created a layer mask again, masked out the background again and masked out a bit more dodging selective areas to give the foreground the appearance of being well lit. Best I can describe this layer as is it's your mock fill flash. Select the topmost layer then hold down shift-cntrl-alt-E... (That copies all layers from the one you're on now and below into a new layer. It's like a merge all without destroying what you have.), unsharp mask, play with the sliders, layer mask, mask out everything but the koala. Normal blending mode 100% shift-cntrl-alt-E again, image->adjustments->shadows/highlight. Play with the sliders again. Layer mask out everything but koala and the trunk he's on. Blending mode luminosity at 45%. Again, I just got here by trial and error. Nothing is set in stone. shift-cntrl-alt-E, and I adjusted the white balance. Turned the temperature down on the image by image->adjustments->color balance.. Red toward cyan a click or two, yellow toward blue 10 or 15 or so. blending mode normal 100% Copy original background layer, bring that layer all the way to the front, set blending mode to color and 100% just to finish it off. Hope that helps a bit ![]() Josh
bobbd Member 184 posts Likes: 3 Joined May 2011 Location: Preston UK More info | My go with pse9 Image hosted by forum (605011) © bobb d [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. 7D, 70-200 f2.8 L non IS USM, 18-135mm EFS, 10-22mm f/3.5-4.5, 70-200mm f/4 L IS USM, 100-400mm f/4.5-5.6 L IS USM, 50mm Mk2 1.8, 85mm 1.8, 17-55mm 2.8, 580 EXII, Manfrotto 055XB & 804RC2 head..........no money left now:p
photocopy Goldmember 1,555 posts Likes: 2 Joined Nov 2011 Location: PNW More info | Jul 09, 2012 11:45 | #10 what a cutie!
Visualization Hatchling 2 posts Joined Apr 2012 More info | Jul 09, 2012 15:40 | #11 JDPhotoGuy wrote in post #14682862 There's a lot of detail still there, even more to be had in the RAW! Here's a quick 10 minute fix - still some ghosting issues that could be fixed with another half hour to spare. ![]() Wow, this one looks nice. The other ones make the koala look like he has jaundice or something! Way too yellow.
| Latest registered member is semonsters 1053 guests, 104 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
