The past couple of time's viewing raw images on the Canon DPP the computer just shuts down, but if I view JPEG its fine. I'm shooting with a Canon 1D MarkIII and the card is a Lexar Pro SD 1GB 133x and the computer is a HP Pavilian zd8000.
devildog2222 Member 43 posts Joined Dec 2008 More info | Jul 07, 2012 15:01 | #1 The past couple of time's viewing raw images on the Canon DPP the computer just shuts down, but if I view JPEG its fine. I'm shooting with a Canon 1D MarkIII and the card is a Lexar Pro SD 1GB 133x and the computer is a HP Pavilian zd8000.
MikeT2i Member 83 posts Joined Dec 2011 More info | Jul 07, 2012 15:17 | #2 First I would uninstall DPP and then reinstall. If that does not work you may want to make sure the file extension (.raw) is registered with the computer. In Win7 > Start > then in search program and files type "file type" without the quotes.
I will try the uninstall of DPP. The file extension (.raw) should be registered with the computer. I've been opening and viewing the files fine for a few years and it just started now.
Moppie Moderator 15,104 posts Gallery: 24 photos Best ofs: 1 Likes: 455 Joined Sep 2004 Location: Akarana, Aotearoa. (Kiwiland) More info | Jul 07, 2012 18:22 | #4 Uninstalling DPP or playing with anything in software won't do anything.
crn3371 Cream of the Crop 7,198 posts Likes: 2 Joined Mar 2005 Location: SoCal, USA More info | Jul 07, 2012 18:42 | #5 Most likely overheating. By computer standards that's a pretty old laptop. Check your vents for dust bunnies.
If it was the heat wouldn't it be turning off all throughout the day since I have it on from morning to around 11pm. It runs hot all the time even when it was new. The only time it shuts down because of heat is when I have it out in the backyard doing White light photography of the sun. When I open the RAW images in Photoshop it is totally fine and does not turn off. I'll have to test out RAW's from my compact card to see if it does the same thing.
joeseph "smells like turd" More info | Jul 08, 2012 04:47 | #7 anything's possible, but if the unit's just idling along then it doesn't really have to work hard. Processing larger amounts of data makes it work harder & working harder generates heat. Heat can affect almost anything from motherboards & cpu's to memory. some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", and an M5, also an M6 that has had a 720nm filter bolted onto the sensor:
Ok, so I downloaded Core Temp to see how my temps were running normal internet stuff and just doing JPEG images. With internet stuff it really never got beyond 65C and editing JPEG images in DPP it got up to around 74C and the loads were not that high. But when I got to the RAW images using DPP the loads would sometime go to 100% and the temp would go over 81C and when it got over 81C by a few degrees the computer shutdown. The odd thing is that when I open the RAW images in Photoshop Elements 9 the temp would be around 74C and the loads never got close to 100%.
JDPhotoGuy Senior Member 294 posts Likes: 1 Joined Apr 2012 More info | Jul 14, 2012 15:27 | #9 devildog2222 wrote in post #14716364 Ok, so I downloaded Core Temp to see how my temps were running normal internet stuff and just doing JPEG images. With internet stuff it really never got beyond 65C and editing JPEG images in DPP it got up to around 74C and the loads were not that high. But when I got to the RAW images using DPP the loads would sometime go to 100% and the temp would go over 81C and when it got over 81C by a few degrees the computer shutdown. The odd thing is that when I open the RAW images in Photoshop Elements 9 the temp would be around 74C and the loads never got close to 100%. In a few days or weeks I'll take apart the computer like I have done before and clean out the fans and the heatsink and the whole laptop. Since I have I'll have the laptop taken apart should I put new thermal paste on? I have not done that with this laptop yet. Would it help with the heat? Few days or weeks will probably be too long to save the laptop. It takes a fraction of a second of overheating to permanently damage your CPU. Thermal paste isn't the issue. Once it's there, it's there. It doesn't really go bad. It's ceramic paste and sealed as it were. It's dust bunnies, your fan blades warped/melted and not pushing as much air. If you do have to pull the heat sink off, of course you need to clean and reapply the thermal paste. Yes, I have severe Equipment Deficiency. No, the pills don't fix it.
If I do reapply the thermal paste what is the best method? I have read where they say doing a small dot of paste in the middle works better then anyother method. But then there is ones that say to put a dot on and then spread it with a credit card or something like that.
JDPhotoGuy Senior Member 294 posts Likes: 1 Joined Apr 2012 More info | Jul 14, 2012 16:08 | #11 devildog2222 wrote in post #14716440 If I do reapply the thermal paste what is the best method? I have read where they say doing a small dot of paste in the middle works better then anyother method. But then there is ones that say to put a dot on and then spread it with a credit card or something like that. The instructions will be on the package the compound comes in. I think you're confusing conflicting applications though. In truth I do both. I clean the surfaces well with alcohol. Then I spread some on both the CPU metal backing and the heatsink. Scrape it all off. This re-primes all the micro fine pores. Then I put the small dot on the CPU backing and press and twist back and forth a degree or two to seat. Yes, I have severe Equipment Deficiency. No, the pills don't fix it.
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Jul 16, 2012 11:14 | #12 I am surprised you have enough patience to edit RAW files on a computer that old and slow! I'd use this as the perfect excuse to get something new with an i5 or i7 CPU. Taylor
maverick75 Cream of the Crop More info | Jul 16, 2012 11:40 | #13 I have a 7 year old desktop with similar specs 2.8CPU,only 1GB of RAM and it handles my RAW files just fine! Granted they're only 6mp. - Alex Corona Sony A7, Canon 7DM2/EOS M, Mamiya 645/67
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Jul 16, 2012 12:16 | #14 If your computer and camera are from about the same year, it's no problem! It's when they get about 5 years apart that things get painful. Taylor
howesit Member 37 posts Joined Nov 2011 More info | Jul 16, 2012 14:06 | #15 I have fixed many overheating laptops, and generally it is the dust bunnies, so it's best to evict them! I usually blow it out with compressed air (I have an air compressor). Blow it out reverse direction of the normal air flow (so blow it in where it usually comes out) that usually clears them out. If you don't get many dust bunnies, then you might have to take it apart. Static warning: Make sure you avoid any kind of static, best is to do it in a room with no carpet, and standing. You don't even have to feel the static shock for it to kill your processor and other chips on the motherboard. if you don't have a grounding strap I find it a good idea to try to keep one hand on a metal leg of the table or just touch something metal frequently. The thermal paste is not supposed to go bad, but I have seen otherwise. Sometimes with enough overheating (and heating and contracting of everything) the paste gets hard or looses contact and then doesn't cool as well. So if you do take it apart, make sure that you clean both the processor and the heat sink alcohol is a good idea (as long as it is rubbing alcohol and not the drinking stuff). If it is one that has the graphics processor on the heat sink too, and it has thermal compound on it, make sure you clean it off on both sides as well. If it is just one of those foam looking pads, those are usually fine to just leave alone and put back as they are. When applying the thermal paste, I usually just put little dabs all over the processor and smear it around with the tip of the thermal paste tube. You don't want too much, but it is worse to not have enough. I like artic silver thermal paste. hope this helps Black box thingy with lots of buttons and a round tube sticking out with some glass on the ends and it keeps making this "click" sound over and over and over and over and over.
| Latest registered member is Thunderstream 2124 guests, 96 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
