Thread started 14 Dec 2005 (Wednesday) 15:55
Exploding Light Bulb
quadphoto
Dec 14, 2005 15:55 |  #1
This image was originally taken with an Olympus 0M1 and two Vivitar 283 flash guns in a darkened room, with the shutter opened on Bulb an airgun pellet was then fired through the light bulb hitting a copper mechanical trip switch positioned about a one foot to the right of the bulb which was connected to the flash gun making it fire, the shutter was then closed. I recently scanned the 8''x10'' print and tweaked a little in PS7.
tomwilli
Joined Nov 2005
Dec 14, 2005 16:03 |  #2
Cool photo. Thanks for shareing. I dont have comments on this one. I like it.
Canon EOS 40D w/ Grip | Canon EF 50mm f/1.4 | Canon EF 85mm f/1.8 | Canon EF 24-70 f/2.8L | Canon EF 70-200 f/2.8L IS | Canon Speedlite 580EX w/ LSII | 2 Pocket Wizards | Bogen Manfrotto 3021BPRO | Bogen Manfrotto 488RC2 |
sparker1
Dec 14, 2005 16:04 |  #3
Amazing.
jr#8
Dec 14, 2005 16:29 |  #4
Awesome. I really like the frozen time. Plus shows how a bullet works, goes in small hole and comes out large hole.
Astrophotography,Fishi​ng
Canon 20D,Canon 100mm-400mm "L" IS USM,50mm 1.4 USM, Tamron AF28-80mm Asph, Canon 50mm FD Backwards Macro
Canon Speedlite 430 EX ,Bogen Monopod
Stroboframe
adam*
Dec 14, 2005 16:40 |  #5
Awesome
:: For sale: 70-200 2.8L :: Nikon D700 ::
:: my site :: www.pbase.com/adamgray​photography (external link) ::
Jman13
Dec 15, 2005 01:59 |  #6
Outstanding capture. I've always wanted to give this a try, but the rigging of the flashguns always seemed to be a massive pain. How hard was it to set up the relay?
Jordan Steele - http://www.jsteelephot​os.com (external link) | https://www.admiringli​ght.com (external link)
Canon EOS R5 | R6 | TTArtisan 11mm Fisheye | Sigma 14-24mm f/2.8 | RF 24-105mm f/4L IS | Tamron 35mm f/1.4 | RF 35mm f/1.8 | RF 50mm f/1.8 | RF 85mm f/2 | RF 70-200mm f/2.8L IS | Sigma 135mm f/1.8
Huckaback ­ Photo
Joined Jan 2005
Dec 15, 2005 02:29 as a reply to  @ Jman13's post |  #7
Jman
You don't need a relay for this shot, as quadphoto said its done with a mechanical switch. when the pellet hits it makes a contact. so you have two pieces of copper strips and using older 283 vivitar flash guns. these use a pc cable conection, make up a special lead 2 wires in a pc lead each wire is soldered to each strip and other end has the pc connection for the flash. touch the two copper strips together and the flash fires.
the point at which it fires is controlled by the distance you set up that switch.
cover the face of one strip with card this will absorb the pellet.
I should mention Quadphoto is a good mate and we did some work together with this set up. he has some tremendous high speed flash pictures.
the rest of the set up I shall leave to him. even using a polaroid back for test shots. digital would be so much easier for the tests.
Quadphoto this looks great on here well done, good to see this again.
Martin (Huckaback Photo)
Old photographers never die. They just go out of focus
skade
Dec 15, 2005 03:34 |  #8
Wow, that is one amazing shot!
Mgdh
unscathed.. NOT!
Gallery: 44 photos
Joined Jan 2005
Dec 15, 2005 07:47 |  #9
Fantastic shot! I'm really impressed and there is just so much information in the shot.
This sounds a similar setup to what I used to capture my 'Cherry Splash' image in the 'Experimental' section ( http://www.photography​-on-the.net/forum/showthre​ad.php?t=119757 ). This was taken some time ago on my Oly OM40 open on 'bulb', again in a darkened room only I had to fire the flash by hand after a countdown as I did not have a trigger mechanism. One roll of film later, I had two useable photo's. Fortunately, I could wipe down the glass between shots and use it again, not something you could do with this lightbulb!
Like you, I scanned my 8x10 with a subsequent clean, resize and slight sharpen for the web.
Mark
So much has changed in our photo-world, and yet basically nothing's changed - It's still the pictures that really matter. David Noton
-- The Gallery (external link) -- The Website (external link) --
JohnnyG
Worthless twinkle toes fairy
Dec 15, 2005 09:57 as a reply to  @ Mgdh's post |  #10
Cool for sure!:cool::cool::cool:
Canon EOS 5D Mark II, 100-400IS L, 24-105 L[COLOR=black][FONT=&qu​ot] IS, 50mm f/1.4, Canon 430EX/580EX II, Kenko 1.5X, Epson R1900, Manfrotto 679B Monopod, 3021BPRO tripod, 808RC4 Head, 486RC2 Ballhead
quadphoto
Dec 15, 2005 12:43 |  #11
Mgdh, just had a look at your 'Cherry Splash' image very good, at the time that i took the exploading light bulb image I also took photo's of exploading balloons and crowns formed from milk droplets using a sound trigger that i made, it was great fun at the time and i am thinking of having a go at it all again using Digital.
Mgdh
unscathed.. NOT!
Gallery: 44 photos
Joined Jan 2005
Dec 15, 2005 18:58 as a reply to  @ quadphoto's post |  #12
Thanks for checking out my pic.
I look forward to seeing the results of the digital shots :)
Mark
waldograce
Dec 15, 2005 19:13 |  #13
Very nice job.
Looks like a fun shot to set up and execute.
Looking forward to seeing your digital work.
I can't create beauty with my camera, I can only capture it.
2,060 views & 0 likes for this thread, 11 members have posted to it.
1089 guests, 127 members online
