I'm using a spyder 4 express with dispcalgui and argyll on Dell U2410 and U2412m monitors. Running win 7 ultimate, and all software is the latest version.
I'm been getting some terrible calibrations results so I decided to reset both monitors to defaults with the u2410 set to the srgb preset. Then I took uncalibrated measurements.
I got
For the U2410 I get:
Uncalibrated response:
Black level = 1.19 cd/m^2
White level = 217.92 cd/m^2
Aprox. gamma = 1.99
Contrast ratio = 183:1
White chromaticity coordinates 0.3303, 0.3293
White Correlated Color Temperature = 5597K, DE 2K to locus = 7.1
White Correlated Daylight Temperature = 5597K, DE 2K to locus = 10.5
White Visual Color Temperature = 5821K, DE 2K to locus = 6.8
White Visual Daylight Temperature = 5976K, DE 2K to locus = 10.1
Effective LUT entry depth seems to be 8 bits
For the U2412m I get:
Black level = 1.18 cd/m^2
White level = 254.47 cd/m^2
Aprox. gamma = 2.18
Contrast ratio = 215:1
White chromaticity coordinates 0.3067, 0.3178
White Correlated Color Temperature = 6963K, DE 2K to locus = 0.8
White Correlated Daylight Temperature = 6967K, DE 2K to locus = 3.9
White Visual Color Temperature = 6929K, DE 2K to locus = 0.8
White Visual Daylight Temperature = 7153K, DE 2K to locus = 3.7
Effective LUT entry depth seems to be 10 bits
The black level seems to be totally wrong. I posted this on the displcalgui forums, but that forum is mainly for the software bugs.
Does anybody else here happen to use this combo? Am I doing something wrong?
I warmed up both monitors for a hour and left the calibrator on the screen to get warmed up too.
If I target 250 it calibrates to 185 ... when I target 350 it calibrates to 237 (which is about what I want). Luminance is always close to spot on and my Delta E is 0.18, which is very good.
