Ok, I've been experiencing mucho lens flare--I shoot a lot of real estate (inside/outside) and use an UWA (Tokina 11-16mm). I get the dreaded green flare and am trying to find the best way to deal with it in CS6.
Any suggestions?
Thanks.
GadgetRick Goldmember 1,081 posts Joined Mar 2010 Location: Jacksonville, FL More info | Jul 10, 2012 15:14 | #1 Ok, I've been experiencing mucho lens flare--I shoot a lot of real estate (inside/outside) and use an UWA (Tokina 11-16mm). I get the dreaded green flare and am trying to find the best way to deal with it in CS6.
Jul 11, 2012 05:51 | #2 Bump.
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Jul 11, 2012 08:13 | #3 Masked adjustment layers. clone. burn. "I think the idea of art kills creativity" - Douglas Adams
Jul 11, 2012 11:30 | #4 René Damkot wrote in post #14701175 Masked adjustment layers. clone. burn. https://photography-on-the.net …showthread.php?p=13608825 https://photography-on-the.net …/showthread.php?p=5801790 https://photography-on-the.net …showthread.php?p=12602775 Next time, use a lenshood and don't use a filter. Or take an extra shot while blocking the light sources from hitting the front lens, even if you need to place a flag where it is in the image. Easier to compose two shots then to have to remove a lot of flare. Thanks.
Numenorean Cream of the Crop 5,013 posts Likes: 28 Joined Feb 2011 More info | Jul 11, 2012 11:31 | #5 |
Jul 11, 2012 19:06 | #6 Numenorean wrote in post #14702094 Maybe get a better lens? LOL!
2. This one I'm not totally sure but it must be coming from the light fixture:
I can't really address preventing flare if I'm not 100% sure of why I'm getting it. I understand when I get it when shooting at light sources. But neither of these were shooting at a light source. Anyone got any ideas?
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Jul 12, 2012 06:19 | #7 Of course you were shooting at a light source: It's in the image. the-digital-picture.com wrote: Unless you like the effect (my daughter thinks it's cool), you are going to have a challenge removing the Tokina 11-16's flare from your images in post processing. The best option with this lens is to avoid the flare in the first place.
ScullenCrossBones Senior Member 842 posts Joined May 2009 Location: Keller, TX More info | Jul 12, 2012 07:45 | #8 Are you dragging the shutter to make the lights brighter? If so, try a faster shutter speed. :p Gear
Jul 12, 2012 11:20 | #9 GadgetRick wrote in post #14704011 I'm trying to understand why I'm getting flare. Because you're using the Tokina 11-16. Really, honestly, that lens is terrible for flare. You owe it to yourself to at least try the Canon 10-22. It's almost impossible to get that lens to flare (without a 'protective' filter). Frank Hollis - Retired mass spectroscopist
Numenorean Cream of the Crop 5,013 posts Likes: 28 Joined Feb 2011 More info | Jul 12, 2012 11:26 | #10 hollis_f wrote in post #14706740 Because you're using the Tokina 11-16. Really, honestly, that lens is terrible for flare. You owe it to yourself to at least try the Canon 10-22. It's almost impossible to get that lens to flare (without a 'protective' filter). I own both lenses, I was hoping I'd be able to sell the Canon when I bought the Tokina. After the first day I realised that the flare problem was so bad that there was no way I could use the Tokina outside in daylight. It's now reserved for astro shots, and even then I can get bad flare. BUT NO THE TOKINA IS BETTER!
kirkt Cream of the Crop More info | Jul 12, 2012 11:58 | #11 The flare is from the lighting, regardless of the lens. You need to reorient the camera to avoid flare, shade the lens to block the concentrated lighting that is causing the flare, or take two images of the scene, one that is your standard image and one that might include your shade in the image but deflares the areas affected by the flare (the lower portion of the image). Kirk
Jul 12, 2012 12:27 | #12 kirkt wrote in post #14706890 The flare is from the lighting, regardless of the lens. Sorry, but it's not regardless of the lens. It's well known that different lenses have different tendencies to suffer from flare. Frank Hollis - Retired mass spectroscopist
ScullenCrossBones Senior Member 842 posts Joined May 2009 Location: Keller, TX More info | Jul 12, 2012 12:45 | #13 hollis_f wrote in post #14707024 Sorry, but it's not regardless of the lens. It's well known that different lenses have different tendencies to suffer from flare. +1 :p Gear
kirkt Cream of the Crop More info | Jul 12, 2012 15:10 | #14 True, but the concentrated light source is the root of the flare. The lens and its ability to suppress flare will only change its appearance. Remove the concentrated light source and you remove the source of the flare. Kirk
Jul 13, 2012 06:14 | #15 René Damkot wrote in post #14705727 Of course you were shooting at a light source: It's in the image. ![]() 1st is probably the window (since it's too big and close to the center to be caused by the lamp), second could have easily been avoided by taking a second shot, while holding a hand between light fixture and lens. (Your hand would be in that image, but you would have an image without flare.) If you don't have the time for that, a quicker way might be to take one shot wide open: Apparently, it flares much less then: http://www.the-digital-picture.com …/Lens-Flare.aspx?Lens=718 1st is not too hard to remove, second might be a bit harder, but still can be cloned out relatively easy. Still, better to avoid it in the first place. Sorry, I know they are light sources, just was more talking about shooting directly into a light source like the sun or a big light. My fault.
| Latest registered member is semonsters 1676 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
