For simply blurring water in streams and falls is a ten stop overkill? Would 6 stop be a better choice?
Thanks.
-Sam
regatta Senior Member 342 posts Joined Jul 2011 Location: St. Pete Beach, Florida More info | Jul 12, 2012 05:24 | #1 For simply blurring water in streams and falls is a ten stop overkill? Would 6 stop be a better choice? Sam
MasterMace Member 33 posts Joined Oct 2010 More info | Jul 12, 2012 07:37 | #2 Depends on how light it is and how fast the water flows. Most of the waterfalls I've shot lay in the shade and on f11 I have 1/40 or 1/60 speed without filter. Usually I start of with a 6 stop.
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jul 12, 2012 17:19 | #3 Yea, I say start with a 3 and 6 stop. [Gear List | Flickr
JoeRavenstein Goldmember 2,338 posts Likes: 1 Joined Mar 2010 Location: E Tx More info | Jul 12, 2012 17:23 | #4 It wasn't included but consider acquiring a high quality variable density filter and choose how much blurring of water you wish. Canon 60D,18-55mm,55-250mm,50mm compact macro, AF ext tubes. Sigma 8-16mm uwa, 18-250mm, 85mm F1.4, 150-500mm
SteveJa Goldmember 2,137 posts Likes: 23 Joined Dec 2008 Location: Nebraska More info | you wll find that you will want from 2 or 3 stops up to 10 stops.
elogical Goldmember 1,217 posts Joined Aug 2010 Location: St Paul, Minnesota More info | Jul 12, 2012 19:36 | #6 I haven't bought a good ND filter yet myself but I went through the same questions when I started shopping around for one and I started to realize that the 10-stop filters I was looking at were probably too much.
Tpfer Member 44 posts Joined Mar 2012 More info | I wanted to do the water blurr too and decided to get:
Mark-B Goldmember 2,248 posts Likes: 10 Joined Jul 2007 Location: Louisiana More info | Jul 14, 2012 15:30 | #8 Yes, 6 stops would be a better choice. In the middle of a bright day, I might use my 6 stop for a 20 second exposure and my 10 stop for a 2 minute exposure. You can always get those times up or down by adjusting aperture and ISO, but the 10 stop will always be considerably more. Mark-B
| Latest registered member is slipper1963 1444 guests, 172 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
