Thread started 12 Jul 2012 (Thursday) 14:02
Umbrella shaft clamp?
timnosenzo
Jul 12, 2012 14:02 |  #1
Not sure if something like this even exists, but I figured I'd ask. :)
My Profoto D1's use a friction mount for an umbrella shaft, which is fine most of the time, but when you're outside and there's a little wind it can pretty easily pull the umbrella out of the mount.
I'm wondering if a small clamp exists that I can tighten on to the umbrella shaft so it can't slide out.
Here's a photo of the back of the light so you get an idea. I'm hoping to clamp it on the backside of the light shown here (obviously I would have to push the umbrella through a bit more).
IMAGE: http://www.timnphotos.com/Daily-Photo/June-2012/i-KqNmbPG/0/L/PAD06012012-L.jpg
Thanks for your help!
rrblint
Gallery: 84 photos
Joined May 2012
Jul 12, 2012 14:14 |  #2
Seems to me that a standard(very small) C-clamp would get the job done, if you can't find something that is purpose-made.
Mark
KirkS518
Joined Apr 2012
Jul 12, 2012 16:08 |  #3
You could also drill through the shaft, and insert a cotter pin/nail/stick. On the even-lower tech side, would a hose clamp or even rubber band work on the very end?
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
989 views & 0 likes for this thread, 3 members have posted to it.
1050 guests, 115 members online
