Thread started 15 Dec 2005 (Thursday) 08:08
L series lenses, which filters?
Neilyb
Gallery: 23 photos
Dec 15, 2005 08:08 |  #1
Lets say I bought an 17-40mm....which I am soooooo close to doing. Would it really be worth sticking on a cheap filter, lets say Hoya CP (the cheapest one), as the 77mm filters cost a fortune..(over £50 for a cheapest one) ...or would this render the greatness of the lens a bit useless?
http://natureimmortal.​blogspot.com (external link)
http://www.natureimmor​tal.com (external link)
malcolmx
Dec 15, 2005 08:14 |  #2
Inmho filters on digital cameras are not as usefull as on film . cs2 will give all you need except for polarisers . shoot two (or more)different exposures of the same shot and with a bit of manipulation this can produce some very good effects .saves all that fumbling about with plastic and glass and no loss of light
:D MALCOLM
LRPS EOS IDSMK2 +BITS
Andy_T
Joined Jan 2003
Dec 15, 2005 08:15 |  #3
Simply for protection, I put a 77 mm MRC B+W UV filter that cost about 50 EUR on my 80-200/2.8 ... you might try to compare prices from different dealers.
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
Neilyb
Gallery: 23 photos
Dec 15, 2005 08:18 as a reply to  @ Andy_T's post |  #4
It's going to pricey whatever I do right! I guess I can live without A CPL for a while.... :(
Malcomx, I ditched my Cokin filters once i started playing with the exposure setting of Raw, now I just layer two pics in PS....I love RAW!
lomond
Joined Apr 2004
Dec 15, 2005 08:26 |  #5
I'll probably get roasted alive for this but I think this is the one time when a cheap filter might be better than no filter at all.
I'm talking about a CP filter. You can't replicate that in PS.
I use a relatively cheap CP on my 17-40 and the results are OK. ( At least no one has said " Look at that image, you must be using a cheapo CP )
Maybe one day I'll get a Lee CP. ?! :lol:
Cameron........My Images (external link)
vjack
Dec 15, 2005 08:47 as a reply to  @ lomond's post |  #6
Before buying a filter for protection, read this: http://www.luminous-landscape.com/columns/​sm-feb-05.shtml (external link)
Canon 20D
Canon EF-S 10-22mm f/3.5-4.5 USM
Sigma 18-125mm f/3.5-5.6 DC
Tamron 28-75mm f/2.8 XR Di LD
Canon EF 50mm f/1.8 II
Canon EF 70-200mm f/4L
Canon EF 100-400mm f/4.5-5.6
L IS
Canon Speedlite 430EX
Manfrotto 3021BPRO; Kirk BH-1 ballhead
Canon Pixma 4200
< see my gallery (external link) >
lomond
Joined Apr 2004
Dec 15, 2005 09:00 as a reply to  @ vjack's post |  #7
I don't think he's talking about protection.
He mentions a CP filter which should only be used for a specific reason, not protection.
vjack
Dec 15, 2005 09:04 as a reply to  @ lomond's post |  #8
Yes, but someone else brought up UV filters so I wanted to make sure.
Canon 20D
L IS
Canon Pixma 4200
lomond
Joined Apr 2004
Dec 15, 2005 09:14 as a reply to  @ vjack's post |  #9
You're quite right, so they did.
jjonsalt
Dec 15, 2005 09:53 as a reply to  @ lomond's post |  #10
I only use Heliopan or B+W filters. However, except for the fact that the rings are aluminum rather than brass (and thus prone to seizing) I have read, on good athority, that in the case of CPs that the modestly priced Tiffen filters are (distortion wise) top rate.
RobKirkwood
Dec 15, 2005 09:57 as a reply to  @ lomond's post |  #11
The 17-40mm is maybe a bit of a special case, as it's only fully weather sealed once it has a filter on the front - could be important factor in some situations, like dusty or wet.
Rob
Neilyb
Gallery: 23 photos
Dec 15, 2005 09:59 as a reply to  @ jjonsalt's post |  #12
I guess my question is: Will using a cheapo filter UV or CP have a detramental effect on the images the lens produces (beariing in mind the not using a filter at all argumant...) :) I ask as a £550 lens becomes a £600+ lens if using cheapo filters....it becomes a £700= lens if using High Quality Coated whatever lenses...
lomond
Joined Apr 2004
Dec 15, 2005 10:26 as a reply to  @ Neilyb's post |  #13
Neil, see my previous post, but yes all filters will have a slight detrimental effect ( some worse than others ). If you can't stretch to the more expensive don't worry. I use a Hoya CP ( £58 from WarehouseExpress) on my 17-40 and I have no complaints.
20D_Newbie
Dec 15, 2005 10:30 |  #14
IMO, any filter will impact the image. Whether it is deterimental will have to be determined by you.
Canon EOS 7D with BG-E7 battery grip, EOS 40D with BG-E2 battery grip, Canon 20D, Canon EF 70-200mm F2.8L IS, Canon EF 24-70mm F2.8[COLOR=#ff0000]L, EF 300mm F4L IS, EF 400mm F5.6L, EF-S 17-40mm F4.0L, Canon Speedlite 580EX
Neilyb
Gallery: 23 photos
Dec 15, 2005 10:56 as a reply to  @ 20D_Newbie's post |  #15
Cheers guys!
2,836 views & 0 likes for this thread, 15 members have posted to it.
2246 guests, 136 members online
