I am look for a tutorial that explain how I can use content aware fill with a layer or just content aware to remove cabinet from wall. Can someone please help. Thanks
extrememc Senior Member 597 posts Joined Oct 2005 More info | Jul 15, 2012 04:09 | #1 I am look for a tutorial that explain how I can use content aware fill with a layer or just content aware to remove cabinet from wall. Can someone please help. Thanks Image hosted by forum (605884) © extrememc [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Photography is an expression of the mind!!!!!!!!!!!!!
saea501 ... spilled over a little on the panties More info | Jul 15, 2012 06:29 | #2 Here.....duplicate layer, selected them then inverted the selection and cloned the background. You might want to put a new background in.
Remember what the DorMouse said.....feed your head.
Jul 15, 2012 10:26 | #3 saea501 wrote in post #14718583 Here.....duplicate layer, selected them then inverted the selection and cloned the background. You might want to put a new background in. Looks like you all had a good time.
What tool did you use to selection them. I have tried lasso but it seems that you have to be exact to get a good selection. My thought on fixing this was make a separate layer with the background color then brush the subject or background backing. Photography is an expression of the mind!!!!!!!!!!!!!
jmharrison Hatchling 8 posts Joined Jul 2008 More info | Jul 15, 2012 10:44 | #4 I would go with the quick selection tool, then refine the mask edge. 5DIII,5D,17-40,24-105,70-200/F4IS,85/1.8,100/2.8
DThompson Goldmember 4,062 posts Likes: 422 Joined Feb 2008 Location: Georgetown, Ky More info | I used the Quick Selection Tool to select everything but the people. Cleaned up in a couple of spots by holding Alt to subtract from the selection. Then ctl+j to copy the selection to its own layer. Locked Transparent pixels on this layer. Turned off the Background layer. With the new layer selected I used the Lasso tool to select the cabinet, clock, and bar across the top (shown by the red area). You don't have to worry about going down into the transparent section as they are locked. I then pressed shf+F5 and chose Content Aware and pressed ok. Deselect. Turn Background back on. You can add a layer mask to the duped layer to clean up if needed. Image hosted by forum (605912) © D Thompson [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Dennis
Jul 16, 2012 10:16 | #6 D Thompson wrote in post #14719279 I used the Quick Selection Tool to select everything but the people. Cleaned up in a couple of spots by holding Alt to subtract from the selection. Then ctl+j to copy the selection to its own layer. Locked Transparent pixels on this layer. Turned off the Background layer. With the new layer selected I used the Lasso tool to select the cabinet, clock, and bar across the top (shown by the red area). You don't have to worry about going down into the transparent section as they are locked. I then pressed shf+F5 and chose Content Aware and pressed ok. Deselect. Turn Background back on. You can add a layer mask to the duped layer to clean up if needed. Sometimes Content Aware may not give the best on first try. Undo and apply again and it may work better. The red outline is what I selected with the Lasso tool for the Content Aware Fill. How do you Lock Transparent pixels on the copied layer? Photography is an expression of the mind!!!!!!!!!!!!!
DThompson Goldmember 4,062 posts Likes: 422 Joined Feb 2008 Location: Georgetown, Ky More info | Jul 16, 2012 13:02 | #7 extrememc wrote in post #14723753 How do you Lock Transparent pixels on the copied layer? Just to the top of your layers - click on the checkerboard square. Image hosted by forum (606084) © D Thompson [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Dennis
Jul 16, 2012 14:04 | #8 Ok so I been working through the steps that were posted. Here my results not my final edit though. Have a few problems. Content aware is not selecting the right color to fill. I think it would be easier to replace the BG with one color but still be about to brush back in the detail of the subjects using a layer masking. How can that be achieved? Image hosted by forum (606097) © extrememc [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Photography is an expression of the mind!!!!!!!!!!!!!
DThompson Goldmember 4,062 posts Likes: 422 Joined Feb 2008 Location: Georgetown, Ky More info | Jul 16, 2012 14:55 | #9 Not sure why you're getting those results. After I used the Quick Selection tool to copy the Background to its own layer and locked transparent pixels, I made one selection like I showed and Content Aware Fill did a nice job. The results I got above only took a few minutes to accomplish. Dennis
DThompson Goldmember 4,062 posts Likes: 422 Joined Feb 2008 Location: Georgetown, Ky More info | Maybe this will help show a little better.
This is the final after turning Background Layer back on. It still needs a little clean up, but it shouldn't take too long at all. This whole process only took a few minutes. You should be able to make the initial selection better by working on the original.
Dennis
Jul 16, 2012 15:56 | #11 D Thompson wrote in post #14725251 Maybe this will help show a little better. Top Left - Using the Quick Selection tool to select the background. Top Right - is the background copied to its own layer Bottom Left - Using the Lasso tool to select for Content Aware. Bottom Right - After using the Content Aware Fill. The white areas are actually transparent in Photoshop.
What you think? Image hosted by forum (606122) © extrememc [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Photography is an expression of the mind!!!!!!!!!!!!!
DThompson Goldmember 4,062 posts Likes: 422 Joined Feb 2008 Location: Georgetown, Ky More info | Jul 16, 2012 16:31 | #12 extrememc wrote in post #14725361 What you think? Looks pretty good from here! Dennis
Jul 16, 2012 16:37 | #13 D Thompson wrote in post #14725567 Looks pretty good from here! Thanks for the help! Photography is an expression of the mind!!!!!!!!!!!!!
DThompson Goldmember 4,062 posts Likes: 422 Joined Feb 2008 Location: Georgetown, Ky More info | Jul 16, 2012 17:08 | #14 extrememc wrote in post #14725602 Thanks for the help! Anytime and glad to. Dennis
subwaysurfer Member 58 posts Joined Feb 2010 Location: Long Island, New York More info | Jul 16, 2012 19:17 | #15 Outstanding tutorial. Mike
| Latest registered member is Frankie Frankenberry 1834 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
