Thread started 17 Jul 2012 (Tuesday) 05:50
Incompatability 70-300L and 2x ext III
Actionphoto
Jul 17, 2012 05:50 |  #1
Hi All,
A friend has just purchased a Canon 70-300 L lens and a Canon 2X Extender III to use on her 50D.
However the pair will not work together.
I have just researched a Canon compatability list and it said they are incompatable.
Can any tell me why they are incompatable and is there a way to overcome the problem.??? ? vmad
Cheers
Bob.
Canon 5D Mk II
EF 24-105 f4 ; EF 70-200. EF 100-400 ; EF 50 f1.8; EF 100 f2.8 macro; 580EX II; Manfrotto 055B w/488CR2 ball head; Manfrotto 680B Monopod w 234CR2 mono head; Hoya PRO Polariser, UV & ND8 filters; Kenko 1.4x Extender; EPSON 3800; Panasonic Lumix LX7.
Personalised Photograhic Tuition Courses.
p32shooter
Jul 17, 2012 06:26 |  #2
the lens is f4-f5.6 which will focus on 50d
add 2xtc an it starts at f8 which 50d won't be able to use to focus - it needs a 1d something body[not 1dx either]
you might be able to tape pins on lens and extend the range some with the 50d but i doubt that it will work on the long end
wants for Ls :D , now have 400do;500f4is,600f4 :cool::cool: off to birding and airshows:):):)
SMP_Homer
Gallery: 29 photos
Jul 17, 2012 06:30 |  #3
when you say incompatible, do you mean it won't physically mount, or it will but not work electronically?
EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
Sig35A, Sig50A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
100-400L, 100L, 100/2, 300 2.8L, 1.4x II / 2x II
600EX-II X3, 430EX-III X3
coldcuts113
Jul 17, 2012 06:41 |  #4
70-300l will not work with canon ext.
Nikon D4, Sony RX10, Sony RX100.
Past Gear: (most recently) 5D3, L's, etc.
Keyan
Joined Mar 2011
Jul 17, 2012 06:55 |  #5
The rear lens element on the 70-300L protrudes too far out of the lens and will hit the element on Canon Extenders, the only option are to use the Kenko extenders, such as this one:
http://www.adorama.com​/KN14XPEOSDGX.html (external link)
Using this extender will result in one stop loss of light, meaning the lens will only have f5.6-8 through the zoom range. AF can still work in well lit cases, but my understanding is that it is slower and possibly less accurate, and it will only work on center point. I have debated getting this, but I just got the lens so right now I am working with it as it comes and then deciding if I really need that extra reach. The lens is so sharp that you get a ton of "crop zoom" ability with still great looking images.
Using a 2x extender will result in 2 stops loss of light, meaning it will be f/8-11 through the zoom range and there will no autofocus at all.
Not sure why the red face, it is clearly listed on the website, every review of the lens mentions it, and the manual which you can download before buying the lens also states that it doesn't work with Canon extenders.
That said, the lens without any extender madness is fantastic and I am really enjoying mine.
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
sebr
Jul 17, 2012 08:45 |  #6
I have used a Kenko 1.4x with the 70-300L. AF works on the 5D2, but it hunts. There is also some IQ loss, but results are still OK. In principle, AF and IQ should be better with the 1.4x than with the 2x because you loose light and have a higher magnification.
Sebastien
5D mkIII ; 17-40L ; 24-105L ; 70-200L II ; 70-300L ; 35L ; Σ85/1.4 ; 135L ; 100macro ; Kenko 1.4x ; 2x mkIII ; 580EXII
M5 ; M1 ; 11-22 ; 18-150 ; 22/2.0 ; EF adapter; Manfrotto LED
Benron Tripod; ThinkTank, Lowepro and Crumpler bags; Fjällräven backpack
electronpusher
Gallery: 39 photos
Joined Mar 2012
Jul 17, 2012 11:37 |  #7
I use the Kenko 1.4/70-300L combo on my 5DII now and then. The 1.4 TC may affect the IQ slightly, dependng on the shot. I've had good success focusing outdoors, using the center (most sensitive) focus point and back-button focusing.
Canon 5D mkIV | Canon 1D mkIII | 24-70mm f/2.8 II L | 70-200mm f/2.8 II L | 70-300mm f/4.5-5.6 L | 17-40mm f/4 L |100mm f/2.8 L Macro | 50mm f/1.8 II | Kenko 1.4x Teleplus Pro 300 DGX | 600EX-RT
Contax RTS
| Zeiss T* 18mm f/4 | T* 35mm f/2.8 | T* 50mm f/1.4 | T* 85mm f/1.4 | T* 135mm f/2.8 | T* 200mm f/3.5 | Fotodiox chipped adapters, Contax/Canon
mike1812
Jul 17, 2012 15:32 |  #8
I just picked up the Kenko 1.4X converter this weekend and am seeing the same results mentioned above, but on a 7D - good success focusing outdoors (and somewhat indoor - tried it at the camera shop pre-purchase and it did well in bright fluorescent lighting).
EF 135L | EF 70-300 L | ST-E3-RT | (4) Einstein E640s | Sekonic L-758 | Sony A7RII Gripped | Sony A7RIII Gripped | Sony 16-35GM | Sony FE 55 f/1.8 | Sony FE 85 f/1.4 GM | Sony FE 100-400GM | Sony 1.4x | Sony HVL-60M | Sigma MC-11 | Flashpoint Xplor AD600 | Flashpoint AD200 (2)| Flashpoint AD360 | plus too many doodads to list
ed ­ rader
"I am not the final word"
Jul 17, 2012 15:36 as a reply to  @ mike1812's post |  #9
the OP never asked about a 1.4 TC.
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
mike1812
Jul 17, 2012 16:53 |  #10
ed rader wrote in post #14730679 (external link)
Those of us who posted about the 1.4X tele were offering "a way to overcome the problem" (quote from the OP in post 1 above).
Actionphoto
Jul 18, 2012 06:27 |  #11
I finally got to check out my friends dilema today. Yes the 70-300L and the 2X extender do not physically go together. The protruding lens on extender fouls with the rear lens in the 70-300 even at maximum zoom.
However I tried my Kenko extender on the 70-300 and it fits and works perfectly. No doubt the image quality on the Canon extender would be superior but the results with this combination looked quite acceptable.
So all is not lost; my fiend is now going to buy a 400mm f5.6L prime lens to go with the Canon 2x extender and also purchase a Kenko 2x extender to go with the 70-300L.
Thanks for all your comments.
Canon 5D Mk II
nubu
Jul 18, 2012 09:00 as a reply to  @ Actionphoto's post |  #12
I hope your friend will not be to unhappy with the resulting 800mm f/11 !!! lens -> dark, manual focus....
5DII/III,7D,m
EF14/2.8LII|EF24/1.4LI​I|EF35/1.4L|S35/1.4A|EF40/2.8|S50/1.4A|MPE6​5/2.8|EF85/1.2L|EF100/​2.8LIS|EF135/2L|EF300/​2.8LIS|EF500/4LIS|Zeis​s500/8|EF1.4xIII|EF2xI​II|EF8-15/4L|EF24-105/4LIS|EF70-200/2.8LISII
Invertalon
Jul 18, 2012 09:37 |  #13
You have to use 3rd party companies when you plan to use extenders outside the list of compatible lenses. I used a Tamron SP Pro 1.4x TC with my 50mm f/1.8 for example long ago (just to try it, never did use it again). Not possible with the Canon model.
You would need something like Kenko or Tamron TC to use with lenses you can't with Canon. But expect to lose AF over f/5.6
-Steve
Facebook (external link)
Keyan
Joined Mar 2011
Jul 18, 2012 12:54 |  #14
Sounds like she really wants one of these..
http://www.bhphotovide​o.com …other-of-All-L-Lenses.jsp (external link)
Cameras: 7D2, S100
gocolts
Jul 18, 2012 14:25 |  #15
mike1812 wrote in post #14730660 (external link)
Have any examples you could post? I'm interested in this lens- but only if I could use it with a 1.4TC in a pinch on my 7D, and the results were decent. The IQ of this lens is so good on it's own, I'm hoping the IQ doesn't take a big hit when adding a 1.4TC..like the 70-200 II.
3,193 views & 0 likes for this thread, 12 members have posted to it.
844 guests, 108 members online
