Setting my Speedlite 430 EX Mk II in Manual Flash Mode to work wirelessly went well. Even when I set it up wirelessly with a ratio of 1/32 Pop-up Flash : 1/1 on the 430 EX Mk II.
But I wanted to experiment and see what combinations looked best. Don't know if this is normal but the 'remote' 430 EXII can be set to anything from 1/1 to 1/128th = Perfect.
But if I use the pop-up flash on the 7D at the same time I can have any combination of power level SO LONG as the Pop up flash 'ratio' number is 1/4 or smaller!
eg I can set up the 430 as 1/1 and the Pop-up at 1/16 or 1/8 or 1/4 .. But it won't let you increase the power level on the 7D i.e. to say 1/2?
Is this working as it should?
