Thread started 18 Jul 2012 (Wednesday) 01:19
How to dismantle a UV filter?
maverick75
Joined May 2012
Jul 18, 2012 01:19 |  #1
Does anyone know how to do it? I did a google search but didn't come up with much.
I need a filter spacer and what better way to get one than to take apart a UV filter that I'm not using :D
This site shows it can be done, but doesn't say how.
http://enchantingkeral​a.org …s-reversal-filter-cap.php (external link)
nellyle
Joined Jan 2012
Jul 18, 2012 01:46 |  #2
Not saying you can't or shouldn't, but how about getting hold of a stepping ring for a few $$?
5D3, 7D2, 1D3, 40D, 14 f2.8 Samyang, 17-40 L, 28-80 L, 70-200 2.8ii L, 200 2.8ii L, 200-400 L, 1.4 ii,
http://chris-stamp.smugmug.com/ (external link)
maverick75
Joined May 2012
Jul 18, 2012 01:52 |  #3
Never knew what they were called! I'll check them out :)
I kept searching for "52mm to 52mm step ring" and "52mm spacer" and not finding anything, but by changing it to "stepper" I found some!
noisejammer
Jul 18, 2012 03:01 |  #4
Seems your problem is resolved, but dismantling a UV filter is reasonably easy.
All you need is an optical wrench... then adjust it to suit the notches on the glass retaining ring and unscrew the retainer. The trick is having the optical wrench... I use this one. (external link) You would be well advised NOT to try this without a proper wrench!
B+W and some other high end models have the retainer ring on the inside.
Some inexpensive filters (Quantaray among them) use a circular spring-clip... these are easy to remove with a jeweler's screwdriver.
Several cameras and more glass than I will admit to.
ZoneV
Jul 18, 2012 03:45 as a reply to  @ noisejammer's post |  #5
And on some filters the filter glass can not be dismatelt because the filter is not hold be retainer ring or spring clip, but bent metal :-/
I dissmanteled some filters to get the glass for my infrared EOS Rebel XT with interchangable filters.
DIY-Homepage (external link) - Image Gallery (external link) - Gear List
ScubaDude
Joined Sep 2011
Jul 18, 2012 04:51 |  #6
Do you have a hammer?
Canon [7D & BG-E7 grip] [T1i & BG-E5 grip] [400mm f/5.6L] [50mm f/1.8 II] [18-55mm f/3.5-5.6 IS]
Induro [AT313 tripod] [AM25 monopod] [GHB2 gimbal head]
My Flickr page (external link)
maverick75
Joined May 2012
Jul 18, 2012 10:55 |  #7
Well I managed to remove it using two screws, using the technique of the spanner wrench. Thanks noisejammer! :)
Now I can put that $10 I was gonna spend on the spacer toward the lens fund. May not sound like a lot but $10 here and $10 there adds up real fast!
IMAGE: http://img690.imageshack.us/img690/2958/img5184xk.jpg
KCMO ­ Al
Jul 18, 2012 16:46 |  #8
I accomplished this by dropping my 645 camera to the ground from about 4 feet. It takes some effort as you have to align it precisely so it falls directly on the corner of the filter. If done correctly, the filter will shatter and you can then just pick out the pieces. Having the camera body hit first will lead to failure of this effort with other unintended results.
Film: Leica M-4, Elan 7E, Rolleiflex 2.8f, Pentax 645 -- Digital: Canon Pro-1, EOS 5D Mk III
EOS Lenses: Sigma 24-70 f2.8 EX - Canon EF 17-40 f4.0L - Canon EF 24-105 f4.0L - Canon EF 35 f1.4L USM - Canon EF100-400 f4.5-5.6L IS USM - Canon EF100 f2.8 Macro - Other stuff: MR 14EX - 430EX - 580EXII - ST-E2 - TC1.4x - TC-80N3
Tigerkn
Gallery: 10 photos
Jul 18, 2012 16:54 |  #9
What is the filter spacer for Mav.?
I just got an idea after seeing this. Thanks!
Website (external link) | Facebook (external link) | Instagram (external link) | Gears (external link)
maverick75
Joined May 2012
Jul 18, 2012 17:04 |  #10
Tigerkn wrote in post #14736384 (external link)
I have a ND and a IR filter, but they were hitting the front element on my lens. I was just letting them go on 180 degrees. But now I can fully seat them and not worry about them falling off.
What do you have in mind? :D
Tigerkn
Gallery: 10 photos
Jul 18, 2012 17:13 |  #11
Can't tell you now. I will show you when I get it done :)
touji
Joined Oct 2011
Jul 18, 2012 23:28 |  #12
I didn't know you could dismantle them like this. I just took a hammer to mine vmad
5D Mark III | Gripped 60D | EOS M | Sigma 30mm f1.4 | Canon 24-70mm f2.8L II | Canon 8-15mm f4L | Canon 50mm f1.8II | Canon 100L | Tamron 150-600mm
Shooting Since 10/16/2011!
FlyingPhotog
Cream of the "Prop"
Jul 18, 2012 23:34 |  #13
ScubaDude wrote in post #14733451 (external link)
bw!
Jay
4,082 views & 0 likes for this thread, 9 members have posted to it.
2778 guests, 138 members online
