Thread started 16 Dec 2005 (Friday) 02:26
50mm 1.4 Hood & Lens Cap Question
rcanzano
Joined Nov 2005
Dec 16, 2005 02:26 |  #1
Ok, got a 50mm 1.4 and bought a hood for it as well as a clear filter to protect the lens. The filter came with a cap.
So here's the problem. With the hood in place I can't get my fingers in there to remove the cap. So, everytime I want to remove the cap I have to remove the hood.
Is there some kind of cap available with a tab or something that I can use?
Silly problem, yes I know, but thought I'd ask.
My Gear: Canon 1D Mark IV • Lenses, Lights, & Stuff • The Brand New Zano Studios! https://photography-on-the.net/forum/showthre​ad.php?t=414511
blue_max
Dec 16, 2005 03:00 |  #2
The original canon lens cap is not too bad. It helps to tip the lens, so the cap falls out when you squeeze the tabs.
Have you bought a 'thin' filter with no front thread on it? If that is the case, I can see that being a pain. However, it could probably be left off during a session (as you have the filter to protect the lens, along with the hood).
Graham
Lamb dressed as mutton.
rcanzano
Joined Nov 2005
Dec 16, 2005 10:05 |  #3
Yeah, I have the thin one with no threads. But, even if I didn't have the filter on and was using the Canon cap with the lens with the hood, I still couldn't get my fingers in there.
Chazs
Joined Aug 2002
Dec 16, 2005 10:09 |  #4
Would a larger lens cap fit on (and stay on) the hood itself? Take it to a camera store and test a few out.
SkipD
Joined Dec 2002
Dec 16, 2005 10:15 |  #5
The simple solution is to ignore the filter unless you are in a really harsh environment and just use the Canon lens cap.
I've never used filters on any of my lenses for 40+ years and the lenses that I purchaed in the 1960's and still own all have pristine glass in them. The outer surfaces have paint worn off from the extensive use they've seen, but the glass has never suffered. I do use lens hoods always. Lens hoods provide all the protection I have ever felt that I needed, and the quality of my old lenses is proof of that.
Skip Douglas
rcanzano
Joined Nov 2005
Dec 16, 2005 10:27 |  #6
That's an interesting idea, putting it on the hood itself, didn't even think of that. Though without any kind of ridges on the hood, I don't know if would stay on.
I had been reading the filter/no filter debate, and for now I'm going with double protection, but as I mentioned before, even without the filter you still can't get your fingers in there to release the cap. It's just a tight fit.
Many people have the "Nifty Fifty" what are they doing about the cap thing?
Perhaps I'm beeing too careful?
Luckie8
Dec 16, 2005 10:32 |  #7
You can purchase a Tamron squeeze type lens cap at your local camera shop.
Feedback
ghaleon109
Dec 16, 2005 10:45 |  #8
I have the same problem with my 70-200mm and I have small fingers! :evil:
Right now I just deal with the extra time it takes to take off/put on the hood and put on/pull off the lens cap. I'ts not that bad in terms of time consumption... just kind of redundant and annoying.
But I just leave the cap off when I'm out on a shoot, if you have a UV filter on there you don't have to worry about it, just take off the cap when you go out and put it back on when you get back. That way you only have to deal with the problem twice ;)
But if you can find a 58mm Tamron lens cap I'm sure that would help. The cap for my 28-75mm is great, the hood doesn't even get in the way. :)
--Mike Hughes--
20D and a lens or two... :)
Mike ­ K
Joined Apr 2001
Dec 16, 2005 10:45 |  #9
Tamron or Nikon lens caps are your answer
http://www.fredmiranda​.com/forum/topic2/1758​56/0#1428185 (external link)
Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
rcanzano
Joined Nov 2005
Dec 16, 2005 10:50 |  #10
Thanks, I'll have to look into the Tamron caps.
bolantej
Dec 16, 2005 15:58 |  #11
i think someone like optech or pelican makes hood covers that are neoprene and fit over the hood so you don't have to use the lens cap at all. kinda looks like on of those old beer can insulation things.
DimensionZero
Dec 16, 2005 16:57 |  #12
what about those lens cap tring things?
You know where one end has a sticky part that goes on the cap and the other end normally ties on to the camera? Why not get one of those and just cut off a bit of the string and just pull on it to remove the cap?
You could always DIY one too. A little string, some tape.. heh.
Ken
Canon 7D
Sigma 10-20mm f4-5.6 EX DC | Tamron 28-75mm f2.8 XR Di | Canon 50mm f1.8 | Manfrotto 3021BN w/486RC2
deviantArt (external link) | my Blog (external link)
Chazs
Joined Aug 2002
Dec 16, 2005 17:02 as a reply to  @ DimensionZero's post |  #13
Here's what you're looking for - - a center pinch lens cap. Saw one earlier today at our local store.
http://www.bhphotovide​o.com …EG&addedTroughT​ype=search (external link)
[edit] oops, should have linked to the 58mm size[/edit]
malla1962
Joined Jul 2004
Dec 16, 2005 17:08 as a reply to  @ Chazs's post |  #14
I have that problem with most of my lenses.:D
Mark_Cohran
Joined Jul 2002
Dec 16, 2005 17:15 |  #15
Yep, the center pinch caps work great when using a hood.
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
5,988 views & 0 likes for this thread, 23 members have posted to it.
2239 guests, 127 members online
