Can you post what settings you found to be sharp Jpegs images from 7D
1) Sports
2) Portrait
3) Landscape
Thx for your time.
TeamSpeed 01010100 01010011 More info | Jul 18, 2012 17:42 | #2 There are 3 methods I use to obtain what I consider sharp images from my 7D bodies (or any body actually). Past Equipment | My Personal Gallery
Jul 18, 2012 17:49 | #3 TeamSpeed wrote in post #14736595 The great thing about this is that others will have different ideas and techniques, with most of them probably being better or equal to what I do. I doubt that. Teamspeed is the resident expert on the 7D, have you perused the FAQ he put together on it?
lannes Goldmember 4,370 posts Likes: 8 Joined Dec 2009 Location: Perth, Australia More info | Jul 18, 2012 18:17 | #4 TeamSpeed wrote in post #14736595 There are 3 methods I use to obtain what I consider sharp images from my 7D bodies (or any body actually). I do not have the camera sharpen the images via picture styles, I turn those down to 2 or 3 and not past. 1) I microadjust my lenses 2) I try to shoot +1/3 to +2/3 past wide open 3) I clean up the image for whatever is needed first, and I USM or high-pass sharpen nearly the last step The great thing about this is that others will have different ideas and techniques, with most of them probably being better or equal to what I do. TeamSpeed, does this apply equally to jpeg and raw ? 1Dx, 1DM4, 5DM2, 7D, EOS-M, 8-15L, 17-40L, 24 TSE II, 24-105L, 50L, 85L II, 100L, 135L, 200L f/2.8, 300L f/4, 70-200L II, 70-300L, 400Lf/5.6
TeamSpeed 01010100 01010011 More info | Jul 18, 2012 18:29 | #5 lannes wrote in post #14736712 TeamSpeed, does this apply equally to jpeg and raw ? For jpeg would you increase the sharpening in the picture style ? If you are only shooting JPG, then you would use the picture styles and the sharpening option would be more aggressive. However as we have seen with the 5D3, and also comparisons to 4/3rd cameras, like the OM line, the JPG engine from Canon needed quite a bit of improvement. I wouldn't go past the middle setting though, I am of the opinion that you leave a little bit of wiggle room for post processing and flavoring your pictures to taste there instead of SOOC. Past Equipment | My Personal Gallery
Jul 18, 2012 18:31 | #6 TeamSpeed wrote in post #14736595 The great thing about this is that others will have different ideas and techniques, with most of them probably being better or equal to what I do. FAT chance.. Canon 6D | Canon 7DII | 17-40 f/4L | 24-105 f/4L | 70-300 4/5.6L |100mm f/2.8L macro | 50mm 1.4 | 580exII | 2 - 430exII |
Once I get my hands on a 5D3 (or even better a 1DX), I would think shooting JPG would be a great option again. But for now, raw provides a much better result on the legacy bodies over the OOC JPGs. I shoot Raw JPG, and if I like the JPG results, I will use them accordingly. However, if I dont like the results, I then work on the raw and convert, giving me a better starting point than the original OOC JPG.[/QUOTE wrote: = Once I get my hands on a 5D3 (or even better a 1DX), I would think shooting JPG would be a great option again. But for now, raw provides a much better result on the legacy bodies over the OOC JPGs. I shoot Raw + JPG, and if I like the JPG results, I will use them accordingly. However, if I don't like the results, I then work on the raw and convert, giving me a better starting point than the original OOC JPG. Recently read a thread where many felt the Jpeg images from the 5d III were equal to that of the 7D. Others commented they were happy with the Jpeg images. Hard to call it from that thread.
TeamSpeed 01010100 01010011 More info | Jul 18, 2012 21:16 | #8 I have LR3 and don't use it, I still use DPP and CS3. I hope others can pipe in here and help you, I won't even try because I would undoubtedly be wrong. Past Equipment | My Personal Gallery
rrblint Listen! .... do you smell something? More info | Jul 18, 2012 21:36 | #9 TeamSpeed wrote in post #14736595 I do not have the camera sharpen the images via picture styles, I turn those down to 2 or 3 and not past. TeamSpeed wrote in post #14737472 I have LR3 and don't use it, I still use DPP and CS3. I hope others can pipe in here and help you, I won't even try because I would undoubtedly be wrong. TeamSpeed...What is the purpose of NOT sharpening via picture styles in camera? Mark
rrblint Listen! .... do you smell something? More info | Jul 18, 2012 21:38 | #10 Forgot to mention I shoot exclusively in RAW. Mark
TeamSpeed 01010100 01010011 More info | Jul 18, 2012 22:01 | #11 It saves time, since DPP honors the picture style to set up the settings. I do sharpen via picture styles, but only values of 2-3 tops, and save the remainder of sharpening later after I edit the JPG. Past Equipment | My Personal Gallery
rrblint Listen! .... do you smell something? More info | Jul 18, 2012 22:06 | #12 TeamSpeed wrote in post #14737688 It saves time, since DPP honors the picture style to set up the settings. I do sharpen via picture styles, but only values of 2-3 tops, and save the remainder of sharpening later after I edit the JPG. Thanks tor the info! Mark
DanFrank Senior Member 380 posts Likes: 3 Joined Dec 2010 Location: Buffalo, NY More info | Does it make a difference using high-pass sharpening on RAW/JPEGS? Can you do it to either? Gear "A creative man is motivated by the desire to achieve, not by the desire to beat others"
apersson850 Obviously it's a good thing More info | It's also a question about what you are going to use your images for. For a quick post on Facebook or to send an e-mail showing something to somebody, you can use jpeg with the S (normal) setting on the 7D. Anders
TeamSpeed 01010100 01010011 More info | Jul 19, 2012 08:12 | #15 DanFrank wrote in post #14737796 Does it make a difference using high-pass sharpening on RAW/JPEGS? Can you do it to either? I don't believe there is a way to high pass sharpen a raw, unless some 3rd party tools allow it. It requires layering. I do it with the JPG in photoshop, I have it part of a general action where it cleans noise, adds a bit of contrast, a bit of saturation, some leveling, and then high pass. Past Equipment | My Personal Gallery
| Latest registered member was a spammer, and banned as such! 2778 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
