Thread started 16 Dec 2005 (Friday) 12:57
70-200mm f/4L OR 70-300mm f/4.0-5.6 IS
detzX
Dec 16, 2005 12:57 |  #1
I'm looking for a zoom lense and both of these have popped up on my radar. Which (in your opinion) is better, the L or the IS? They are both around the same price.
Amorous
Dec 16, 2005 13:05 |  #2
Well, the advantage with the L is that you can use f/4 at the whole range where you can only have f/5.6 at 300mm for 70-300mm. Besides, the build quality will be different. The only advantage of 70-300mm will be its reach (300mm).
My web site: http://kaitcilla.smugm​ug.com/ (external link)
Los Angeles area local photography group: http://lashooters.org (external link)
detzX
Dec 16, 2005 13:12 as a reply to  @ Amorous's post |  #3
the IS too, how much would I missing without this at 200mm?
jojohohanon
Dec 16, 2005 14:53 |  #4
How often, where you plan to use this lens, do you get 1/320th shutter or faster @ f/4. If often, you don't need IS. if seldomly, you'll wish you had it.
willg
Dec 16, 2005 15:00 |  #5
the images from the L are just stunning
5D, 300D, Tamron 17-35mm f/2.8-4, Canon 70-200mm f/4, 135mm f/2, 24-105mm f/4, 50mm f/1.4, Sigma ef 500 dg super, Canon 580EX
http://www.spideronthe​floor.com/ (external link)
GyRob
Dec 16, 2005 15:55 |  #6
i would say go with the L ok it has no IS but lets say you normaly use iso 100 pop it up to 200 iso thats like giveing you one stop of IS i.e double your shutter speed thats the way i look at things .
Rob
"The LensMaster Gimbal"
Jon
Joined Jun 2004
Dec 16, 2005 16:10 as a reply to  @ Amorous's post |  #7
Um. The disadvantage on the 70-300 is that you can only have f/4 at 70, not that you can only have f/5.6 at 300. You can set your aperture to f./5.6 at any focal length with either lens. I think what you meant to say was that you can't go any faster than f/5.6 at 300 (or anywhere much beyond 240 mm. You lose f/4 at around 120 mm as the maximum aperture becomes around f/4.5 indicated there, moviing to about f/5.1 or so at 180 - it actually gradually changes between f/4 and f/5.6, rather than taking abrupt steps as this implies). What you said sounds rather like you don't get f/5.6 at anything but 300.
If you shoot a lot in poor lighting conditions, you'll appreciate IS. If you can stay in the "safe zone" of above 1/250 with the 70-200, or above 1/500 with a lens in the 300 mm range, IS doesn't give you a lot of help. This, of course, assumes you aren't a caffiend.
Jon
Cocker Spaniels
1,698 views & 0 likes for this thread, 6 members have posted to it.
2246 guests, 127 members online
