Taking shots of a friend, but they are a bit too detailed. Could someone describe a way I could use CS5 to make the skin 'smoother'?
trailguy Senior Member More info | Jul 21, 2012 19:49 | #1 Taking shots of a friend, but they are a bit too detailed. Could someone describe a way I could use CS5 to make the skin 'smoother'?
stayhumble Goldmember 1,328 posts Joined Nov 2010 Location: Huntington Beach, CA More info | Jul 21, 2012 20:38 | #2 Permanent banlightroom is a lot easier for quick work such as this, and especially if you are just starting out. There are no rules for a good photograph and there are no excuses for a bad one.
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | Jul 21, 2012 20:41 | #3 I depends on what exactly you're trying to achieve... simply removing blemishes, etc does not require as aggressive retouching as glamour or fashion retouching. Here's a quick edit using dodging and burning (Curves adjustment layers); with time much more could be done such as balancing the lighting between the background and the subject.
I'm not wanting to create a perfect skin smoothness here (probably a bit too unrealistic). I am seeing more skin pores? on her cheeks than l like, and a bit too obvious lines in the forehead.
stayhumble Goldmember 1,328 posts Joined Nov 2010 Location: Huntington Beach, CA More info | Jul 22, 2012 13:15 | #5 Permanent banjust tone down clarity and sharpness a bit with LR. feather on your way out as to blend. There are no rules for a good photograph and there are no excuses for a bad one.
Jul 22, 2012 19:46 | #7 Thanks for the info. I went to that site and read what he did, I played with it a bit, but decided it was more than needed for this. I ended up using a bit of Gaussian blur, just on her face, and history brushing the blur back out of her eyes. I think it worked ok in this case.
Jul 23, 2012 03:57 | #8 I've got an action for this that I created from a tutorial I found some time ago, which gives pretty good results. Going from memory, it involves duplicating the picture, applying a high-pass filter, inverting it, gaussian blur and overlay mode. I can't remember the radiuses though. Keeps the texture but basically reduces micro-contrast, works like a charm. Plus you can play with the opacity to dial it down if you want. Fuji X-T4, 18-55 and 55-200 zooms, Samyang 12
Jul 23, 2012 09:28 | #9 I have an action too. Don't know if armis' action is based on this tutorial, but take a look.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Jul 23, 2012 11:35 | #10 Am I the only one bothered more greatly by the photographer missing the exposure than by her pores and wrinkles on the forehead being revealed by a sharp lens?!
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
chrisa Goldmember More info | Jul 23, 2012 12:51 | #11 Smoothed and lightened a little.
Jul 23, 2012 15:48 | #12 Wilt wrote in post #14757028 Am I the only one bothered more greatly by the photographer missing the exposure than by her pores and wrinkles on the forehead being revealed by a sharp lens?!
http://www.avidchick.com
Jul 23, 2012 18:59 | #13 Wilt wrote in post #14757028 Am I the only one bothered more greatly by the photographer missing the exposure than by her pores and wrinkles on the forehead being revealed by a sharp lens?! No; but then, that wasn't the OP's question, was it? Fuji X-T4, 18-55 and 55-200 zooms, Samyang 12
ScubaDude Goldmember 1,104 posts Likes: 7 Joined Sep 2011 Location: Waveland, MS More info | Jul 23, 2012 22:57 | #14 Permanent banThis method Canon [7D & BG-E7 grip] [T1i & BG-E5 grip] [400mm f/5.6L] [50mm f/1.8 II] [18-55mm f/3.5-5.6 IS]
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Jul 24, 2012 07:07 | #15 I think he forgets to use Gaussian blur. "I think the idea of art kills creativity" - Douglas Adams
| Latest registered member is Niagara Wedding Photographer 1251 guests, 148 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
