When I attempt to shoot a photo in Live View mode, the shutter does not open. All that happens is that it keeps attempting to focus.
Please help!
katz_jd Hatchling 3 posts Joined Jul 2012 More info | Jul 22, 2012 08:15 | #1 When I attempt to shoot a photo in Live View mode, the shutter does not open. All that happens is that it keeps attempting to focus.
rrblint Listen! .... do you smell something? More info | Jul 22, 2012 08:38 | #2 What are you trying to focus on and how close is it to the camera? Mark
Jul 22, 2012 09:07 | #3 rrblint wrote in post #14751612 What are you trying to focus on and how close is it to the camera? Do you see an image on the LCD screen? I'm trying to focus on an image perhaps 5 feet away. I do see the image in the LCD screen.
JohnfromPA Cream of the Crop 11,262 posts Likes: 1530 Joined May 2003 Location: Southeast Pennsylvania More info | Jul 22, 2012 09:18 | #4 In low light and depending on the lens focusing may not lock and you won't be able to take a picture. Try doing Live View in something well lit, perhaps outdoors. If that works then low light is your likely problem in which case I would bump up the ISO to get a smaller aperture.
Jul 22, 2012 09:25 | #5 John from PA wrote in post #14751708 In low light and depending on the lens focusing may not lock and you won't be able to take a picture. Try doing Live View in something well lit, perhaps outdoors. If that works then low light is your likely problem in which case I would bump up the ISO to get a smaller aperture. I took your advice and tried it outside, holding down the shutter button...it worked. I also tried it in a low light situation, again holding down the shutter button. After a few seconds it also worked.
oldvultureface Goldmember More info | You can also flip the AF-MF switch on the lens to MF and focus manually. You can use the magnify button as a focus aid to zoom in on your subject for easier focus. Page 120 in the manual.
| Latest registered member was a spammer, and banned as such! 2938 guests, 156 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
