Thread started 16 Dec 2005 (Friday) 18:36
Cobra 440AF Flashgun
imrtun
Dec 16, 2005 18:36 |  #1
Hi, I've been using this flash with my 20d. Another goodie I found under my dads bed (the other being a 38-76mm lens) and I'm quite concerned at the washed out exposures I've been getting. Is this flash too old for the camera or are there any special settings on the 20d that I've missed?
Thanks very much for your time.
Canon 20D - Canon 10-22 3.5/5.6 - Canon Speedlite 580EX - Canon 24-70 /2.8 - Canon 17-55/2.8 - Sigma 70-200 /2.8 - Sekonic L-358 - Bowens Esprit Gemini 500/500 - Bowens Travel Pak - 120cm Octobox
www.fotu.co.uk (external link)
PacAce
Joined Feb 2003
Dec 17, 2005 19:42 |  #2
I am not 100% sure but chances are that the flash only works in TTL mode and not the ETTL mode needed for your 20D. So that means that if you want to use this flash you'll need to set the camera on manual mode and set the proper aperture based on the flash-to-subject distance.
...Leo
malum
Joined Jul 2002
Dec 18, 2005 13:17 |  #3
I have the 700AF and it will only fire at full power on the 20D no matter what I set it to do.
You might also want to know that the wrong trigger voltage from the flash can kill your camera, so you should consider yourself lucky that you got away with it.
PacAce
Joined Feb 2003
Dec 18, 2005 14:26 as a reply to  @ malum's post |  #4
According to this site(http://www.botzilla.co​m/photo/strobeVolts.ht​ml) (external link), the 440AF is safe to use although, from what I understand, the 20D can handle voltages up to 250V.
...Leo
imrtun
Dec 19, 2005 10:03 |  #5
great, thanks for the information. It doesn't seem to matter what i set it to it's only acceptable at about f/22 which i don't want to use. Looks like I better start saving for a 430ex!
Tendy
Mar 20, 2011 10:13 as a reply to  @ imrtun's post |  #6
I know this is an old thread but I found this by googling about this flashgun and it brought me here! Anyone got this unit to work witg a 10D?
5D | 30D | Canon IXUS 265HS | Oppo Smartphone
My photo blog:
http://inventedeye.blo​gspot.com/ (external link)
My Photography Page
https://www.facebook.c​om/LarryShonePhotograp​hy (external link)
7,364 views & 0 likes for this thread, 4 members have posted to it.
2840 guests, 133 members online
