I don't see many comparisons with the 7D and the original 5D.
I cannot put the decision off much longer. I am expecting a small insurance payment and I will be able to spend around a thousand dollars to 1,500 or so. I currently have a 450D and 500D set of bodies. I will sell the 450D and that will give me an extra 300 or so since it only has 6000 shutter clicks and a long life in front of it.
My big thing is portraits mainly, and the problem I have with the 450d and 500D is the non cross type outer points, so I have to focus and recompose and when the lens is fairly wide open this throws my focus off. So, i need all cross type points and that's my main issue.
Now, I could go for a 50D or 60D as well i guess, since they both have cross type, but one thing the 7D has is all the extra focus points. So, considering the advantage of having all the 7D points, is it a good portrait body because you should be able to keep from focusing and recomposing with so many points to choose from?
Does the original 5D have all cross type points? And since I can get a used one for around 700 would that be my best option?
Since the 50D and 60D have the same number of points as my current crops, but all cross type, one of them may be my best option as I don't really have too much problem using the outer 8 points and keeping from recomposing much, it's just that the 7D with all those focus points sure seems like it would take some seriously sharp portraits with almost zero recompose.
Literally, I have a week or two to make this huge decision. The FF 5D has a great following and I can't help thinking that for portraits and landscapes it too would be very sweet as long as all it's points are cross type
As for lenses, I can sell a couple of mine to change over to EF so that all my lenses would work on my 500D and a FF 5D if i went that route. I have the Sigma 301.4, just weeks old, haven't even filled out the warranty, and it's a sharp copy, so that will be no problem to sell and won't have to add anything to get the EF 28 1.8 if I want and that will work with the FF and 500D. I have the EF-s 60mm Macro, and it's also in perfect shape so i could sell it and grab maybe the older EF 50 macro which people seem to love just fine.
Then i have the EF 100mm F2 so that will already work on FF and my 500D. So switching my Sigma and my EF-S 60 macro over to EF lenses won't be a problem and won't cost me anything.
So, what would you guys do if you were mainly in to portraits?
1. Classic 5D, (if it has all cross type points) and switch my two non EF lenses over
2. 7D because of all the extra focus points meaning not nearly as much recomposing for getting eyes sharp
3. Maybe a 50D (which has Micro adjust) and I can get a refurb unit for around 750 to 800 I see on Ebay (cost even more than a 60D refurb, why?) Or a 60D?
Thanks for any help
