Thread started 22 Jul 2012 (Sunday) 14:49
canon EoS Utility plugin and photo transfer
Momentum69
Joined Jul 2012
Jul 22, 2012 14:49 |  #1
I have installed EoE Utility and updates for my canon rebel XTi and I am unable to make my computer see the plugin. It does see the camera but when it load is says error failing to read the plugin.
Does anyone knows what can cause this? I run windows 7Ultimate/64 with 8 gig ram. amd phantom II x4 proc/3.40 ghz with a ATI radeon hd 5700. Its a pretty ok computer and should have no problem!
thank you for any advice.
PixelMagic
Jul 22, 2012 14:51 |  #2
What version of EOS Utility did you install? I recently read that the newest versions do not support older cameras.
WaltA
Gallery: 10 photos
Joined Feb 2006
Jul 22, 2012 15:50 |  #3
I suspect the problem is with the 64-bit OS. I am running Win7 Ultimate 32-bit and it works fine with my 5Dc and XTi
You may need to run a virtual XP session and execute EOS utility in it.
Walt
400D, 5D, 7D and a bag of stuff
tzalman
Fatal attraction.
Jul 22, 2012 16:07 |  #4
What do you mean by "plugin"? EOS Utility is a standalone application. Connect the usb cable, turn on the camera and launch EOS Utility from the Start menu.
Elie / אלי
PixelMagic
Jul 22, 2012 16:08 |  #5
None of this is useful without stating which version of EOS Utility is being used.
The Canon Xti, also known as the 400D or Canon Kiss x, is not supported in more recent versions of EOS Utility. This is from the Readme file for EOS Utility 2.10.4 and there have been versions released after this one:
http://support-sg.canon-asia.com …nts/SG/EN/02001​89602.html (external link)
5. Supported Models
EOS Kiss X5 / EOS REBEL T3i / EOS 600D, EOS Kiss X50 / EOS REBEL T3 / EOS 1100D, EOS 60D, EOS Kiss X4 / EOS REBEL T2i / EOS 550D, EOS 7D, EOS-1D Mark IV, EOS Kiss X3 / EOS REBEL T1i / EOS 500D, EOS 5D Mark II, EOS 50D, EOS 40D, EOS Kiss F / EOS REBEL XS / EOS 1000D, EOS Kiss X2 / EOS REBEL XSi / EOS 450D, EOS-1Ds Mark III, EOS-1D Mark III
I should also add that the Canon 5D classic is also no longer supported in the newer versions of EOS Utility.
tzalman
Fatal attraction.
Jul 22, 2012 16:14 |  #6
If all the OP wants is file transferal, the easiest solution is a card reader.
Elie / אלי
crn3371
Jul 22, 2012 16:15 |  #7
If all you're trying to do is get the photos from your camera to the PC then just use a card reader. Easier, faster, and way less problematic.
Momentum69
Joined Jul 2012
Jul 23, 2012 08:38 |  #8
PixelMagic wrote in post #14752864 (external link)
I will buy a card reader for 10$... it will save me the time to figure it out as I wasted enough time on it allready... Thx for the trouble :)
WaltA
Gallery: 10 photos
Joined Feb 2006
Jul 23, 2012 10:51 |  #9
PixelMagic wrote in post #14753146 (external link)
As I said above, I can use the Canon EOS utility latest version and it works with both my 5Dc and my XTi.
Having said that - I use a card reader for most of my transfers but I make sure EOS utility is still working in case I need it - like if I forget my card reader or whatever.
Walt
ErgoSpacePig
Jul 23, 2012 14:54 |  #10
WaltA wrote in post #14753063 (external link)
i use win7 64 and have no issues with EOS Utility.
bob
5D III | 5Dsr | TS-E 24 f/3.5L II | EF 35 f/1.4L USM | EF 135 f/2L USM | EF 85 f/1.2L II USM | EF 85 f/1.8 USM | Sigma 50mm f/1.4 EX DG HSM | Rokinon 14 f/2.8 | Zeiss Makro-Planar T* 2/100 ZE
Speedlite 580EX II | Flash Point Streaklight 360 TTL | Feisol CT 3441T | Photo Clam PC-40NS | Domke F4AF pro | Click Elite Escape | Think Tank Airport Takeoff
WaltA
Gallery: 10 photos
Joined Feb 2006
Jul 23, 2012 15:18 |  #11
ErgoSpacePig wrote in post #14758102 (external link)
bob
Hmm - do you use it to tether the camera for taking pictures or just to download? It could be the problem was only when tethering the camera.
Plus I think it was only with older Canon models - like the 5Dc and XTi.
Edit - See this thread
Walt
ErgoSpacePig
Jul 23, 2012 16:29 |  #12
WaltA wrote in post #14758223 (external link)
I have only used it to download.
bob
3,347 views & 0 likes for this thread, 6 members have posted to it.
2847 guests, 163 members online
