Thread started 23 Jul 2012 (Monday) 14:34
7d Raw Quality minus resolution question
jaomul
Joined Apr 2011
Jul 23, 2012 14:34 |  #1
On a 7d there are options to have small and medium size raw files. While I normally try to always use the largest possible resolution in case I get a shot that somehow requires this. I also regularly shoot with a 10d and usually 6mp is enough. My question is if the smaller raw files types are selected do you lose image quality, or just resolution? Thanks
Olympus EM5,Nikon d7200,
Olympus 12-50mm, 40-150mm,17mm f2.8,Nikon 50mm F1.8, Tamron 90mm vc, 18-105mmVR, Sigma 18-35 f1.8
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Jul 23, 2012 14:42 |  #2
Much like resizing down a JPG, you will end up with the same basic result but with a raw file.
This post is very similar and the responses should be about the same: https://photography-on-the.net/forum/showthre​ad.php?t=775425
Lincolnshire ­ Poacher
Joined May 2011
Jul 23, 2012 14:43 |  #3
It depends on how large you wish to print and/or how much you wish to crop.
The usual recommended PPI (pixels per inch) for printing is 300. So if your camera produces images 6000 pixels wide by 3000 pixels high, you can comfortably print at 20 inches by 10 inches. However if you wish to crop your image, then you lose a number of pixels so cannot print quite a large.
On the other hand, if the image is destined for viewing on the web or in an e-mail, then 72 PPI is ample. In that case, taking shots at a lower than maximun resolution makes sense as it reduces the files sizes massively.
NinetyEight
"Banned for life"
Jul 23, 2012 14:45 |  #4
Lincolnshire Poacher wrote in post #14758045 (external link)
For web use ppi is absolutely meaningless - all that matters is the number of pixels, so yes, if you are purely shooting for web use the smaller files.
Kev
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Jul 23, 2012 14:51 |  #5
The larger the print, the lesser need for high DPI when printing. You can print poster-sized 20x30 photos at 200-240 DPI and they will look great, provided the original source material looks good and you upsize using good tools.
jaomul
Joined Apr 2011
Jul 23, 2012 14:53 |  #6
Thanks all. I gather if I do not need the res in certain cases I wont lose quality by selecting smaller raw files.
Joined May 2011
Jul 23, 2012 14:55 |  #7
NinetyEight wrote in post #14758058 (external link)
You are of course correct. It's been a long, long day!
1,476 views & 0 likes for this thread, 4 members have posted to it.
911 guests, 118 members online
