Thread started 23 Jul 2012 (Monday) 15:14
Depth of field
isle
Joined Jul 2012
Jul 23, 2012 15:14 |  #1
On a T2i what does the DOF button do.I have tried it a number of times in different settings and live view and I can not seem to see what it does or is supposed to do.
BTBeilke
Jul 23, 2012 15:54 |  #2
From your manual:
Press the depth-of-field preview button to stop down to the lens's current aperture setting. You can then check the depth of field (range of acceptable focus) through the viewfinder.
It's basically a WYSIWYG feature that lets you see how the picture will look using the aperture you (or the camera) has selected for that shot. Typically, cameras will focus and such with the lens at its largest aperture regardless of the setting you've selected. So if you lens is capable of f/4 at the focal length you're using, the camera will focus at that aperture and that is how you'll see the picture in the viewfinder. If you have the camera set to take a photo at f/11, the camera will stop down the lens diaphragm just before taking the picture. If you want to see how the depth of field looks at f/11, press the DOF preview button. Obviously, if you've set the camera to take the shot at f/4, you won't see a difference when you press the preview button. (Note, if you intend to use a smaller aperture, your viewfinder should get noticeably darker when you press the DOF preview button as less light will be available at that smaller setting.)
Blane
Billginthekeys
Billy the kid
Joined Nov 2005
Jul 23, 2012 15:56 |  #3
It tells the lens to stop down to the set F-stop so you can see what will and won't be in the depth of field of the shot at that setting. Put your camera in Aperture priority, stop it down to, say F8, look through the viewfinder and hit the DoF preview button. The image should get "dim" but more of it should appear in focus.
Mr. the Kid.
Go Canes!
My Gallery (external link)My Gear
what the L. just go for it.
modchild
Joined Jul 2011
Jul 23, 2012 15:57 |  #4
When you shoot in Av and you set the aperture to between f16 and f22 try pressing the DOF button then. You'll see the viewfinder darkens and shows the picture as it will be taken with the full DOF in focus. When you are shooting upto around f8 in sunlight you probably wont see much of a difference. Without pressing the DOF button you will see the view as it would be taken with the aperture wide open.
EOS 5D MkIII, EOS 70D, EOS 650D, EOS M, Canon 24-70 f2.8L MkII, Canon 70-200 f2.8L IS MkII, Canon 100 f2.8L Macro, Canon 17-40 f4L IS, Canon 24-105 f4L IS, Canon 300 f4L IS, Canon 85 f1.8, Canon 50 f1.4, Canon 40 f2.8 STM, Canon 35 f2, Sigma 150-500 OS, Tamron 18-270 PZD, Tamron 28-300 VC, 580EX II Flash, Nissin Di866 MkII Flash, Sigma EM 140 Macro Flash and other bits.
uOpt
Jul 23, 2012 16:00 |  #5
isle wrote in post #14758203 (external link)
The thing to understand here is that if you close the aperture with the dial, or if some automatic mode does it for you the camera actually close it. In the Canon shooting model the aperture will always stay full open whole you are messing with the camera and only snap close to the desired aperture when you actually fire.
The button tells the camera to actually close to the desired setting. It does nothing if your selected aperture is the lens'es maximum aperture anyway.
Sometimes I wish Canon would communicate a little clearer instead of piling up "less confusing" terms and them spend 20 years making up more confusing terms just to be bug-compatible.
My imagine composition sucks. I need a heavier lens.
Preeb
Gallery: 151 photos
Joined Sep 2011
Jul 23, 2012 16:19 |  #6
uOpt wrote in post #14758454 (external link)
I don't see anything confusing about it. I had a DoF preview button on my Minolta SRT nearly 40 years ago, and it did the same thing. I used it religiously.
Rick
6D Mark II - EF 17-40 f4 L -- EF 100mm f2.8 L IS Macro -- EF 70-200 f4 L IS w/1.4 II TC
uOpt
Jul 25, 2012 13:14 |  #7
It's confusing to people without 40 years of photography behind them.
jwp721
Jul 25, 2012 13:21 |  #8
uOpt wrote in post #14768152 (external link)
It was still confusing 32 years ago when I bought my first SLR since the viewfinder darkened enough that it was hard to see what was and what was not in focus.
Never used it then and still don't use it today.
ejenner
Gallery: 98 photos
Joined Nov 2011
Jul 25, 2012 14:13 |  #9
jwp721 wrote in post #14768180 (external link)
Agreed, BUT today we have live view. Unfortunately, however, not DOF preview lock (maybe on 1-series though).
The main use I see for it with modern cameras is when on a tripod in LV mode where you can zoom in to selected parts of the frame and LV compensates for the reduced aperture. You can then use it to see if the entire (or at least most of it since you might not be able to zoom into the corners) is in focus when stopped down to your current aperture settings.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
tkbslc
Jul 25, 2012 14:19 |  #10
The viewfinders on modern AF SLR cameras don't shot DOF very accurately. So even when holding down the DOF preview button, the viewfinder isn't showing you very well what you are going to get. Where it does work well is in liveview.
Taylor
EOS Rp | iPhone 11 Pro Max
Nature ­ Nut
Joined May 2012
Jul 25, 2012 14:27 |  #11
Every time I press the DOF button my lens falls off
tkbslc wrote in post #14768423 (external link)
+1 Live view is much more useful with dof preview, maybe with the bigger cameras with a MF screen the DOF preview would be slightly more helpful. I find the viewfinder useful for rough "is it in focus" check but thats about it.
Adam - Upstate NY:
seall
Gallery: 14 photos
Joined Mar 2012
Jul 25, 2012 14:31 as a reply to  @ tkbslc's post |  #12
Not on the standard camera however Magic Lantern on the 600D will allow you to make the button sticky, I assume it functions the same for the T2i?
Lowner
"I'm the original idiot"
Jul 25, 2012 14:40 |  #13
Nature Nut wrote in post #14768453 (external link)
Very droll!
But regarding the original question, I find depth of field tables more helpful. As already said, stopping down makes the image too dark to see anything useful.
But it becomes second nature. I know from experience that the DoF Is about 1/3rd in front of the subject and 2/3rds behind and also how deep it will be for various apertures. As I shoot landscapes I normally want the largest DoF I can get rather than the smallest. If I habitually wanted the opposite I'd soon get used to that.
Richard
sawsedge
Joined Dec 2011
Jul 25, 2012 15:11 |  #14
Just a quick note... on my 20D and 50D, I seem to recall reading that the DOF preview button does nothing in the "picture" modes, it only works in the "creative" modes... P S A M. I assume it is the same with the Rebels.
And of course if the aperture is open as wide as it goes, there won't be a change. You need to stop down (set a higher f-number) to see a change when you push the button.
- John
2,006 views & 0 likes for this thread, 13 members have posted to it.
Depth of field
2715 guests, 162 members online
