Hey. I use canon 550d with YN560-II flash and have a little problem. Do you have any suggestions how to focus in the night then there is not enough light and autofocus dont work. You can't do anything good with manual focus either. When you are using pop up flash, the infrared beam turns on and helps to focus, but the it doesnt light up when you are using external flash. Maybe there is any chance to make the beam work with ext flash? Now I'm using flashlight when i need to focus in dark or just use manual focus blindly until i get a good result but it's not very convenient. Any suggestions?
