Thread started 25 Jul 2012 (Wednesday) 17:58
18-200 as travel lens on 7D
Sushi49
Joined Jul 2012
Jul 25, 2012 17:58 |  #1
I am in the market for a 7D, I travel a lot of backpacking. Is the 18-200 Canon lens a good choice and what can I expect in terms of image quality vs a Mu43 with similar lens I currently have?
PhilipAlex
Joined Jul 2012
Jul 25, 2012 19:50 |  #2
Photozone (external link) doesn't have much good to say about Canon's 18-200mm. Sigma makes an 18-250mm (external link) with OS that I've heard some good things about and it's only $479. May be worth checking out if you're in the market for a one lens solution. Tamron has a a couple good ones in the range as well.
Scott ­ M
Gallery: 111 photos
Jul 25, 2012 20:29 |  #3
The new Tamron is a pretty compact size, which may be of interest since you will be using it backpacking. These super zooms are a compromise in image quality, anyway, so you may as well get one that is small to fit your application.
Photo Gallery (external link)
DreDaze
Gallery: 49 photos
Jul 25, 2012 20:37 |  #4
why a 7D and not a rebel if it seems like size is an issue?
i'd think the new t4i kit with the new 18-135STM lens could be a good idea...if the optics are as good as the 15-85mm it should be a nice lens
Andre or Dre
gear list
Instagram (external link)
Ando27
Joined Jan 2012
Jul 25, 2012 21:10 |  #5
I got one with my 7D body.....anyway I use it for Lanscapes as I use long lenses for most of my shooting
Ive found the 18-200 used around th middle & @ f8/f9/f10/f11 makes a very underrated walkaround n lanscape lens.
Its just fashionable to bash it ,
Ando.
"Down Under"
[CENTER][B]Canon 1D4 / 5D3 gripped / 7D gripped / 300f2.8 IS L / 100-400f5.6 L / 70-200f2.8 IS II L / EFS18-200IS / 24-105 f4 IS / 10-20 f4 / 580EXII x 3 /1.4 TC III / 1.4TC II / 2 TC III / 15' Rig / 20' Rig.[CENTER]
tkbslc
Jul 25, 2012 21:12 |  #6
PhilipAlex wrote in post #14769764 (external link)
Photozone.de was much harder on the 18-200 and 18-135 than anyone else. The-digital-picture and slrgear had pretty good reviews on it.
Taylor
EOS Rp | iPhone 11 Pro Max
wayne.robbins
Joined Nov 2010
Jul 25, 2012 22:21 |  #7
The 18-135 STM seems to be a little bit better - but only played with it a little- -over the original 18-135 IS. Never tried the 18-200- but there is a number of those out there that own it- and like the lens. Lenses are always a compromise- between range, or lack of, aperture, build quality, and price. I'm sure that there may be other criteria for some- but those are the major pieces as I see it.
You should probably peruse the lens sample archive for that lens- and look at them - see if they are satisfactory. Otherwise, buy it, try it, and see if you like it. On POTN, you are likely to find critics for everything, and at the same time, others that like the product. You could also just buy a body- and rent the lens for a few days- to see if that's something you are interested in, or go to a local store and try them out there.
If weight and space are a premium- a T4i and 18-135 would be significantly smaller and lighter- out of curiousity- why the 7D ? Weather resistance ? (weather resistance with a non-weather resistant lens is basically pointless- right ? Besides- Canon voids the warranty if you drop it or get water into the camera or lens. ) get some rain sleeves instead. And some larger zip lock bags.
EOS 5D III, EOS 7D,EOS Rebel T4i, Canon 70-200 f/2.8 IS II, Canon 24-105L, Canon 18-135 IS STM, 1.4x TC III, 2.0x TC III, Σ 50mm f/1.4, Σ 17-50 OS, Σ 70-200 OS, Σ 50-500 OS, Σ 1.4x TC, Σ 2.0x TC, 580EXII(3), Canon SX-40, Canon S100
Fond memories: Rebel T1i, Canon 18-55 IS, Canon 55-250 IS, 18-135 IS (Given to a good home)...
danpass
Jul 25, 2012 22:31 |  #8
Yes
A sampling of its flexibility on a 60D
18mm
100mm 'macro'
200mm
Dan
Gallery (external link) | Gear/Feedback
mwsilver
Gallery: 54 photos
Joined Oct 2011
Jul 25, 2012 23:42 |  #9
Ando27 wrote in post #14770088 (external link)
I also have a Canon 18-200mm, and find that its generally much sharper than the Tamron 18-270 PZD, which I also own. Focus is pretty fast, although a bit noisy, on this non-USM lens. IS is very good. There is a lot of barrel and some pincushion distortion. In my opinion the worse thing about it is the very high amounts of chromatic aberration. I'm not sure if the IQ of this lens is better than, or even equal to the basic kit combo of the 18-55mm and 55-250mm. Mine has excessive zoom creep. However, although far from perfect, once you accept its limitations, its a very good and useful walk around lens.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
mwsilver
Gallery: 54 photos
Joined Oct 2011
Jul 25, 2012 23:44 |  #10
It has issues, but its very useful. Even wide open its reasonably sharp.
Mark
mwsilver
Gallery: 54 photos
Joined Oct 2011
Jul 25, 2012 23:47 |  #11
tkbslc wrote in post #14770102 (external link)
The degree of negatively does vary a bit from review to review, but all the reviews seem to pinpoint it limitations accurately.
Mark
uOpt
Jul 26, 2012 00:34 |  #12
Canon's 18-200 isn't bad at all.
If you don't need indoors with no flash you can feed a vacation off it.
My imagine composition sucks. I need a heavier lens.
Larry ­ Weinman
Jul 26, 2012 07:45 |  #13
It is a surprisingly good lens. The distortion on either end is easily corrected in Lightroom.
7D Mark II 6D 100mm f 2.8 macro 180mm f 3.5 macro, MP-E-65 300mm f 2.8 500mm f4 Tokina 10-17mm fisheye 10-22mm 17-55mm 24-105mm 70-300mm 70-200 f 2.8 Mk II 100-400mm Mk II 1.4 TCIII 2X TCIII 580EX II 430 EX II MT 24 EX Sigma 150-600
mwsilver
Gallery: 54 photos
Joined Oct 2011
Jul 26, 2012 10:09 |  #14
uOpt wrote in post #14770896 (external link)
Absolutely. While I think I get much sharper and better IQ from my 15-85mm, and I really like its ability to go wide at 15mm, when I'm out and about I often miss the reach and versatility of the Canon 18-200mm.
Mark
mwsilver
Gallery: 54 photos
Joined Oct 2011
Jul 26, 2012 10:12 |  #15
Larry Weinman wrote in post #14771837 (external link)
Generally true, but I find the chromatic aberration is so high that post processing doesn't fix it completely.
Mark
9,074 views & 0 likes for this thread, 15 members have posted to it.
2938 guests, 156 members online
