Thread started 27 Jul 2012 (Friday) 14:39
Can't re-compose with fast lenses (35 1.4L...) ?
CanonYouCan
Jul 27, 2012 14:39 |  #1
I know a professional wedding photographer that says you can't re-compose with fast lenses, like 35 1.4L.
Did he mean only 35 1.4L or also 85 1.8, 135 f2L for example?
Maybe it's only with f1.2 - f1.4 lenses where dof is very narrow ?
Didn't notice this actually, maybe I was lucky that pics are reasonable sharp :)
Sony A7 III | Metabones V | Sigma 35 1.4 Art | Sigma 85 1.4 Art | 70-200 2.8L II
Lighting : Godox AD600B TTL + Godox V860II-S + X1T-S
Modifiers: 60cm Collapsible Silver Beautydish + grid | Godox 120cm Octagon softbox + grid + Speedlite Flash bender
Tripod: Vanguard Alta 253CT carbon
CyberManiaK
Jul 27, 2012 14:45 |  #2
Maybe this will explain it a bit
http://digital-photography-school.com …he-focus-recompose-method (external link)
Carlos
60D / 10-20 + 100L + 40/2.8
shinksma
Joined Jul 2011
Jul 27, 2012 16:09 |  #3
The basic cause, which seems to have eluded many of the commentators on that site, is that the plane of sharp focus (a.k.a. focal plane) is literally (almost) a plane (i.e. flat like a big sheet of glass) and not curved (like a sphere). So when you recompose, the object that you focused on, while still the same distance away from the camera, is no longer in the focal plane, because the focal plane moved when you re-aim the camera/lens.
I use focus-recompose at times, and I run into this issue more often than I'd like. So I'm trying to get into the habit of selecting off-center focus points that require really small/no recomposing.
shinksma
5DII | T3i | EF 17-40 L | EF 24-105 L | EF 24 1.4 L II | EF 28 1.8 | EF 85 1.8 | EF 70-200 2.8 L IS II | EF 100-400 L | EF-S 15-85 IS USM | EF-S 17-55 2.8 IS USM | EF-S 10-22 USM | EF 100 2.8 Macro USM | EF-S 18-55 IS | EF 35-80 III | EF-S 55-250 IS | Rokinon 8mm FE | EF 75-300 non-USM III | SMC Takumar 50mm f/1.4 | Tamron 70-210 | 430EX II | Kenko 2x MC4 and 1.4x Pro300DGX TC
CanonYouCan
Jul 29, 2012 01:19 as a reply to  @ shinksma's post |  #4
Thanks, so a 1.4 is almost impossible to re-compose, and the 85 1.8 still to thin ? So I f you do a model shoot for example you should select immediately select a side focus point for example.
Maybe the 70-200 2.8L IS II shouldn't be a problem at f2.8, it still thin but not so extreme.
nonick
Jul 29, 2012 01:46 |  #5
35L 1.4 can't use for recompose wel if you are using wide apretures. I am not happy with the performance when the lens is used on 5DII in low light at wide apretures because it forced me to use the center AF point. The outer AF points are not reliable and recompose method is not working well in the sitaution.
Gear|Searching for 7DII, Buying 5DIII 35L II, 24-70 2.8L IS
sebr
Jul 29, 2012 02:17 |  #6
I have recomposed at f/1.4 on the 5D2 and get good results, as long as it is not a close up when the DoF becomes really thin. I cannot post any shot just now because I am on vacations, but it is not impossible. Make sure your subject is still and take several shots if possible.
Sebastien
5D mkIII ; 17-40L ; 24-105L ; 70-200L II ; 70-300L ; 35L ; Σ85/1.4 ; 135L ; 100macro ; Kenko 1.4x ; 2x mkIII ; 580EXII
M5 ; M1 ; 11-22 ; 18-150 ; 22/2.0 ; EF adapter; Manfrotto LED
Benron Tripod; ThinkTank, Lowepro and Crumpler bags; Fjällräven backpack
nWmR12
Jul 29, 2012 02:33 |  #7
I would say its quite possible to recompose with the 35 1.4 but is certainly hard especially if you can't determine where the focal plane is. I have done it for a some time now and actually get most of them in focus. Since my 5Dc share the same af points which are not the best off the center. Its more knowing what you body movement is doing and predicting where the focal plane is then taking the shot (multiple usually), along with manual focusing to get the right adjustment at times. This of course all just depends how much the distance you are from it also. The longer focal lengths are much harder to do i.e 135 and 85 wide open I find much harder but only when they are getting close to their MFD.
5DIII, 5Dc, 24-105L, 100-400L, 14mm Rokinon 21 ZE, 35L, 50 1.4, 50CM 2.5, Rokkor 58mm 1.2. 85 1.8, 135L |S90| Film: Mamiya RZ67 ProII/ Mamiya 7II | Rolleiflex 2.8C
flickr (external link)|500px (external link)|facebook (external link) - Travel/landscape | facebook (external link) - Portrait| Instagram (external link)
Portfolio (external link)
DimeRazorback
Joined Sep 2011
Jul 29, 2012 03:00 as a reply to  @ nWmR12's post |  #8
Compensate with a touch of manual input :)
Canon 5D MkII (Gripped); 17-40mm f/4L 50mm f/1.2L, 85mm f/1.2L, 135mm f/2L, 580EX II.
Osiriz
Joined Jul 2012
Jul 29, 2012 03:02 |  #9
If you think the 35L is tricky to recompose with, you should try the 85L II. ;)
I guess this is the reason to why many 5D2 owners upgraded to the 5D3.
JelleVerherstraeten
Jul 29, 2012 03:50 |  #10
sebr wrote in post #14784572 (external link)
I second this. But it's still possible at a close range, but you may have to move your body a bit to compensate for that.
-Jelle l Gear l Website (external link) l
Earwax69
Joined Jul 2012
Jul 29, 2012 04:02 |  #11
Interesting!
Canon 6D | S35mm f1.4 | 135mm f2 The rest: T3i, 20D, 15mm f2.8, 15-85mm, 24mm f2.8, 50mm f1.8, 85mm f1.8, 90mm f2.8 macro, 55-250mm.
So long and thanks for all the fish
smorter
Jul 29, 2012 08:07 |  #12
I think the OOF caused by focus-recompose is grossly exaggerated, it doesn't really make that much of a difference. I think what happened was that years ago some theoretical armchair photographers spread paranoia over this issue and nowadays we all accept it as truth, even though in practice it rarely makes a difference
35 @ f/1.4:
85 @ f1/2:
Wedding Photography Melbourneexternal link
Reviews: 85LII
sebr
Jul 29, 2012 09:20 |  #13
Excellent examples smorter !
JelleVerherstraeten wrote in post #14784793 (external link)
I actually agree with you, it is just that it is more difficult at close range...
Sebastien
jbrand
Aug 03, 2012 21:30 |  #14
shinksma wrote in post #14778868 (external link)
shinksma
+1
Not a lens problem, a depth of field problem. Crank the DOF to the same place as the lens that don;t have this "problem", and it performs the same. Shallow DOF is a two-edged sword...
"If you can't do something smart, do something right"
Gripped 7D, Gripped 450D, Rokinon 8mm 3.5, Sigma 20mm 1.8, Sigma 30mm 1.4, Canon 40mm 2.8, Sigma 50mm 1.4, Canon 85mm 1.8, Canon 200mm f2.8L, Canon 70-200mm f2.8L, Canon 300 f4L, Kenko 1.4 TC and tubes, S95, AT-1, and a bunch of other stuff.
Wilt
Aug 04, 2012 11:18 |  #15
smorter wrote in post #14785201 (external link)
...After all, film SLR shooters had relied on centered focus aids to focus and then had to reframe, yet the recompose issue was not really raised in significance until later when AF comes along.
Quite some time ago I did a spreadsheet for focus-recompose error on FF cameras (shallower DOF) with different FL lenses at different distances. This shows the amount of focus error and how much tolerance can be compensated by DOF (using lens manufacturer standards for DOF calculation) For example, at 5' distance and shifting the point of focus 15 degrees (1.34'), 50mm f/2 has insufficient DOF zone to compensate adquately (pink field indicates when DOF zone is inadequate to compensate; the subject is at 4.83' while DOF zone does not cover that near distance adequately to fool the eye.
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/Focus_recompose_FF.jpg
But one needs to also consider that it is somewhat foolish to be shooting a photo of someone from 5' away due to the induced perspective distortion caused when being too close to your portrait subject!
3,492 views & 0 likes for this thread, 13 members have posted to it.
2766 guests, 152 members online
