J_O_S_H_U_A wrote in post #15154388
How may rows deep is your group? and how far back do you need to be to shoot a group at 85mm?
at a distance of 30ft (which I assume is not wide enough) you only have a depth of field of 3'3 ft, certainly not enough if they are more than two rows deep.
My suggestion is to crank the WL's, stop down to at least f8 and if you need more ambient, slow your shutter down to 1/80 at the slowest.
Two rows deep max in the groups, and I want to blur out the altar area. The background would be distracting if I shot at anything slower than f/2.8. I did play with this while shooting with my 15-85 as I was setting things up, but I kept having my eye drawn to all the shiny brass and other things in the background. So, I need to throw it out of focus.
Ambient is a mix of colors, and I am killing it in these shots. If the sunlight coming through the stained glass becomes a problem, I'll throw on a CPL (almost 2 stops of loss) and use some of the headroom I have on the strobe power. [Umbridge voice]I will have order![/Umbridge voice]
SkipD wrote in post #15154428
First off, you'll want to get the lights clustered together as much as practical and above the camera. Crank the lights up full blast and leave them there. Adjust the ISO setting up so you can get light levels adequate for an f/11 aperture setting.
Done as mentioned earlier, the stands were right next to each other and 12' high. They were basically touching to give a roughly 6'x12' bank of light. However, as mentioned above, I do not feel that shooting at f/11 will work for this venue. We want it to be clear that it was at the church, but the background would be WAY too distracting with the dof that I would get from f/11.
Unless the group will be on a tiered stage (each row higher than the one in front), you'll want to get the camera atop a sturdy six-foot or eight-foot stepladder. The lights still should be a couple of feet above the camera, which suggests you'll want sturdy 13-foot light stands.
I've gone through several different ideas before proving that this combination truly works. For large groups (I've done up to 80 people or so in a group), I typically use 6 lights with large umbrellas (5-footers) clustered above the camera.
DO NOT put one light left of the camera and another right of the camera, especially if the lights are at camera height. This produces some absolutely horrible shadows of heads that inevitably wind up on other people's faces.
There are two very wide steps leading up to the chancel area, so seeing everyone won't be a problem (no ladder needed here, but it is good advice to others).
