Thread started 28 Jul 2012 (Saturday) 17:40
Singh-Ray polarizers for Cokin P, ring or sprocket mount?
koffikapp
Joined Jun 2012
Jul 28, 2012 17:40 |  #1
I made a similar thread in Nature & Landscapes Talk but haven't got any replies yet, and this subforum seem to have more traffic...
Anyway, I recently bought a set of Singh-Ray ND grads for use with Cokin P, of which I have both the wide-angle and standard holders. I originally wanted to use a screw-in circular polarizer on the lens and then mount the holder to the filter, but found it was a bit of hassle turning the polarizer while trying to keep the holder stationary. I'm therefore looking into getting a polarizer from SR for use with the grads, I'm thinking either a LB Warming or Color Combo, and maybe a Gold'n'Blue.
My question is, for those who've used this system, if it's better to get the sprocket rather than ring mount? I will probably use the polarizers in combination with the grads for the most part, and I guess I could just handhold the grads, but I might want to use the polarizer + two grads on the standard P holder. As for the wide holder, would mounting a sprocket polarizer result in the filter edges being visible on 17mm on FF? I'm using a 5D II with a 17-40, and the holder itself doesn't vignette @17mm.
Also, if anyone who've used the SR LB Warming/Color Combo, I'd love to see some shots with/without the filter if you happen to have some.
Cheers!
koffikapp
Joined Jun 2012
Jul 29, 2012 14:58 |  #2
No one has any opinions on sprocket type polarizers?
PG1
Jul 29, 2012 17:29 |  #3
I use sprocket mount SR LB warming polarizer on the Lee kit. Tried it out recently - worked well. I put it in the closest slot (to lens) and grad ND in the 3rd spot (second spot is not usable with the sprocket mount in the first spot) - no vignetting with the 17-40 at 17 on 5DII.
Too much gear, not enough skill or time!
Canon R, Sony a7III, EF 24-70 II L, EF 70-200 II f/4.0 L, RF 100-500 L, RF 35 1.8, RF 800mm f/11, Sigma 85 1.4 DG DN, Voigtlander 35 1.2 SE. Gitzo 2545T, 3541LS, Markins Q3T, Q20.
koffikapp
Joined Jun 2012
Jul 29, 2012 18:37 |  #4
Nice to hear there's no vignetting, but kind of a bummer if you can only use one grad together with the polarizer. Wonder if it applies to the Cokin holder as well? The Lee kit is larger than Cokin P though, equivalent to Cokin Z-Pro, or have I misunderstood?
Jon
Joined Jun 2004
Jul 29, 2012 18:38 |  #5
Right - the Cokin P filters are only 85 mm; the Z-Pro and Lee are 100 mm (4"), so less vignetting especially at wide angles and with round filters in the equation.
Jon
Cocker Spaniels
koffikapp
Joined Jun 2012
Jul 29, 2012 18:43 |  #6
Thanks for clearing that up. I guess that means vignetting could be present with the P sized filters.
PG1
Jul 29, 2012 18:53 |  #7
Correct - Lee is Z-pro equivalent.
I have not tried it, and not sure it will work, but you could put the sprocket mount polarizer in the 3rd spot and use the first 2 for square filters.
FWIW, the setup I mentioned first is what Darwin Wiggett uses and recommends...
koffikapp wrote in post #14787215 (external link)
3,587 views & 0 likes for this thread, 3 members have posted to it.
504 guests, 138 members online
