Does anyone have a script that simply puts your name in a photo somewhere?
Also a script to resize photos down to a certian size
TIA
weka2000 Is that a 300mm in your pocket? More info | Dec 17, 2005 21:28 | #1 Does anyone have a script that simply puts your name in a photo somewhere?
EOSX Senior Member 408 posts Likes: 1 Joined Nov 2004 Location: Virginia, USA More info | Dec 17, 2005 21:31 | #2 I am looking for the same. Sony A7R |E 10-18 f4 | FE 24-70mm F4 OSS Vario-Tessar T* FE | 55mm F1.8 ZA Zeiss Sonnar T* | EOS M | EF-M 22 f2 STM | EF-M 18-55 f3.5-5.6 IS STM |
rpolitsr Cream of the Crop More info | Dec 17, 2005 22:16 | #3 weka2000 wrote: Also a script to resize photos down to a certian size I use Photoshop CS but I guess this menu will be available in CS2 as well: rafael
mickle Senior Member 824 posts Joined Aug 2004 Location: Peterborough UK More info | Dec 18, 2005 02:55 | #4 weka2000 wrote: Does anyone have a script that simply puts your name in a photo somewhere? Also a script to resize photos down to a certian size TIA If you have CS or CS2 then try the link in my sig..... Mike
queenbee288 Cream of the Crop More info | Dec 18, 2005 19:17 | #6 I use a custom saved brush for my signature. You save it then when you use it you can make it any size or color you want. YOu can make it semi transparent by changing the opacity. Here is how you do it.
HarrySettle Senior Member 663 posts Joined Jun 2004 Location: Bemidji, MN More info | rpolitsr wrote: I use Photoshop CS but I guess this menu will be available in CS2 as well: To resize a photo you have a direct menu command: File>Automate>Fit Image… A dialog pops up. Set the width and height in the “Constrain Within” boxes to the desired values and click OK If you wish, you can record it as an action and use Batch process to resize a complete folder or the images selected in the File Browser. For the Copyright Script, I left it to a CS2 owner. In the constrain within boxes, if you put the same dimension in both boxes, say 1800, then it will automaticaly keep the longest side to that dimension and the short side will go to whatever your ratio is. What is this good for? If you have a file full of shots that you want to size to 4x6 and some are horizontal and some vertical you won't have to go through and rotate half of them.
herb_sims Hatchling 6 posts Joined Jun 2005 More info | Dec 28, 2005 13:02 | #8 Try:
| Latest registered member was a spammer, and banned as such! 2306 guests, 135 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
