Thread started 29 Jul 2012 (Sunday) 09:42
5dmk3 AI servo low light tests
bobbyz
Jul 29, 2012 09:42 |  #1
First run I was happy when using 70-200mm f2.8 IS II. Yesterday I tested 300mm f2.8 IS and one run is good but two others I hoped for lot better.
Can other folks also post their low light AI servo test results? My case light was still good, when shoting high school football I would be in much worse light. Also want to hear from folks claiming how good 5dmk3 compared to 1dmk4 is when in AI servo low light. Can you also please posts some sequence shots? Would really appreciate that.
Fuji XT-1, 18-55mm
bobbyz
Jul 29, 2012 09:42 |  #2
Run #1 70-200mm f2.8 IS II
IMAGE: http://www.bobbyzphotography.com/img/s1/v54/p112363543-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s2/v61/p284781218-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s2/v52/p326793173-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s2/v59/p376632424-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s2/v60/p480419467-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s1/v48/p131153017-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s2/v61/p221601857-5.jpg
Fuji XT-1, 18-55mm
bobbyz
Jul 29, 2012 09:43 |  #3
Run#1, continuation (canon 70-200mm f2.8 IS II)
IMAGE: http://www.bobbyzphotography.com/img/s1/v46/p109153005-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s1/v57/p124358400-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s1/v48/p398527484-5.jpg
Last one is OOF as I think he is too close to me and lens can't focus.
Fuji XT-1, 18-55mm
Stickman
Jul 29, 2012 09:43 |  #4
bobbyz wrote in post #14785426 (external link)
Nothing showing right now.
Stick
http://www.flickr.com/​photos/stickgunner/ (external link)
bobbyz
Jul 29, 2012 09:43 |  #5
Run#2, Canon 300mm f2.8 IS. Pretty good results here.
IMAGE: http://www.bobbyzphotography.com/img/s1/v56/p1039865925-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s1/v47/p991897553-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s2/v52/p922556759-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s2/v60/p1073538642-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s2/v61/p1002310233-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s1/v49/p1016059673-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s2/v53/p1032241566-5.jpg
Fuji XT-1, 18-55mm
bobbyz
Jul 29, 2012 09:44 |  #6
More Run#2, continuation (300mm f2.8 IS). AF messed up in #2 shot here.
IMAGE: http://www.bobbyzphotography.com/img/s2/v59/p665395543-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s2/v60/p556942578-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s2/v60/p1017198172-5.jpg
IMAGE: http://www.bobbyzphotography.com/img/s2/v52/p737265668-5.jpg
Fuji XT-1, 18-55mm
bobbyz
Jul 29, 2012 09:44 |  #7
Run #3, canon 3000mm f2.8 IS. Needs to be better. These are smaller size, focus is soft in case of originals.
IMAGE: http://www.bobbyzphotography.com/img/s2/v60/p831142978-6.jpg
IMAGE: http://www.bobbyzphotography.com/img/s2/v61/p890276783-6.jpg
IMAGE: http://www.bobbyzphotography.com/img/s1/v57/p692392645-6.jpg
IMAGE: http://www.bobbyzphotography.com/img/s1/v46/p891352483-6.jpg
IMAGE: http://www.bobbyzphotography.com/img/s2/v58/p654252622-6.jpg
IMAGE: http://www.bobbyzphotography.com/img/s1/v55/p1016546500-6.jpg
IMAGE: http://www.bobbyzphotography.com/img/s1/v56/p608502452-6.jpg
Fuji XT-1, 18-55mm
bobbyz
Jul 29, 2012 09:45 |  #8
More run#3. Alternate shot is good. Not sure why.
IMAGE: http://www.bobbyzphotography.com/img/s1/v47/p969800876-6.jpg
IMAGE: http://www.bobbyzphotography.com/img/s1/v57/p851027471-6.jpg
IMAGE: http://www.bobbyzphotography.com/img/s1/v55/p981185820-6.jpg
IMAGE: http://www.bobbyzphotography.com/img/s1/v54/p804820862-6.jpg
IMAGE: http://www.bobbyzphotography.com/img/s1/v56/p668566972-6.jpg
Fuji XT-1, 18-55mm
bobbyz
Jul 29, 2012 10:12 |  #9
Will see if I can test using my old 1dmk2.
Fuji XT-1, 18-55mm
jase1125
Jul 29, 2012 11:43 |  #10
What af case did you have it set to? What af mode (single, spot, single +4, single +8, zone or all points)?
Tweaking the af settings should make your tests improve. Once I started fiddling with the settings based on what I was shooting my keeper rate increased.
Jason
sempaidavid
Jul 29, 2012 13:32 |  #11
I shoot Roller Derby in very low light and my 5d mkIII hits more often than my 1D mkIV. Single point, back button focus on both.
5D mkIII, 1D mkIV, Tokina 16-28 f/2.8, EF 24-70L, EF 70-200 f/2.8L II IS, EF 100-400L, EF 85 f/1.8, Sigma 50 f/1.4, EF 24-105
http://www.davidcostap​hotography.com (external link)
bobbyz
Jul 29, 2012 14:17 |  #12
jase1125 wrote in post #14785825 (external link)
I was mainly using case 4, single + 4points.
Fuji XT-1, 18-55mm
jase1125
Jul 29, 2012 14:53 |  #13
Try case 2 and see if there is a difference. In theory, af should grab the boy and hang on better. I would
keep using 1 point plus 4 expanded
Jason
KarlGB77
Jul 29, 2012 16:03 |  #14
What I read Bobby is that in AI Servo using the different case settings, you need to use all 61 points so it can track.
Otherwise it won't track properly.
Canon 5D Mark III, 5D Mark II, T2i (2), 24-105 f4LIS, 17-40 f4L, 70-200f4L IS, 70-200 2.8L IS II, 100 2.8, 85 1.8, 50 1.4, 50 1.8, 15-85 f4-5.6 IS, 60 2.8, 18-55 IS, 55-250 IS, 430 EX II, 580 EX II, Manfrotto 055XPROB Tripod w/ 498RC2, Calumet 8121 Tripod, Manfrotto 679B Monopod w/ 234 RC2 head
KarlGB77
Jul 29, 2012 16:04 |  #15
You start with whatever point you want and then it tracks.
Doesn't track in any other mode than all 61 points.
8,551 views & 0 likes for this thread, 9 members have posted to it.
2789 guests, 167 members online
