Thread started 29 Jul 2012 (Sunday) 11:43
Battery problem
VSS2011
Joined Apr 2011
Jul 29, 2012 11:43 |  #1
I am not happy!
Out today to take some unrepeatable images.
New battery, LP-E6, charged overnight but never got green light. Charge level showed at 66% so considered it should be OK as I was only expecting to take 50-100 images absolute maximum.
First 9 images fine, safely saved to the card. Next batch was a short burst of about 6-10 images, no more. Battery dies before images saved from the buffer to the card.
Having partially recharged the battery it shows image count of 0, which is wrong.
Simple question, is the battery faulty? (I can think of several other words for it!)
Age is a state of mind, and I don't.
pwm2
"Sorry for being a noob"
Jul 29, 2012 11:49 |  #2
Yes, charger or battery is broken. Return it for a replacement.
Maybe it is an old battery that have been on a shelf for a very long time - if a lithium ion battery gets too depeted, it will refuse to take charge to avoid the risk if fire.
Salleke
Jul 29, 2012 11:50 |  #3
VSS2011 wrote in post #14785823 (external link)
I am not happy!
1) What camera do you have?
2) Do you have another batterie to test the camera?
3) Have you tried another memory card?
Please first make shure if it's the memory card or the batterie
or the camera itself.
Good luck.
Joe ­ Ravenstein
Jul 29, 2012 12:05 |  #4
The 1st charge on a "new" battery takes significantly more time to reach full state than an older cycled battery does. Put back on charge and let it charge the battery fully till the green light comes on showing it is fully charged.
Canon 60D,18-55mm,55-250mm,50mm compact macro, AF ext tubes. Sigma 8-16mm uwa, 18-250mm, 85mm F1.4, 150-500mm
VSS2011
Joined Apr 2011
Jul 29, 2012 12:23 |  #5
Salleke wrote in post #14785849 (external link)
Good luck.
Canon 7D
Yes, other battery seems fine, as does charging to 100% with green light and correct image count
Not tried a different memory card
John ­ from ­ PA
Joined May 2003
Jul 29, 2012 12:31 |  #6
A recently acquired SterlinTek battery had some strange behavior after the initial "full" charge, only delivered about 20 shots in my 60D and then appeared to be dead. After the 2nd "full" charge it bahaved normally, even delivered about 400 shots on a recent Alaska trip.
As "joe" says, charge it again then see what happens.
RTPVid
Jul 29, 2012 12:51 |  #7
You should do a full charge & discharge cycle on a new battery to correctly calibrate the "level" indicator. (So I've been told, anyway.)
Tom
RTPVid
Jul 29, 2012 12:53 |  #8
Joe Ravenstein wrote in post #14785892 (external link)
The 1st charge on a "new" battery takes significantly more time to reach full state than an older cycled battery does....
True, but...
...New battery, LP-E6, charged overnight but never got green light...
"Overnight" should have done it (unless the OP's "overnight" is 3 hours! ;))...
There may be a battery / charger issue. But, I'd still try to charge it again. If it doesn't work the 2nd time, and your charger works correctly with your other battery, return the battery.
Tom
VSS2011
Joined Apr 2011
Jul 30, 2012 15:36 |  #9
Thanks all.
Battery now been on charge for past 30+ hours and still no green light.
As my other battery charges fine, I'm going to assume this one is duff & send it back.
lannes
Jul 30, 2012 17:14 |  #10
Is is a genuine battery or third party ?
VSS2011
Joined Apr 2011
Jul 30, 2012 23:38 |  #11
lannes wrote in post #14791846 (external link)
Genuine.
VSS2011
Joined Apr 2011
Aug 26, 2012 02:29 |  #12
Sorted. Battery returned to Canon. Replacement received within 3-4 days.
Brilliant after sales service from Canon.
CanonCameraFan
Joined Sep 2011
Aug 26, 2012 19:16 |  #13
Good to see happy conclusion reported!
EOS 7D w/BG-E7 (3), 550EX (3), 430EX II, Vivitar 285HV, Opteka 6.5mm/3.5, Canon EF-S 10-18/4.5-5.6 IS STM, Canon EF-S 24/2.8 STM, Canon EF 40/2.8 STM, Canon EF 100mm/2.0 USM, Canon EF 70-300mm/4-5.6 L IS USM, Canon 77mm 500D Macro, Tamrac 614 Bag & 787 Backpack, Crumpler 8 MDH, 7 MDH, 6 MDH
http://www.flickr.com/​photos/johnebersole/se​ts/ (external link)
2,357 views & 0 likes for this thread, 8 members have posted to it.
Battery problem
1473 guests, 133 members online
