Paul4Runner wrote in post #14785943
Hi All,
What is wrong with my lens? The below photo was shot with a 60D, Tamron 17-50 non VC at 17 mm, f/14, 2 sec exposure and lastly I used the camera's level to insure a level photo. If anything there should be barrel distortion because I know I get slight distortion at 17 mm but the towers are leaning in, why and how could I correct this? Thank you in advance for your input.
I guess your camera was about 1.5 meters from the ground? If the camera hand been totally level, then the middle of the image would have showed the the buildings, about 1,5 meters above the ground. But the middle of the image is aimed above the roofs.
When using a wide angle lens, there is a very significant difference in distance between you and the buildings at ground level - where you stand - and all the way up at the top of these towers. Since the distance to the top of the towers are further away, it will look like they are bending inwards. It's just a question of perspective - things further away looks smaller. The top of the towers are further away and hence looks smaller. And they have to look smaller in all directions, so the distance between the towers also have to look shorter at the top than at ground level.
It is always better to use a bigger focal length and stand further away, when that is an option. Or - as already mentioned - invest in a very expensive, but nice, tilt-shift lens.
