FORUMS Post Processing, Marketing & Presenting Photos HDR Creation
Thread started 30 Jul 2012 (Monday) 01:42
why does green look yucky
lensfreak
Joined May 2012
Jul 30, 2012 01:42 |  #1
Why does green look really yucky when it comes to HDR?
imjason
Joined Nov 2010
Jul 30, 2012 02:17 |  #2
cuz someone over cooked their HDR?
my greens here do not look too bad:
Sunset from Tunnel View, Yosemite (external link) by JFChanPhoto (external link), on Flickr
Canon gear: EOS M, Canonet QL17, SX230HS, S95, SD1200IS
Non-Canon gear: D600, D5000, D70, XG-2, U20
rrblint
Gallery: 84 photos
Joined May 2012
Jul 30, 2012 02:19 |  #3
imjason wrote in post #14788956 (external link)
^^^^That's gorgeous!
Mark
imjason
Joined Nov 2010
Jul 30, 2012 02:28 |  #4
thanks mark!
OP, if the greens look "yucky" then process your HDRs so that the greens are not yucky. its like any type of post processing of photos. dont like something, then fix it.
Duck ­ Soup
Joined Jun 2012
Jul 30, 2012 06:23 |  #5
I too didn't like how greens and browns came out when I first tried photomatix. But you have the ability to create any tones you want. Keep at it and good luck!
Palmerston Panorama (external link) by Duck_ Soup (external link), on Flickr
Lowner
"I'm the original idiot"
Jul 30, 2012 06:41 |  #6
Duck Soup,
Were the greens really that colour?
Richard
sandpiper
Jul 30, 2012 06:45 |  #7
Duck Soup wrote in post #14789283 (external link)
That pretty much sums it up. Processing images is all about making the changes you want, if the greens "look yucky", then adjust them so that they don't. Have you tried adjusting the green channel with H/S/L ?
kirkt
Jul 30, 2012 12:20 |  #8
Photomatix will often introduce color shifting and artifacting into an HDR merge and tone map. It could be from several sources, including poor image acquisition in your exposure sequence (the images do not cover the entire dynamic range of the scene and clamping results), using AUTO White Balance so that colors are not uniform across the exposure sequence due to variations in the channel multipliers applied by the AUTO WB, noise in the shadow tones where green may be a dominant color (like grass and trees), overcooking the settings during tone mapping, etc.
Although Photomatix is not the only application to cause artifacts in the HDR merge and toning process, it is notorious for being able to produce them very easily if the user ignores proper technique for image acquisition or goes too far with tone mapping sliders. The HDR process does not pollute greens, but mishandling the HDR process can definitely produce unpleasant results.
Add "greens look yucky" to "everything turns slightly magenta" and "everything looks like it is covered in coal dust" and "everything looks like it has been touched by nuclear meltdown." A conservative, gentle tonemapping in Photomatix will yield a solid, well compressed base image that is ready to be finalized outside of Photomatix. The key is not to produce yucky greens in the first place - this avoids having to "correct" them later. Trying to push the image too far in tonemapping will uncover problems inherent in the source data and cause artifacts that will only be amplified as you try to manipulate the image down the line.
Rarely have I found that a final image can be produced fully within Photomatix and yield reasonable results. If you are going for "artistic" or whatever you want to call non-photographic, then you can get crazy results directly from Photomatix.
kirk
Kirk
Bsmooth
Jul 30, 2012 13:47 as a reply to  @ kirkt's post |  #9
Every single HDR I get from Photomatix has greens which have too much yellow in them, without a doubt. I've compared them to the originals, and there not even close.
So you can balance them afterwards in PS or in Photomatix.Add a little blue, or just color balance the whole image.
Bruce
wolfden
Jul 30, 2012 14:13 |  #10
Try to keep in mind that photomatix is just one step in the whole process, it shouldn't be your final image when it comes out of photomatix. Blue, Green, and Magenta are always needing adjusting it seems. HUE/SAT in Lightroom 4 work great for color adjustment correcting.
~KJS~
Photos by KJS (external link) | Flickr (external link) | Blog (external link) | 500px (external link) | Google+ (external link)
Canon 60D Shooter
michaelnel
Jul 30, 2012 18:45 |  #11
wolfden wrote in post #14791054 (external link)
I agree. My HDR processing workflow is pretty involved, and photomatix or hdr efex pro 2 or whatever combines the images is just a momentary stop along the way.
I frequently bring the RAWs into DxO Optics Pro for some lens corrections and save them as .tif files. Then into PMP or HEP2 (or sometimes even into Photoshop CS6, which seems to do better alignment than either one) for HDR 32bit image generation. Then PMP or HEP2 does the tonemapping even if I did the combining in PS. Out of there as a .tif, into PS for final tuning. Then sometimes from there into the trash can, which is where many HDR images should end up. ;-)a
I keep my photos on SmugMug: (http://michaelnel.smug​mug.com (external link))
tmcman
Jul 30, 2012 23:59 |  #12
As with Wolfden, I use LR to put things right as I saw it.
Comments, Questions, Observations Welcome
Fuji X-T2, 18-55mm, Gitzo 1541 w/ Markins M10 ballhead.
"Art always shows itself by doing much with few and simple things." Arthur Wesley Dow
2,064 views & 0 likes for this thread, 11 members have posted to it.
1638 guests, 143 members online
